What oil do you use and how do you like it? |
View Poll Results: What oil do you use? | |||
BMW Twinpower Turbo 5w30 | 33 | 50.77% | |
Castrol TWS 10w60 | 1 | 1.54% | |
Amsoil OE 5w30 | 3 | 4.62% | |
Mobil 1 0w40 European formula | 15 | 23.08% | |
Rotella T6 5w40 | 3 | 4.62% | |
Motul 8100 5w40 | 10 | 15.38% | |
Voters: 65. You may not vote on this poll |
05-21-2016, 02:17 PM | #23 | |
Rep 647
Now im easily making 10-15hp increase to the wheels after this 0w40 mod |
05-21-2016, 02:19 PM | #24 | |
Rep 1,422
Thinking of buying a D I N A N badge and an S10 badge |
05-21-2016, 03:13 PM | #26 |
Rep 1,422
Man, that's a broad range. I guess 0w40 has the most flexibility then. Thanks man. My manual said 5w30 but those other grades were "optional".
05-21-2016, 05:21 PM | #27 |
Rep 1,422
Ok, I've spent a few hours traversing online for info on 0w-40 oils that meet BMW LL-01/LL-01 FE specs.
1. Castrol Edge (German) 2. Motul 8100 X-max (although on BITOG, they claim Motul isn't as good as Mobil 1, which in its current FS formulation is no longer approved by BMW) Amsoil European Car Formula I couldn't find any LL-01 approved LiquiMoly, Redline, She'll (non-OE BMW TwinPower oil).... Also, found out that Rotella T6 is not LL-01... Shit. |
05-21-2016, 07:03 PM | #28 | |
Rep 647
05-21-2016, 07:14 PM | #29 | |
Rep 1,422
But what of cars running big boost? Running/holding 17-18psi sometimes... |
05-22-2016, 09:27 PM | #30 |
Rep 1,422
So far, overwhelming response for the BMW OE oil. That said, which version do you buy?
There are three levels: |
05-23-2016, 08:25 PM | #31 |
Rep 647
05-23-2016, 08:36 PM | #32 |
Rep 1,422
I'm confused...which one do they put in our cars for "free" maintenance?
05-24-2016, 05:55 PM | #33 | |
Rep 957
0w 40 had a higher ambient temperature range than 5w30, I would prob. not run the 0w 40 in winter in Canada, but I live in FL so no problem 0w 40 is a better choice for the turbos, I think 0w-40 is more suitable for our turbo cars. Especially when you wot alot, you will see very high engine oil temp, 0W-40 will give you more protection on wot. You may see marginal fuel economy drop over 5w 30. |
05-24-2016, 06:08 PM | #34 | |
Rep 1,422
05-25-2016, 09:08 AM | #35 | |
Rep 647
05-25-2016, 10:13 PM | #36 | |
Rep 1,422
Thanks Manchu. |
05-26-2016, 03:08 PM | #37 |
Rep 53
Pennzoil (Shell) recommended oil for the m235i is Pennzoil Platinum Euro 5w40. It's what I'm using. 0w40, 5w40, 0w30, 5w30 are all acceptable according to my 2016 manual. Might switch to 0w30 for the winter if I can find a good one affordably.
http://www.pennzoil.com/en_us/oil-se...NfRUZ0OFBsTWpW |
05-26-2016, 03:11 PM | #38 | |
Rep 1,422
05-26-2016, 06:40 PM | #39 |
Rep 53
It's a group 3 full synthetic made using a gas-to-liquid process rather than hydrocracking. It's not group 4 since the base oil is not a blend of PAOs.
The performance in tests of these Shell GTL oils has generally been very good and I've seen VOA of Platinum Euro where the additive package compared very favorably to any other I've seen. Group IV oils do not always exceed the performance of Group III. Of course, bobistheoilguy.com is the home to most of this info and speculation. Also: http://www.machinerylubrication.com/...ase-oil-trends note the numbers here are from 2002 at the latest and specific to hydrocracking. group III has only continued to improve. Last edited by stealthwang; 05-26-2016 at 06:59 PM.. |
05-26-2016, 06:59 PM | #40 | |
Rep 1,422
So I'm running and holding 17.5-18psi of boost and wanted more protection. Pretty soon will run upward of 20psi. Do you think Group III will stand up to that type of usage? I used to think that shear strength is everything but apparently detergent packages make a big difference too. Your thoughts? I'm royally confused. |
05-26-2016, 07:48 PM | #41 | ||
Rep 53
got no doubt it can. i'm sure you can find those running this oil in even more demanding applications.
group III can out perform group IV. Quote:
to quote that earlier article: Quote:
05-27-2016, 04:07 PM | #42 | |
Rep 647
05-27-2016, 04:58 PM | #43 |
Rep 5,372
Fellas, Castrol 0W-30 Euro is where it's at. I won't get into the detailed chemical specifics, but it's extremely robust and behaves much like a 40 weight in certain instances.
05-27-2016, 06:05 PM | #44 | |
Rep 1,422
This is VERY recent. There might still be old stock that have the old labeling. |
Tags |
#bmwoil, #castrol, #mobil1, #motul, #oil |
