04-21-2020, 06:42 PM | #1 |
Rep 85
Asking something REALLY different
Ok, lots of different options given, but has anyone gone with oversize speakers in custom housings?
On my e30 vert, had very poor audio. I put 6.5" reasonably priced coaxial speakers (Polk) in front and back, running on amp, with an underseat powered subwoofer. Sound was plenty good with tons of clear volume for driving top down. Smaller speakers just couldn't produce big clear sound, per the R3v audio gurus. Loved the stereo in the e30 10x more than my HK 2 series. On the e30 fronts, I made custom housings in the lower doors. In the rear, I just used a surface spacer 1" ring and the magnet protruded into where the old small speakers were. Total price without head unit was about $400. My question is: Will the current HK amp drive 4-6.5" speakers effectively without having to upgrade? I already have ASD coded off and will unhook the center soon. Project will most likely be this summer when I have more time. I am fully willing to chop up my car a bit for clear cruising music. Own my 2015 M235i outright and not planning on selling it. |
04-22-2020, 09:01 AM | #2 |
Rep 242
So there's no cut and dry answer here because it all depends.
But the HK amp will certainly power the speakers with no trouble you just might not like what you are hearing. If you are going the expense to custom the drivers and fitment, you may as well go the expense to get a clean signal from the head unit and amplify that separately. Just leave all the HK stuff in place and run a new setup in parallel. Seth |
04-22-2020, 06:34 PM | #3 |
Rep 85
Thank you Seth, appreciate the input.
Anyone have guidance to where to find the wiring diagram, access points for doing so DIY? Or a connector, Crutchfield style? I wouldn't mind adding a seperate, reasonably priced amp. Not looking to drop 1k on this project. I unhooked the center last night. WOW! That makes more of a difference than I ever imagined. That mixed center speaker just turned stereo separation into "mush." All the comments are correct. ASD off and center channel delete are two of the best audio upgrades for the car (at any cost under 4 figures.) |
04-24-2020, 01:02 PM | #4 |
Rep 242
Since you already did all the speakers and wiring, that number might be achievable. You can really get any 4 channel amp you like for the 'mains' and any mono amp for the subs, or do what many people do and get a 6 channel amp for all 6 speakers.
[editing since I put wrong info here] Seth Last edited by sethwas; 05-08-2020 at 11:39 AM.. |
04-25-2020, 11:00 AM | #6 |
Rep 1,264
Try www.newtis.info. Enter the last 7 characters of the car’s VIN. Hit enter and bookmark the page. The wiring diagrams are there.
I just finished upgrading my 2018 M240i. Here’s the link: https://www.bimmerforums.com/forum/s...-MATCH-7UP-amp |
04-26-2020, 11:34 AM | #7 | |
Rep 242
05-01-2020, 10:54 AM | #9 | |
Rep 242
'base' which is like 2 speakers running off head unit 'hifi' which is 4 paper cone speakers (2 door/2 rear deck not counting subs) 'hk' which adds tweeters and a different amp. Seth |
Maynard3848.00 |
05-01-2020, 05:32 PM | #10 |
Rep 85
Update: TechnicPNP harness works great for adding whatever traditional amplifier you choose on the HK sound system. I used the Soundstream Picasso Nano PN5.640D 5 channel amp.
05-01-2020, 05:37 PM | #11 |
Rep 85
My next idea is to custom fit a small box in the pass through area when the seat folds down. Will put a pair of 6.5" drivers in there and not try to oversize the side speakers. Will just add another 2 channel amp to drive them with a remote switch to kill it when I have rear passengers (rarely, but it happens.) Will be able to just fold the seat up to hide them when parked with the top down.
05-02-2020, 05:01 PM | #12 |
Rep 85
Rainy day. Got some projects done. This should fix that missing middle range and add some volume when the top is down on the freeway. Polk DB+ 6.5" in fully enclosed (separated L and R box.)
Still need to finish adding a two channel amp to drive these and make an automatic cut off switch for the amp. When the seatbacks fold up, the amp wil turn off. Now the wifey wants the bathroom painted. Should have stayed in the garage. |
05-03-2020, 04:23 PM | #13 |
Rep 85
Fronts
I installed the front Polk DB+ 4" today. Used some 3d ABS printed adapters i found on Thingiverse. No issues, sound great. I left the OEM tweeters in, but they are non-functional.
System is good now. I have another pair of DB+ 4" Polks for the back, but may or may not ever get around to putting them in. The 6.5s in the back are fantastic at producing mid-range. This is a convertible, so not worried about perfect concert hall, etc. Mainly need very loud tight music for top down cruising (98% of my driving, as the car is a garage queen, not a daily.) Last edited by 2breezy; 05-03-2020 at 04:24 PM.. Reason: add pics |
05-03-2020, 04:35 PM | #14 |
Rep 85
Port?
I constructed the box for the 6.5s with seperate L/R enclosures each measuring about .25 cubic ft of interior volume. Using an online port calculator this provides a .5" port length for a 1" port.
Should i port this box? (1 each on L/R sides.) Or leave it as a sealed unit. I don't know hardcore audio, so I am wondering if my sealed small volume box (vert top, so not willing to sacrifice trunk space.) is too restrictive for these speakers. As per last post. Nice reasonably loud cruising music is the goal. Tastes are varied, but Wilco, Sublime and alt rock on the HD radio. I can easily 3d print whatever size/shape port I need. Assuming port firing forward into the car? |
05-04-2020, 10:24 PM | #16 |
Rep 85
Port
Installed a 20mm x 20mm deep port on one speaker. Tested both. Definitely need ports on a small enclosure box like this. The sealed small volume box was inhibiting cone travel. Ported both sides of the enclosure.
05-07-2020, 09:47 AM | #17 | |
Rep 1,264
05-08-2020, 11:38 AM | #18 | |
Rep 242
I'll edit my posts so it's not confusing. Seth |
