2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications IND Painted Reflector Installation Procedure
      02-12-2015, 10:37 AM   #45
WMc2318
Drives: 2015 228i
Will these fit a 228i Sport Line, or only M Sport?
      02-12-2015, 10:50 AM   #46
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Only M-sport. The sport line uses a different part number.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      02-17-2015, 03:19 PM   #47
darkfaker
Drives: M235I
got mine today,i tried one hour to remove OEM one, i took top one out with break one tab, and there is impossible to remove bottom one..
      03-16-2015, 06:57 AM   #48
M2TROLL
WRX Betrayer
Drives: M235ix Estoril Blue Coral Red
Yeah, its nowhere near as easy as ind lets on to be. I ended up just breaking one tab on both the top and bottom to get them out. Worse comes to worse ill buy a new set for a couple bucks if the broken ones dont hold on long enough for the dealer to accept it without noticing theyre broken when i return the car...it was such a pain in the butt to get them off, I am never going to trust the ind instructions to give me an indication of how easy something is to install ever again.
      03-16-2015, 11:08 AM   #49
F80_M
Drives: 1/1 PSM F80, F36, G11
Interesting cause I've used the instructions from IND. They are pretty straight forward and never had any issues with them
      03-16-2015, 11:30 AM   #50
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Originally Posted by SuperBran View Post
Worse comes to worse ill buy a new set for a couple bucks if the broken ones dont hold on long enough for the dealer to accept it without noticing theyre broken when i return the car....
any idea what the part number is?
      03-16-2015, 01:21 PM   #51
F80_M
Reflectors
Hey I have the stock Amber reflectors if you're interested
      03-22-2015, 10:21 PM   #52
MrBallooKnot
Drives: Like I Stole It
Can confirm. My install instructions would read:
Step 1: Try and be delicate and follow the manufacturer's instructions for the first one; destroy hand and break clip anyways. [20-40 min]
Step 2: Insert new one. [5 sec]
Step 3: Bash 2nd one through with something. [5 min]
Step 4: Insert the new one. [5 sec]
Disclaimer: This is the Internet talking
      03-23-2015, 02:04 AM   #53
e46m3to335i
e46m3to335i's Avatar
Drives: 2015 F80 M3
      04-05-2015, 12:24 PM   #54
M2TROLL
WRX Betrayer
That pretty much sums it up perfectly.
      04-07-2015, 08:50 AM   #55
artinz
Drives: m235i
The instructions may be straight forward in terms of what needs to be done, but it certainly is not a 5 minute job. As everyone has mentioned, taking the top part of the reflector is incredibly tough. I spent an hour yesterday trying to install mine (my m235i has the parking sensor), and finally gave up because it was getting too dark and cold and my fingers started hurting from trying to squeeze the top clips for so long.
Will have to try again later.
      04-07-2015, 09:22 AM   #56
pikcachu
pikcachu's Avatar
1406
Drives: M235i (F22 Red angel)
once you unclip the top clips is easier if you can put some trim removal tool (as it's soft and won't scratch) in between the grill and the bumper so that the clip doesn't go back in
      04-17-2015, 12:49 AM   #57
OrangePeanut
Drives: M235i BSM
2015 M235i  [0.00]
just installed mine, it's definitely not as easy as it looks (to a newbie like me at least). I couldn't for the life of me squeeze the clip heads enough to push it through with just two fingers...ended up finding a small plier and squeezing that inside, then I could grip down on the clips with my whole hand and it came out a lot easier.
I had that huge thing blocking the bottom clip as others have mentioned, ended up having to semi-yank it out.
lol I came really really close to doing this too
      04-22-2015, 07:07 PM   #58
Pistole-Peteski
Drives: 2015 BMW M235i
Did mine on the weekend, no issues. It's definitely not as easy as the iND instructions depict, but it was really not a problem. No tools needed. However, I must say, I did have my wheels off as I was adding spacers at the same time... So having that extra space to work in the wheel well made the job a lot easier for me. I simply reached in, pinched the top clip as hard as I could and pushed out firmly and did so while looking at the reflector from the outside of the fender. As I could see the reflector beginning to move slightly out of it's seat, I grasped it with my free hand and began to firmly pull... So one hand was pushing from inside the fender, while the other hand was pulling from outside the fender. You will see the reflector beginning to get further and further out of the seat until finally the top clip comes free... Once that's done, do a similar exercise for the bottom clip, although I couldn't pinch mine due to the parking sensor being in the way... Nevertheless, the process is basically the same - push from one side and pull from the other. It was literally not a problem at all... Took me a couple minutes per side.
Good luck and I hope this helps.
Tpeterson156.50
      04-26-2015, 12:45 PM   #59
cmbaldwin
cmbaldwin's Avatar
Drives: 2014 228i
Is there any plan by IND to make the painted reflector for the 228i as well?
      04-27-2015, 10:32 AM   #60
m235iMike
Drives: 2015 m235i, 94 Supra, 03 Evo
anybody else have mineral gray pictures?
      04-28-2015, 05:28 PM   #61
scottomfg
scottomfg's Avatar
287
Drives: '14 Cayman S 6MT, '21 X5 45E
Here are two phone pics. In real life, they look great and as seamless as a separate piece can look.
2014 981 Cayman S 6MT, X73 Suspension, SES
2021 X5 45e MSport, Manhattan Green, Coffee Merino, Review & Photos
Previous: '18 340 GT, '15 M235i 6MT, '15 i3 REx, '15 x1 xDrive28i
      05-05-2015, 01:33 PM   #62
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
I have a set for the 228i from IND...I couldn't tell any difference between any of the models, they all look the same.
Will know tonight for sure.
      05-05-2015, 01:51 PM   #63
OpenAir
OpenAir's Avatar
Andrew, the set you sent me is for my Sport Line 228i. Should I even try then?
      05-05-2015, 07:04 PM   #64
OpenAir
OpenAir's Avatar
It appears that the F22 kit will work on the Sport Line in the Front. I did not have a chance to pull mine off due to weather, but I held the IND unit up to the OEM and they appear identical!
The rear units will not fit...not even close. Weather permitting, I'll try to mount the fronts tomorrow.
      05-06-2015, 08:35 AM   #65
tux2005
Drives: 2017 M2
The IND M-Sport/M235i front reflectors do not fit 228i SportLine, they may look the same when you're holding the IND ones up to the SportLine but they are different. I found that out after having fought to remove one and then the IND ones would not fit.
      05-06-2015, 09:43 AM   #66
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
We only offer a solution for the M-sport front and rear bumper. There a slight variances in the core pieces that will impact fitment.
I have sent you a private message.
