How do you protect your front bumper from curb or stopper |
01-06-2016, 08:03 PM | #23 | |
Rep 115
01-07-2016, 06:28 AM | #24 |
Rep 42
Just FYI, i have contacted bimmertech and I will have to purchase front camera retro fit unit and the multimedia unit total about 500 and leave some change.
They said every normal car audio shop would be able to do the job. Does anyone knows any shop in Los Angeles have installed bimmertech unit around westside ? I would love to show you guys how well the front camera work but not sure where to go to install it. i think the installation is beyond my ability and also not worth my time to ticker around. Please let me know if you know any shop, thanks. |
01-07-2016, 01:18 PM | #25 | |
Rep 95
Regretfully pain on most cars these days is crap. Its a combination of paint and environmental agencies. The cars I had in the 80s/90s had bomb proof paint until the EPA went nuts... |
01-07-2016, 03:25 PM | #26 |
Rep 3,523
4 corners
When you drive a car a driver Should know where all 4 corners of your car are.
01-07-2016, 03:58 PM | #27 |
Rep 115
Both my 2005 xterra and my 2010 camaro have far better paint. This car's paint comes off if you look at it funny, its just sad.
01-07-2016, 04:26 PM | #28 | |
Rep 721
01-09-2016, 11:01 AM | #29 | |
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
01-11-2016, 11:51 AM | #31 |
Rep 3,843
01-11-2016, 02:04 PM | #32 | |
Rep 757
I see it everyday with brand new Benz, BMWs, Audis, etc. |
01-11-2016, 07:22 PM | #33 |
Rep 42
so at the end, it just coast too much to get a front camera install.
the set of bimmer tech cost close to $500 USD and not to mention shipping and installing. the quote i got to install was 200 to 300 and i would consider 300 because it is not a simple plug and play, many parts have to be taken apart and wire have to be run through the car than re-install all parts back that was taken off for installation. i estimate around $800 on a safe bet but that is just too much. so i decided not to spend this money. I have been testing out the front sensor and it does work but just not really all that accurate. For stoppers in parking lot, it would detect it in a split sec than disappear. Now to try to detect that stopper, a few time i went in the spot very slow and to catch that stopper showing on sensor, it worked, when i go slow i see it pop up and i stop and went out the car to check, as showing yellow almost to red on the sensor screen, the stopper was about 15" away to the bumper itself, after i knew how far i went in just a bit more about 6" away to the stopper but you would not see it on the sensor anymore. same as concrete curb, if you go head in in front of a store, just go slow, it would detect it. at the end of the day $800 bucks is not worth for its function that i can simply put some effort and try out to get it right. but if its cheaper, i would probably do it just because..... Thanks for everyone's help.....I just need to get use to this car. |
01-12-2016, 09:19 AM | #34 |
Rep 2,067
When parking in a spot with a curb in front, I always press the button to engage the front parking sensors and then drive in slowly and stop when the yellow band starts to turn red and the beeping start. At that point you're still about 1.5 feet from the front of the curb.
2019 X2
01-12-2016, 11:27 AM | #35 | |
Rep 757
1.5feet is a pretty big buffer. Guess if I were you I'd get to the beeps and then move another 6-12inchs then stop. |
01-12-2016, 01:58 PM | #36 | |
Rep 2,067
The 2er is sufficiently short so that even if you're 18" from a curb, your ass-end isn't sticking out any further then most full sized vehicles.
2019 X2
01-12-2016, 04:48 PM | #37 |
Rep 757
01-18-2016, 12:20 PM | #39 |
Rep 892
The front sensors included with the Driver Assist Package work really well as far as I'm concerned, but you have to get used to them. I find that they will detect a low curb from 3 to 5 feet away, but as you get closer, the sensors will go over the curb and no longer detect it. With experimentation you should be able to turn the camera/sensors on before you get say 5 feet from the curb. The sensors should detect it, and if you stop when the visual indicator is flashing red, you should be good.
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
01-18-2016, 12:33 PM | #40 |
Rep 205
Do any of the BMW models come with a front view camera? I love my Bimmertech Front View Camera. I originally was planning on getting their rear-view camera and then realized I could package the front view camera with it. It was pricey but has come in handy so many times in parking garages, parking lots, street parking, and driveways. IMHO, just like the rear view camera, once you have used it, you don't want a car without it.
01-18-2016, 12:52 PM | #41 |
Rep 886
"Any"? Yes.
2-series? No.
01-18-2016, 06:02 PM | #42 |
Rep 1,227
This is precisely why I back into every parking spot no matter where I am. Not only can you use your rear-view camera to park exactly how you want, your rear bumper is much higher than your front bumper so you can pull in farther and avoid people on your sides hitting you when pulling in an out. It's also way easier to pull out of spots when you've backed in, I don't understand why more people don't do this. Can anyone name an advantage to pulling in vs. backing in?
01-27-2016, 07:10 AM | #43 |
Rep 886
Scrolling through the Settings menu today and I saw an entry for "Parking". There's a checkbox in there to turn the sensors on automatically if you're at low speed. This may be the reason for the differences people see in the parking sensor behavior.
01-27-2016, 07:47 AM | #44 |
El Capitán
521
Rep 2,652
I reverse into as many parking spots as possible.
The rear sits higher than the front and I would rather scrap my exhaust than crack my front bumper. Always reverse in... |
