04-09-2021, 07:16 PM | #23 | |
Rep 442
One thing to keep in mind is that the official ISTA procedure, and the near verbatim text copy in the Foxwell tool, only does the ABS bleed on the left rear and left front. At first I thought the Foxwell tool was goofy and missing the right side, but no, you only do it on the left. Not sure why you don't do the right side, but I guess the ABS block is exercising both sides and just moving fluid through the front or rear circuits. I suspect Maxi Check will work fine. |
waxwing_f311.50 |
04-11-2021, 10:49 PM | #24 | |
Rep 452
Borrowed my buddy's motive power bleeder. Testing the lines on it. Hooked it up after pouring both bottles of ate typ 200 in.. Started the bleeding on the rear caliper..seeing a lot of bubbles coming out, thought it was odd..got up to the hood in time to see a pin hole leak in the line completely explode and send almost 2 full liters of the brake fluid out all over the car and driveway.. spent the rest of the evening trying to wash off as much as I could, ran to HD to get replacement line..clamps....repaired the bleeder, then settled for Pentosin LV4 as it was the only one in stock and had to be re-bled at that point since air was already in the lines. brakes feel decent...only to find out that my brake pads "service" is due in about 3200 miles. Might repeat it again then and do it with typ 200 if I really want to punish myself. Gives me plenty of time to figure out how to cycle the ABS pump. |
04-22-2021, 07:30 PM | #25 |
Rep 442
I feel your pain.
I had to start researching the ABS bleed processes when I was doing a simple caliper bleed between track weekends. Not doing a full flush so I was just minding the reservoir and refilling it. I had done 3 wheels, and just had the drivers front to go. Took a glance at the reservoir and I thought I had just enough before I would have to fill it. Started the bleed, and then dropped the wrench. Of course it skittered under the car and I had to scramble to grab it. Then I couldn't get the wrench on the bleed screw. By the time I had finally closed the bleeder the reservoir was completely dry. ARGH! It took about 4 ABS bleeding cycles, and 4 liters of brake fluid, over a couple months of trying, before I finally got all the air out and the pedal was as firm as it was originally. |
04-23-2021, 10:34 AM | #26 | |
Rep 1,264
dradernh4413.00 |
04-23-2021, 05:19 PM | #27 |
Rep 442
Whenever I work on my brakes, I have a bright drop light permanently next to the reservoir to keep an eye on it. That's what made it so easy to see I'd drained the reservoir when I screwed up and dropped the bleeder wrench.
04-24-2021, 09:57 AM | #28 |
Rep 1,264
Yeah, I did the same thing and the brakes were mushy. I took the car to my local indie and they did a full brake bleed including the ABS. That's when I started putting the flashlight behind the reservoir.
05-10-2021, 11:55 AM | #29 |
Rep 515
I was watching some Youtube guide where they use a pressure pump to push brake fluid through the line and let older liquid out from bleed holes. Is this flushing method include the ABS? Is there a good guide in here somewhere?
05-10-2021, 07:42 PM | #30 | |
Rep 442
The ABS pump has a lot of valves and passages and the pump itself that hold some brake fluid in them. To flush the ABS pump and valves, and the associated passages in the pump block, you have to 'cycle' the pump. This runs the pump and cycles the valves open and closed so that as new brake fluid moves through the system it gets into every part of the ABS block. This is a great video on using the BMW ISTA maintenance software to do the ABS cycle bleed: The process with an OBD tool is usually the same. Just a different tool you are pushing the buttons on. My Schwaben/Foxwell tool even steals a lot of the text from the ISTA software, and the steps are identical. FaRKLe0079 posts a lot of good videos. He also has a good simple pressure bleed video he links to in this one. Do you have to do the ABS cycling? Maybe not every time. I only do it in the fall when I put LV fluid back in for the winter. But definitely if you got air in the system, or you at several years since the last time you did it. |
05-11-2021, 08:42 AM | #31 | |
Rep 515
05-11-2021, 12:10 PM | #33 | |
Rep 3,497
"Despite what the manuals say, not a single BMW technician I know would run the ABS pump unless it was absolutely necessary, such as when air gets in the pump--for example, when replacing the brake master cylinder. No such thing is required during an ordinary brake-fluid change or when replacing brake pads and rotors." Mike Miller, Technical Editor Roundel Magazine May 2021 I can't find the quote, but I recall one of the writers at Car & Driver suggesting it's a good thing to replace the fluid in the ABS pump when doing an annual brake fluid replacement. IIRC, he said "your ABS pump will thank you". My memory may be playing tricks on me, though.
05-11-2021, 02:35 PM | #34 | |||
Rep 515
Hmm, that last statement dradernh, I seems to have seen that too somewhere.. Thanks guys! |
