2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Coding Speed Limit Info (8TH)
      01-03-2015, 12:54 PM   #1
sputman
sputman's Avatar
Drives: '15 M235i xDrive + '21 Z4 M40i
My M235i came with speed limit info and I figured it's most likely just software to enable on my buddies 435i. He as well has Lane Departure Warning and Collission Detection like my M235i.
I edited the FA to add 8TH and VO coded KAFAS2, FEMBODY, HU_NBT AND KOMI as I figured those were the potential ECUs it may effect.
The option is now available in iDrive and it shows the 3 dashed lines as it does before it reads any speed signs... but nothing ever gets detected and displayed in the instrument cluster or HUD.
I did a bit of googling and read that an FSC code may be required.
Is there a way to generate and install the FSC code via Esys? I remember reading something about generating an FSC code for nav updates... but have never done it.
Are there any other ECUs that need to be VO coded for this to work?
Is there any way to find out either of these answers given that my car has this feature from the factory?
      01-03-2015, 05:25 PM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
use the ncd / cafd tool http://www.bimmerfest.com/forums/sho...d.php?t=749668
and select SVT - cafd, load your svt and then select 8th it will show all the ecus affected....
for my car were but i don't have the KAFAS camera so if you do it against your svt it might have additional stuff
<<< CAFD_00000794.caf.011_033_013 (FEM_01) >>>
FEM_01 > LaMaster1 3073 > LUT_FLC_FORWARDLIGHTING_Y = F020Codierwert ohne AFS
FEM_01 > PfRainLightSensor 3130 > REGENSENSOR_INTERVALL = aktiv
FEM_01 > PfRainLightSensor 3130 > RLS_LIN_VAR = RLS
<<< CAFD_00000DED.caf.003_009_015 (HU_NBT) >>>
HU_NBT > EXBOX 3001 > SPEEDLIMIT_INFO = aktiv
HU_NBT > HMI 3000 > SLI_NAVI_DISPLAY = nicht_aktiv
<<< CAFD_000009C8.caf.006_000_031 (KOMBI L7_MID) >>>
KOMBI L7_MID > Anzeige_Konfiguration 3000 > SPEED_LIMIT = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_APPL = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_TIMEOUT = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_APPL = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > RCOG_TRSG_TIMEOUT = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > STAT_FAHRLICHT_TIMEOUT = aktiv
KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_AUS = mit_rls
KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_EIN = mit_rls
      01-03-2015, 05:28 PM   #3
pikcachu
pikcachu's Avatar
1399
for reference this is on an F10 with kafas:
<<< CAFD_00000C18.caf.014_078_002 (DSC_Premium) >>>
DSC_Premium > Applikationsparameter 3009 > CCC_CoCoIvx = wert_00
DSC_Premium > Applikationsparameter 3009 > CCC_CoMPerm = wert_00
DSC_Premium > Applikationsparameter 3009 > CCC_CoMPermDTC = wert_00
DSC_Premium > Applikationsparameter 3009 > CCC_CoPCCC = wert_00
DSC_Premium > Applikationsparameter 3009 > CCC_CoWeakAy = wert_00
DSC_Premium > Applikationsparameter 3009 > CCC_CoWeakvx = wert_00
DSC_Premium > Applikationsparameter 3009 > CCC_fLwDyn = wert_00
DSC_Premium > Applikationsparameter 3009 > CCC_MLCay = wert_00
DSC_Premium > Teillisten 3007 > Teilliste_CCC = wert_00
<<< CAFD_00001148.caf.000_021_002 (Kafas2) >>>
Kafas2 > SLI_CODING 3010 > NPI_ON_OFF = F010
Kafas2 > SLI_CODING 3010 > SLI_ON_OFF = F010
<<< CAFD_00000069.caf.010_001_049 (KOMBI L6 BO) >>>
KOMBI L6 BO > ERM_Konfiguration 3004 > RCOG_TRSG_APPL = aktiv
KOMBI L6 BO > ERM_Konfiguration 3004 > RCOG_TRSG_TIMEOUT = aktiv
KOMBI L6 BO > PIA_Einheiten 3008 > KI_PIA_SPEED_LIMIT = aktiv
      01-04-2015, 12:49 PM   #4
sputman
sputman's Avatar
Nice tool, thanks for the link. I got lucky and guessed the right 4 ECUs. I guess an FSC code is definitely required. Any hints on that side of things?
FYI, this is what was returned for an F20 chassis with a November 2014 build....
<<< CAFD_00000794.caf.012_034_013 (FEM_01) >>>
FEM_01 > LaMaster1 3073 > LUT_FLC_FORWARDLIGHTING_Y = F020_ohne_AFS
FEM_01 > LaMaster2 3074 > C_HBA_CAM_POS_Z = F020_KafasLow
FEM_01 > PfInternalMirror 3120 > PF_INMI_LIN_VAR = nicht_aktiv [Default]
<<< CAFD_00001148.caf.000_023_003 (Kafas2) >>>
Kafas2 > SLI_CODING 3010 > NPI_ON_OFF = F15_F020_F025_F030
Kafas2 > SLI_CODING 3010 > SLI_ON_OFF = F15_F020_F025_F030
<<< CAFD_00000DED.caf.003_012_025 (HU_NBT) >>>
<<< CAFD_000009C8.caf.006_002_033 (KOMBI L7_MID) >>>
KOMBI L7_MID > ERM_Konfiguration 3004 > STAT_FAHRLICHT_APPL = nicht_aktiv [Default]
KOMBI L7_MID > FZG_Ausstattung 3003 > ANZEIGE_NPI = nicht_aktiv [Default]
KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_SPEED_LIMIT = aktiv
      01-04-2015, 04:08 PM   #5
pikcachu
pikcachu's Avatar
1399
you will probably need to buy the FSC code... ask here http://www.bimmerfest.com/forums/forumdisplay.php?f=175
      05-29-2015, 11:35 PM   #6
mario123
Drives: 328i
you guys may be interested in this
http://f30.bimmerpost.com/forums/sho....php?t=1132862
      04-19-2016, 03:00 PM   #7
boxer29
Drives: F46
can this be done on a F46 uk model
just read this and it looks great .
can this be done in my 2016 gran tourer F46 which has got
1) navigation plus package (ZNQ)
2)technology pack (ZOJ)
3)driver comfort package(ZOJ)
ive got the HUD but it doesnt show the max speed limit ,it will show the collision warning with a red car when you approach are stopping car ,i assume it has got the front camera which is needed for the display of the speed limit .
thanks
      04-19-2016, 03:28 PM   #8
boxer29
Drives: F46
thanks
      04-28-2016, 02:03 AM   #9
gery1980
Drives: Bmw Gran Tourer
thanks
Hello,
Im only new here in this forum.
Just wanted to enquire.
Have You managed with this speed limit info?
I bought the same car and Im also looking to get this added to my BMW.
I was searching and can't find the right answer.
Please let me know.
      06-06-2016, 01:40 PM   #10
reala
Drives: 16' MG M235i xDrive
I really need this feature. I have back up camera. Is this going to work? Mine is 16 m235i.
      06-06-2016, 01:48 PM   #11
crbalch
The Schwab
crbalch's Avatar
Drives: 2020 AW M340xi
2017 BMW X1  [0.00]
2016 BMW M235xi  [0.00]
Same
      06-15-2016, 09:28 AM   #12
reala
Anybody got this working?
      03-27-2019, 09:02 AM   #13
Xarok
Germany
Drives: F33 428i
Sure, your back up camera is able to detect the signs, however you always have to drive backwards
