2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Harman Kardon Sound System Settings
      10-14-2017, 03:57 AM   #1
omera60
omera60's Avatar
Turkey
195
Drives: 218i Coupe
Wondering what everybody else is using, I’ve found that +6 tremble with +4 bass is quite nice especially in higher volumes. However I can’t decide what’s the best fader setting, I feel like the back speakers have potential however when I put the fader towards the back it sounds like I’m loosing some of the immersive setting when it’s in the middle. What do you guys think? What are your settings?
      10-14-2017, 03:55 PM   #2
ctemkin
Drives: 2018 M240i
What I have found works best so far is turning the treble down two notches and turning the bass all the way up. That takes away some of the screechiness, although it is more revealing of the lack of resolution of the HK setup.
Monday morning I am having everything but the subwoofers swapped out for Bavsound, and I am hoping that this will be a big improvement.
omera60194.50
      10-15-2017, 03:46 PM   #3
BEM-S4
BEM-S4's Avatar
Amp too or just speakers? Once you get the speakers in you?ll want the subs. Trust me. And throw $100 at a FiiO X1 that?s the best value / $ upgrade there is.
      10-16-2017, 01:15 PM   #4
ctemkin
Drives: 2018 M240i
I was scheduled to have the amp and all the speakers except the subwoofers replaced this morning, but unfortunately Bavsound sent the wrong size speaker brackets to the installer. So I do have a new Bimmertech amp, and it seemed to me that just the amp, with whatever setting the DSP was, improved the resolution and overall sound noticeably. I am now scheduled to have the HK speakers replaced on Thursday.
An obstacle to using a Fiio or any other similar device is that my car does not have an AUX input, just the USB input. The installer is consulting with Bimmertech to see if it is possible to add an AUX input.
I'll report back on how all this goes.
      10-16-2017, 01:18 PM   #5
BEM-S4
BEM-S4's Avatar
Ah that?s right. Sacrifices in the name of progress (aka cost cutting).
Viffermike1753.00
      10-17-2017, 09:31 AM   #6
Viffermike
Viffermike's Avatar
No consultation needed. The Bimmertech amp does have an analog input, as well as a digital input. Your primary challenge will be controlling source selection and anything you connect to the amp's input (FiiO DMP or otherwise) from the driver's seat. Wires shall be run ...
--Helmets are for closers.--
BEM-S44515.50
      10-17-2017, 10:09 AM   #7
BEM-S4
BEM-S4's Avatar
While a bit of a challenge it's also an opportunity in disguise as you can get good, clean source material directly into the amp. I would be interested in two things, first if you can source the BMW OEM USB / aux-in part and connect USB to head unit and aux-in to amp for a factory look install withing the armrest. Second would be the switch VM mentions.
WHILE YOU ARE AT IT AND THE CAR IS APART - isn't that amp controlled / settings tweaked via an Ethernet cable? I'd run that up to the armrest as well so you wouldn't need to rip the trunk back apart to mess with it.
      10-17-2017, 11:28 AM   #8
MarcoZandrini
Drives: 2018 M240i
I replaced the front HK speakers with the Eton B100W 10 Cm 2 Way Components over the weekend. Great sound improvement! Buy them at Amazon.
zenmaster1576.50
      03-30-2018, 02:04 PM   #9
aturk
Drives: 2014 BMW M235i
Did you have to use the B100 XHP crossovers?
      04-04-2018, 03:45 AM   #10
VIN240i13
VIN240i13's Avatar
Drives: 2018 BMW M240i F23
Going back to the original post... (No MODed HiFi Question)
I have an F23 with the upgraded HK system, its stock in current setup and have mine set up very similar except with the fader more prominent to the front / center speakers. I am not much of a HiFi fanatic and with a convertible, unless you drive top UP the majority of the time, the sound system is always competing with wind noise. For me, my car is not a daily driver and an upgrade / speaker swap-out is not on my to-do list anytime soon.
2018 ///M240i Convertible [Loaded - Garage Queen]
2018 Ford F150 XLT FX-4 [Daily Driver]
BMW CCA #535395
SCCA #619713
      07-10-2018, 03:11 PM   #11
Drogles
Drives: BMW 230i
Hi everyone,
First post here, and sorry if it's not in the correct thread and so on. I tried searching for something similar, but this was the closest I could find. So bear with me.
Anyway, I have a 2016 230i with the Harman Kardon sound system, but when I go to sound settings, there is no Logic7 ON/OFF option. Am I doing something wrong here, or is it not supposed to be there in the first place? This might be a stupid question, so again; bear with me, fellas!
Kind regards.
      07-11-2018, 01:08 AM   #12
somm
Austria
Drives: M240i xDrive
Hy - this setting is not available in the "little" H&K version used in the 2 series ...
      07-11-2018, 03:17 AM   #13
omera60
omera60's Avatar
Turkey
195
Drives: 218i Coupe
Originally Posted by Drogles View Post
Hi everyone,
Kind regards.
For some reason these vehicles don't have the option, I think it is only available in 3 series and up with HK Systems.
      07-11-2018, 05:01 AM   #14
BEM-S4
BEM-S4's Avatar
Hi everyone,
Kind regards.
They don't. 2 HK = 3 and beyond HiFi.
      07-11-2018, 04:22 PM   #15
Drogles
Drives: BMW 230i
Oh okay. Thanks for clarifying.
Kind regards
      07-16-2018, 09:06 AM   #16
MarcoZandrini
Drives: 2018 M240i
No. The speakers come with blocking capacitors.
      11-20-2018, 10:23 PM   #17
icin235
icin235's Avatar
Drives: 2015 M235i Silver 6spd
Wondering what everybody else is using, I’ve found that +6 tremble with +4 bass is quite nice especially in higher volumes. are your settings?
This is what I think is a good starting point for most music types.
Treble +3
Bass +3
Balance +2 to the right
Center speaker disconnected (cleaner sound).
      11-21-2018, 09:12 AM   #18
cxp213
cxp213's Avatar
313
Why do you shift the balance to the passenger side?
      11-21-2018, 10:16 AM   #19
FX TR8R
FX TR8R's Avatar
Drives: Seaside Blue 230i
2018 BMW 230i  [0.00]
Treble +3
Bass +3
Biased slightly to the back.
      11-21-2018, 10:20 AM   #20
icin235
icin235's Avatar
From driver perspective (sitting on left side) the left side speakers sound louder. Shifting to right +2 sounds more balanced to me.
      12-17-2018, 08:51 PM   #21
Lipper
Lipper's Avatar
Australia
42
Drives: 2015 M235i 6MT
Do you hook up the FiiO via Bluetooth? Are you still able to use your cell phone for calls? Looks like an interesting device.
2015 M235i 6MT | Alpine White/Black Dakota | MPerformance Body Kit | 19" M-Sport 359s w/Pilot Sport 4S (r:255/30 f:225/35)
BMS JB4 w/Bluetooth| Wagner Competition IC | Wagner DP | Evolution Raceworks IC Pipes | Dynan CAI | BMS Catch-Can | Active Autowerks Axle-Back | ECS 2-Piece Rotors/Hawk HPS 5.0 Pads | Full MP Carbon/Alcantara Trim | M-Performance Alcantara/LED Steering Wheel
      12-18-2018, 07:29 AM   #22
BEM-S4
BEM-S4's Avatar
No, you use AUX In which is a better connection sound-wise. Your car is old enough you should have one.
