2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Where/how to fill coolant
      01-17-2020, 01:57 PM   #1
jloco
Drives: 2020 X3M
2020 BMW X3M  [0.00]
I had to replace a punctured radiator for a 2016 m235 xdrive auto. I have to replace the coolant.
From what I have seen online, it looks like one would need to use a vacuum tool to replace the coolant and flush the system? If so, where do I connect the vacuum tool?
Or, could you just keep filling the reservoir then go through the bleed process?
Can anyone chime in on this? I appreciate it!
      01-17-2020, 04:37 PM   #2
overcoil
Drives: M235i 6spd
https://www.newtis.info/tisv2/a/en/f...ls/17-cooling/
is this applicable to the 235 ?
      01-20-2020, 11:24 AM   #3
jloco
Drives: 2020 X3M
2020 BMW X3M  [0.00]
So, I basically used the vacuum tool to refill my coolant and check for leaks and it worked like a charm hooking it up to the coolant reservoir. I then proceeded to do the car's bleed process that took about 12 minutes. Looks like everything is good.
      01-20-2020, 12:20 PM   #4
overcoil
Drives: M235i 6spd
which vacuum tool ?
      01-21-2020, 10:33 AM   #5
jloco
Drives: 2020 X3M
2020 BMW X3M  [0.00]
https://www.ecstuning.com/b-schwaben.../024948sch01a/
Schwaben Coolant Vacuum Fill Tool
Mfg Part #
024948SCH01A
overcoil3073.50
