M235i H&R sway bars with Ground Control adjustable front endlinks |
07-31-2015, 02:41 PM | #1 |
Rep 845
Getting them installed Monday. Might take some time -- it's a pretty intensive process for F-Chassis BMWs. I'll post a review once I get it done.
07-31-2015, 06:05 PM | #3 |
Rep 201
I've got my car in the shop getting my hotchkis bars installed. What do end links do and/or improve?
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
07-31-2015, 06:43 PM | #4 | |
Rep 845
I didn't even know Hotchkis had bars out for the M235i yet.
07-31-2015, 07:14 PM | #5 | ||
Rep 201
Pretty sure I'm the first person to get the Hotchkis production bars. I badgered them almost daily lol.
07-31-2015, 07:46 PM | #6 | |
Rep 566
Typically, if you make the front end links shorter the front end will be stiffer, therefore, more prone to understeer mid-corner but will be more responsive (sharper initial turn in) and more stable on a straight but less comfortable on less than perfect roads. If you make them longer (effectively makes the arm of the sway bar longer) the front end will be softer and less prone to understeer mid-corner (to the point of outright oversteer depending on your settings) but slightly less responsive (slushy initial turn in) and less stable on a straight but generally more comfortable. |
08-03-2015, 12:06 AM | #8 |
Rep 845
Goods before install.
08-06-2015, 10:21 AM | #10 |
Rep 845
Just got my car back last night. The endlinks are the right size, but the hardware on the ends needs to be swapped, so I'm using the stock endlinks right now. They do just fine for a modest (1 inch) drop. I think if you were slammed on coilovers or something, you might need them more.
Survey says -- awesome upgrade. A gigantic pain in the ass to get the sway bars installed (very expensive if you aren't doing it yourself), but definitely stiffens the car up and kills any body roll the car might have had.
08-06-2015, 06:08 PM | #11 | |
Rep 1,503
FBO M235i r
F80 M3 |
08-06-2015, 06:23 PM | #12 | |
Rep 845
To be honest, although I like the upgrade, if I wasn't tracking the car, I wouldn't bother. It's too much of a hassle.
08-07-2015, 07:04 PM | #13 | |
Rep 957
I will post a picture of what the stock end links looked like after a track day running hr springs and camber plates when I get to my shop and can dig them out, absolutely destroyed them. |
08-07-2015, 11:08 PM | #14 | |
Rep 201
Post pics of the damaged stock one please. |
08-07-2015, 11:10 PM | #15 | |
Rep 201
08-08-2015, 10:09 AM | #16 |
Rep 957
08-08-2015, 10:17 AM | #17 |
Rep 957
Also I replaced the rear ones, there plastic from the factory. The factory rear sway bar was about as thick as a pencil, not sure if the plastic ones would bend too much. For a 150 bucks seemed reasonable.
08-08-2015, 10:28 PM | #18 | |
Rep 356
08-16-2015, 10:29 PM | #19 |
Rep 957
Here are the Picts, they also make the bar hit the tie rod ends under certain conditions, may not be an issue w the 228 since it is lighter. If you look at your bar and it is chipped up, then you know it's hitting.
Kind of hard to tell from photos but drivers side is a little bent. |
