2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Screen Mirror
      05-24-2017, 02:17 PM   #45
Cars
Cars's Avatar
39
Drives: 2017 M240xi MGM
Originally Posted by EL BAN View Post
Thanks!
BAN_M2C4180.00
      10-18-2017, 04:08 PM   #46
derfl
Drives: F30 335i
Great will code it on weekend.
Is the mirror screen also available with splitscreen?
So navigation in split and Android screen on the main screen?
      10-22-2017, 01:59 PM   #47
zenmaster
Drives: '17 M2
Yes.
http://f87.bimmerpost.com/forums/sho...&postcount=901
      10-22-2017, 06:10 PM   #48
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Biggest thing now is killing the DVD in motion so it doesn't kick off the mirroring when car is moving.
      10-24-2017, 02:53 PM   #49
derfl
Drives: F30 335i
Does anybody know if the splitscreen is also available with screen mirroring?
Thanks.
      10-24-2017, 03:01 PM   #50
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Thanks.
Yes.
      10-27-2017, 09:56 AM   #51
derfl
Drives: F30 335i
Coded it today, thank you guys for you help!
Everything works wonderful except one thing.
On my phone Bluetooth is always on and connects automatically when I enter the car.
If my phone now is connected via Bluetooth the screen mirroring display is ok and I can see my phones display on the bmw screen. But there is no sound available. If I disconnect Bluetooth the sound over screen mirroring is working.
So I always have to disable Bluetooth and enable wifi to use screen mirroring. After my mirror session is done I have to enable Bluetooth again.
Is this normally or do I have forgotten something to code or adjust?
Thanks again.
      10-27-2017, 11:23 AM   #52
Almaretto
Almaretto's Avatar
2374
Thanks again.
Not sure if normal, but you can use programs like Tasker to automatically disable and enable base on criteria like connected to vehicle.
      10-27-2017, 11:38 AM   #53
derfl
Drives: F30 335i
Thank you!
Is it possible for you to test it for me if its the same in your car? Appreciate it.
The problem with tasker is that i need both. Sometimes i use screen mirroring for 20 minutes and then id like to make a phonecall or navigate to an adress which is on my phone contacts or use the integradet spotify APP.
Also i think its not normal that Bluetooth must be disconnected when using screen mirroring.would be great if someone could test it for me. Thanks.
      10-27-2017, 11:40 AM   #54
Almaretto
Almaretto's Avatar
2374
Thank you!
My phone does not support screen mirroring, so cannot help. Good Luck.
      10-27-2017, 11:56 AM   #55
cxp213
cxp213's Avatar
313
Sounds normal. Sounds like the car prioritizes bluetooth over wifi, especially for sound output, since that's what BT was designed for while the wifi is an aftermarket add-on which happens to also carry sound.
      10-27-2017, 12:02 PM   #56
derfl
Drives: F30 335i
Thanks.
Maybe someone can try it. If its also without sound when Bluetooth is connected we can be sure that it is normal.
      10-27-2017, 01:36 PM   #57
Almaretto
Almaretto's Avatar
2374
Thanks.
Wifi is better quality. Carplay uses both.
      10-27-2017, 07:26 PM   #58
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
Has anyone gotten the DVD in motion coded to allow the screen mirroring while driving?
      10-27-2017, 08:58 PM   #59
Almaretto
Almaretto's Avatar
2374
Yes, though solutions are all commercial.
      10-28-2017, 08:49 PM   #60
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
I shall have to look into this then. PM me with a suggestion.
      10-28-2017, 09:00 PM   #61
Almaretto
Almaretto's Avatar
2374
Bimmercode App is least expensive.
WolfGTI716.00
      10-30-2017, 04:09 PM   #62
derfl
Drives: F30 335i
Come on Guys, nobody tried it?
Please help me to find out if it's normal.
Thanks
      10-30-2017, 04:13 PM   #63
Almaretto
Almaretto's Avatar
2374
Thanks
In my limited experience, that behavior is not normal on either IOS or Android.
      10-31-2017, 11:10 AM   #64
derfl
Drives: F30 335i
What should I try next?
Is the coding wrong? Did it like the picture in this thread shows.
Or is it my mobile?
What's your opinion?
      08-05-2018, 08:04 PM   #65
alex87
Mexico
Drives: Blue M240i 2017
HU_NBT_EVO
Originally Posted by Gabrola View Post
HU_NBT_EVO
3000 > ENT_MIRACAST = aktiv
Help please.. I can't find HU_NBT_EVO.. maybe my car is not equipped with it?
Maybe different name? Thanks!
Car: m240i 2017 (Mexico)
EDIT: I went in HU_NBT2, and follow the instructions above.. now it works.. wow! thanks!
      08-27-2018, 10:04 AM   #66
BJM2018
Drives: 2018 M2 DCT
Dont think this works with my Iphone on my 18 M2 stock as I dont see it in the Idrive menu, would it work if coded?
