2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning mpe exhaust mod
      02-22-2020, 11:29 AM   #1
BelugaaF22
BelugaaF22's Avatar
Drives: 228i N20
mpe exhaust mod
hi all
so I've looked up the more exhaust mod where you disconnect the valve to keep the flap open and when I looked down at the pipe, I see the flap opened so I disconnected it before starting the car. but I notice usually when I'm in sport and the flap is opened, the exhaust produces more burbles and over run but after doing this mod, it basically sounds the same in comfort as if I didn't do the mod.. any ideas? thanks in advance
      02-27-2020, 07:31 AM   #2
ngl
ngl's Avatar
118
Drives: BMW 228i
Scan the car, you most likely have an error for the valve so probably the car acts as if it's always in comfort because you are not supposed to open the valves while the car is stationary ( noise and emissions standards ).
Best is to leave the valve connected and remove the fixing bow ( see piece 9 ) and then lock the valve into open position.
The ECU will still try to open / close, but since the actuator is not connected to the valve, nothing will happen.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger
Maynard3804.50
      02-27-2020, 09:03 AM   #3
KennyFSU
KennyFSU's Avatar
1103
Drives: Lexus RC F
I just pulled a fuse in the trunk while in Sport mode to keep the valve open.
Estoril Blue E36M3
Mineral Grey M235ix/12.02 @ 115
Ultra White Lexus RC F
      02-28-2020, 10:06 AM   #4
BelugaaF22
BelugaaF22's Avatar
Drives: 228i N20
would any of these methods throw codes? where is the fuse in the trunk located?
      02-28-2020, 10:27 AM   #5
KennyFSU
KennyFSU's Avatar
1103
Drives: Lexus RC F
No code, it's fuse #146, make sure it's in Sport mode so the valve is open.
Estoril Blue E36M3
      02-29-2020, 10:59 AM   #6
ngl
ngl's Avatar
118
Drives: BMW 228i
Stock cars should not open valve on engine idle, regardless of mode ( normal / sport / sport+ ). If it does you would hear it doing it, it's loud enough to hear it with the door open. Valve opens only on engine load, there is a map in the ECU telling it at what engine load / rpm it should open, so I can't see how pulling the fuse could work, unless you pull it while reving the engine hard.
If you use BM3, there is an menu to control valve, you can manually open / close it. The same is true if you use a data display like AKMotion DataDisplay.
Search this Thread:
