2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Windshield Washer Warning Light
      02-10-2015, 01:39 PM   #1
TB///M3
Drives: 16 ///M3
I'm getting a washer fluid warning, even though I have filled it to the top.
Is anyone having this problem? I have coded the headlight washer off, not sure if that is the case.
      02-10-2015, 02:44 PM   #2
Nahlem
Nahlem's Avatar
Sweden
1144
Drives: None atm
2022 BMW i4 m50  [10.00]
For me it was due to the weather here in Sweden causing a lot of issues, The first time it happened i topped the liquid in the container, The Used a lot of the liquid on the windshield and it reseted it self somehow and the warning dint appear for a while, Then came a couple of weeks with -6-9c during night time and then during daytime it was around 4-8c so it freaked out again. Then i had it replaced.
      02-10-2015, 03:07 PM   #3
jb606
Drives: 430i xDrive
What type of washer fluid are you using? Don't know how BMW does it but some of the VW folks have had issues with certain brands (RainX?) messing up the level sensor.
      02-10-2015, 05:04 PM   #4
BlueM235
Drives: M4 2017 comp pkg
Had the same problem a few days ago. Thought that the fluid was frozen and the alarm came on. I am using -40C fluid. Senor issue maybe or crappy software ???
      02-10-2015, 08:42 PM   #5
TB///M3
Drives: 16 ///M3
I am using the RainX fluids. Could that be it?
      02-10-2015, 10:28 PM   #6
alz0rz
What goes here?
alz0rz's Avatar
452
Drives: 2019 G30 M550i
I had this issue just yesterday.... I too am using rainX fluid. It came on for a few drive cycles and has not come back on.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      02-11-2015, 01:21 AM   #7
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
doesn't your dealer refill it for free?
      02-11-2015, 08:25 AM   #8
Bimmer86
Drives: 2024 M440i xDrive Gran Coupe
Pretty sure all the dealers do refill it for free, but I mean personally I wouldn't go to the dealer just to refill washer fluid either.
      02-11-2015, 12:06 PM   #9
TB///M3
Drives: 16 ///M3
Well, I noticed something, the light was coming on during really cold temps in my area.
When used the washer, I noticed my headlight washer never came on. Maybe due to temps? Then a couple of days ago when it got warmer around upper 30's. The headlight was sprayed. Every since then, the light haven't come on.
      02-11-2015, 12:15 PM   #10
alz0rz
What goes here?
alz0rz's Avatar
452
yeah.. I don't have time to drive to the dealer to get my windshield wiper fluid refilled.
2019 G30 M550i
GBNF:
      02-11-2015, 08:22 PM   #11
TB///M3
Drives: 16 ///M3
I spoke too soon, the light came back on tonight. I don't know why using different fluid will upset the leveling.
      03-01-2015, 06:24 PM   #12
Sindarin
Drives: BMW
The washer fluid level sensor is a capacitive sensor with contactless measurement through two small lances. The sensor is part of the washer fluid tank. RainX washer fluid is known to damage this sensor which will require its replacement.
Just us the cheap blue washer fluid you can get at the gas station and it shouldn't be a problem.
      03-04-2015, 09:40 PM   #13
TB///M3
Drives: 16 ///M3
Yes, you are correct, I did end up putting in the cheap blue washer and the light did go away.
      03-04-2015, 09:59 PM   #14
2msport
Drives: '14 228 MT
I'm using the green RainX fluid. Have been for 6 months. No issues
