2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Anyone do an oil change yet?
      07-16-2014, 02:35 PM   #1
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
I know oil changes are all the same but has anyone done a diy oil change yet? Any trouble getting the m235 on ramps?
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      07-16-2014, 02:51 PM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
I did one last week....
Ya I had to do some ramp extensions with some home depot 8x2 cause the bumper will not clear the ramp... you might be able to see it in the pic behind the metal ramp
Also got an adapter to be able to remove the oil filter
http://www.pepboys.com/product/detai...ilter_wrenches
      07-16-2014, 02:57 PM   #3
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Looking good, i have the rhino ramps and have the woods ready...also already have the oil filter cap from previous e90 n52. Hope its the same size and if not I'll just bust out the strap wrenches
2006 325xi (Sold)
      07-16-2014, 03:02 PM   #4
pikcachu
pikcachu's Avatar
1399
just make sure if your car is in a down hill you put the ramps in the opposite way... so that the lift from the front ramps compensate a bit with the down hill so it's as level as posible...
my garage is downhill towards the rear of the car and when i lifted the front was even more pronounced so then when there is very little oil left it will start moving towards the rear of the oil pan and dripping some oil into the cloth cover of the undercarriage...
      08-21-2014, 09:47 AM   #5
ketema
Drives: 2015 M235i
Anyway to use an oil extractor with this car? I just ordered one and something the salesman said stood out to me: "There is not even a dipstick."
      08-21-2014, 09:59 AM   #6
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Yup no dipstck, have to drain from under the car
2006 325xi (Sold)
      09-30-2014, 02:41 PM   #7
obliterate
obliterate's Avatar
13
Drives: 2015 EB M235i
So the "CTA Ritefit 86mm x 16 Oil Filter Cap Wrench" does fit the oil filter cap of N55? It's great that I don't need to buy a $24 BMW one!
      09-30-2014, 02:51 PM   #8
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
# of quarts?
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      09-30-2014, 03:21 PM   #9
overcoil
Drives: M235i 6spd
I believe 6.5 quarts into the sump after drain then use the remainder to correct for any corrections the computerized dash oil level exhibits.
      09-30-2014, 04:12 PM   #10
pikcachu
pikcachu's Avatar
1399
ya i got that one for $6 i think
and 7 quarts
      09-30-2014, 08:53 PM   #11
obliterate
obliterate's Avatar
13
and 7 quarts
Thank you!! Quoting from the other post, DUDE, YOU ARE THE MOST HELPFUL FORUM MEMBER!!!
      09-30-2014, 10:43 PM   #12
pikcachu
pikcachu's Avatar
1399
lol thanks
      10-01-2014, 04:03 PM   #13
overcoil
Drives: M235i 6spd
Did first oil change on 235. Unfortunately I could not get car onto Petersen Utra-Ramps with extension without rubbing the flexi-flap in front of the front tires. Resorted to my 3.5 ton Arcan garage jack (Costco) and a ReverseLogic pad (lifting point) tool.
I lifted at the drivers side front jack-point and was able to get enough height to work the flap door and drain plug. I was also able to lower the car to 'level' while draining to get a good drain.
The one tool I purchased for the job that was indispensable the Form-A-Funnel [small size (green object in picture)] that routed the draining oil over the flap door into a basin.
The factory drain plug gasket was silver and blended onto the drain plug bolt - so be sure to pry that off. The OEM filter kit came with a copper drain plug. And the actual factory filter was installed with the writing on the filter facing upward into the plastic filter cap. I purchased a OEM filter socket made in Switzerland. Used a 27mm socket to turn the filter cap.
I put in around 6.6 quarts ( let drain for about thirty-minutes ) and after a short 1.8 mile drive car showed oil at 'MAX' level with a 'Oil O.K.' reading.
And when under the car I placed a floor jack and spare tire strategically though not touching anything and I used two wheel chocks on the passenger side front & rear. The next time I do a thirty-minute drive I will chk oil level - the system needs that thirty minute drive for the iDrive oil level reading to be accurate/stated in manual.
      10-01-2014, 05:38 PM   #14
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Any part # for the filter
I believe is the same as the n52/54/55
2006 325xi (Sold)
      10-01-2014, 05:47 PM   #15
overcoil
Drives: M235i 6spd
From my invoice :Part # 83300493936* Genuine BMW N52/54/55 Oil Filter Cap Removal Wrench
But I'll chk the actual part when I get home. Some post mentioned how some cheaper oil filter sockets had deformed over time making use difficult, so decided to go with the OEM.
      10-01-2014, 06:01 PM   #16
pikcachu
pikcachu's Avatar
1399
i think he is asking for the filter part # not the removal tool
      10-01-2014, 06:11 PM   #17
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Yea haha
2006 325xi (Sold)
      10-01-2014, 06:17 PM   #18
pikcachu
pikcachu's Avatar
1399
I did mine and it was the same as the regular n55 whatever that one is
http://www.fcpeuro.com/products/bmw-...ilter-041-8195
      10-01-2014, 06:24 PM   #19
overcoil
Drives: M235i 6spd
The oil filter part# 11 42 7 566 327
Includes: Filter, copper drain plug gasket, two rubber oil cap seals.
      10-01-2014, 06:49 PM   #20
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Great thanks for the confirm
So these are the same for all N52/N54/N55 engine
I get the filters from Mann HU816x (Mann is actually the oem supplier for these filters) and they can be found at around $8-9 (usd)
The filter wrench can be found on amazon for $18 (AST V410)
Oil (mobil 1 0w-40 european formula) can be found at Walmart for $23 (5 qt) jug
As for ramps, i got myself some race ramps but if you have clearance issues, use some 4x2 to give you that extra 2"
2006 325xi (Sold)
      10-01-2014, 10:59 PM   #21
pikcachu
pikcachu's Avatar
1399
You can use this instead http://www.pepboys.com/product/detai...nlyStore=false
it's $6 instead of $28 it's made of metal so no issues wearing off
I rather use BMW oil so it's the same oil they use for the free oil changes....
http://www.fcpeuro.com/products/bmw-...-oilchgkit6327
but I don't really think using Mobil 1 would make any harm...but I rather just use the exact same brand...
      10-02-2014, 06:06 AM   #22
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
M1 0w-40 is LL01 approve
Used it 9 years on the e90
$6 is cheap metal vs aluminum and you have to add shipping no? Those wrench might not apply even pressure when you torque it...result in premature oil filter housing gasket wear. Just my 2 cents
But whatever works
2006 325xi (Sold)
Search this Thread:
