2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Square Setup
      04-09-2019, 03:52 PM   #1
tubingchamp
tubingchamp's Avatar
101
Drives: 2023 G87 M2
Square Setup
Hi guys,
Wanting to mount 245/35/18's all around for maximum grip.
I have seen a few threads with concerns about Xdrive.. Does it take up more space up front?
I would probably go for a 18X8.5 wheel with 40 offset.. Should this clear the suspension and fender?
Probably going to get MPS 4S tires.
Thank you.
      04-19-2019, 04:33 PM   #2
Shayan55
Shayan55's Avatar
Drives: F90 M5
2105 BMW M235I  [0.00]
Originally Posted by tubingchamp View Post
Hi guys,
Thank you.
No idea about the X drive part, but i have this smae exact tire size setup on mine but im RWD
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct
Hmu on Ig: @n55_shayan
      04-23-2019, 05:59 PM   #3
tubingchamp
101
Drives: 2023 G87 M2
Yeah, I've seen some square setups without rubbing, but none seem to be XDrive.. Not sure if anybody knows if it takes up additional space or not, but that would be very helpful
Thanks
      04-23-2019, 09:58 PM   #4
trilax59
Drives: '18 M2 LCI
  [0.00]
  [0.00]
2018 BMW M2 LCI  [0.00]
I'm on xDrive and am running 235/40/18 on APEX EC-7 18x8.5 ET45 square with a 5mm spacer in the front. If you want to do 245/35, you would have to dial in some slight negative camber accompanied with the spacer (assuming you use the same specs as I have). You should contact APEX race parts for fitment advice, as they would be able to get you exactly what you want.
EDIT: I'm also using MP4S.
-Ryan
'18 M2 LCI 6spd
Dylan861330.00
      04-24-2019, 01:22 PM   #5
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
-Ryan
I run 245/35/18 in front at 34psi and 265/35/18 in the rear at 37psi. Car has front camber plates and is aligned more aggressively than stock. Handles quite well. Tires are Continental ExtremeSports.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD.
Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r).
Dylan861330.00
      04-24-2019, 01:54 PM   #6
XutvJet
I'm running 245/35R18 MPS4s on 18X8 et43 wheels and no spacers. No issues with clearance whatsoever. The xdrive is no different than the RWD in terms of fender and suspension wheel and tire clearances.
A 8.5" rim is not necessary to run 245/35R18s and most 8.5" rims for these cars have crappy offsets which then force you to run spacers and/or stretch or run narrower front tires.
https://www.2addicts.com/forums/show....php?t=1597122
      04-24-2019, 04:56 PM   #7
tubingchamp
101
Drives: 2023 G87 M2
Sweet.
Yeah, I've seen your setup and have been using it as a benchmark. Most people go with 8.5" rim, but 8" should be fine with a 245. My main concern was XDrive.
Thanks for the info .
Now to make a choice on some 18X8 et40-43's....
      05-28-2019, 03:51 AM   #8
TakoMako
Drives: M240i Xdrive
17x8 et40 is what most people run for 245 square setup. No modification required and has more tire options. I am xdrive and using this, but I am search to move up to 255 square with camber.
      06-19-2019, 06:57 PM   #9
If you're dialing in camber, you can also use 9" if you want more support for a 245. Apex directed me to either 235/40 or 255/35 for the 18x9. I think the slight sidewall stretch on a 235/40 with 9" rim would buy you a bit of clearance back so you don't need much more than -2.0*. It's how I set up my street wheel set, just haven't run them, yet. Cup2 up front in 235/40 and PSS in the rear, 255/35, you can see they fit very similar, just the 255 has about a half inch wider contact patch. Most fear the 9" square setup, but I'm actually thinking about 265's on 9.5" wheels next time around.
      06-20-2019, 03:22 PM   #10
MerlinMc
Drives: 2020 M240i
Agreed. Stay with an 8" wide wheel for the square set up using 245s. I have 245/35-18s with et 45 that work; have used also these 3mm and 5mm spacers in front. Also now have 245/40-17 et 43; they also work well with the 3mm spacers for an et of 40.
The 8.5 wheel with the 245 will likely require some modifications like adjusting the camber. I didn't want to do that.
      06-20-2019, 06:01 PM   #11
tubingchamp
101
Drives: 2023 G87 M2
Think 40 offset would be ok?
      06-20-2019, 11:23 PM   #12
MerlinMc
Drives: 2020 M240i
et 40mm using 245 on 8" width wheels works well for me. I can post some images over the weekend. No rubbing and no poke and not inset either. This is without any camber adjustments or other modifications.
      06-21-2019, 09:53 AM   #13
tubingchamp
101
Drives: 2023 G87 M2
Sick, thanks
      07-05-2019, 10:59 AM   #14
tubingchamp
101
Drives: 2023 G87 M2
Ended up going with 18 X 8 et 40 Fast FC04 wheels with MPS4S 245/35/18.
They fit really well, no rubbing yet. I have not driven hard though, tires still need to break in.
Might drop it a little with Dinan springs or something.
View post on imgur.com
RMNB365.00
      07-05-2019, 03:02 PM   #15
MerlinMc
Drives: 2020 M240i
Looks good.
