2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes The brake pad thread
      01-29-2022, 12:05 PM   #353
Stefo
Drives: BMW M240 xi 2017
Akebono EUR1656 Rear Ceramic pads
I installed the Akebono EUR1656 Rear Ceramic pads on my M240xi about 3 months ago, and about 1 month ago when going in reverse the pads started making a horrible squeaking noise. It happens more when cold backing out of my driveway and it literally wakes up my neighbors. No noise when going forward or when breaks are hot. Live in NJ, so very cold the past month.
I had applied brake quiet on the back of the pads when I installed them, as well as the special brake grease on the moving parts.
Any suggestions?
I am now hesitant installing Akebono's on the front.
      03-06-2022, 12:13 PM   #354
Stefo
A quick update on the Akebono brakes squeaking problem.
Taken brakes apart again and re-applied a generous amount of brake grease on the back/sides of the pads, spring bracket and pins. It's been about 1 month and no squeaking, even in reverse.
I probably did not apply enough grease the first time, so be generous to prevent this.
PeterWT253.50
      03-19-2023, 04:48 PM   #355
ironxcross
Drives: 2022 X3 M40i/2016 M235xi
Originally Posted by bryan_G01 View Post
same, part numbers are on the sheet on 1st page.
Going to put yellows on the x3 m40.
Did you end up doing so, and if yes, are you happy with them? Looking to do the same myself. Ty!
      04-17-2023, 01:14 PM   #356
dirty_denim86
Drives: 2018 M240ix
Just read through the thread very helpful. I was leaning towards the EBC RedStuff for my 2018 M240ix but I'm trying to figure out which Rotors to go with.
EBC recommends their Ultimax Slotted Rotors or Sport Rotors with the EBC RedStuff brake pads but I'm open to recommendations. Vehicle is used for street use only no track time.
Here is a link to the EBC Front Brake Kit with USR:
https://www.tdotperformance.ca/ebc-b...oiNDAyMzA4Ijt9
      04-19-2023, 07:50 PM   #357
ggggbmw
Drives: 2017 M2 Manual
It's hard to beat the beat the performance, weight, and cost of the OEM 2-piece plain rotors. They are bulletproof, and will provide the quietest and best braking performance on street.
Anything slotted/drilled/dimpled is more of a cosmetic affectation for street use. And unless you have upgraded everything else are rarely of much benefit on track. They can look cool though.
      04-24-2023, 02:01 PM   #358
LanceM26
LanceM26's Avatar
Drives: BMW M235i, BMW M240iX
Tested EBC blue on track. They're trash
      04-24-2023, 02:11 PM   #359
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
How so?
      04-24-2023, 02:14 PM   #360
LanceM26
LanceM26's Avatar
Originally Posted by dradernh View Post
How so?
For the price (a bit less than proper hawk DTC pads) I didn’t like them.
Takes too long to bed
The front pads were cracked down the middle (they were brand new)
I can see the blues as being a decent dual duty pad, but for advanced track… I wouldn’t recommend it.
I did however get my PB with Ventus RS4 and EBC blues before they shit the bed
dradernh4413.00
      04-24-2023, 04:39 PM   #361
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
I once read the EBC bed-in instructions. I'd seen instructions like those before and have always stayed away from pads requiring an involved bed-in routine.
My experience with Hawks has always been the opposite: drop them in the calipers, warm them up for a couple of laps, and then they're good to run hard.
LanceM26115.50
      04-24-2023, 04:59 PM   #362
LanceM26
LanceM26's Avatar
I ideally want GLOC pads but FCP doesn’t stock them. So I will just go to hawk DTC 70.
Even Ferodo… they only have ds2500 not even 1.11
dradernh4413.00
      04-24-2023, 11:30 PM   #363
aerobod
aerobod's Avatar
3626
My son recently purchased the DS1.11 for the M240i from Demon Tweeks in the UK, ended up being the cheapest option for a suitable track pad, including shipping and duty to Calgary.
Should be FCP4611W Front (https://www.demon-tweeks.com/ferodo-...s-ferfcp4611w/) and FCP4663W Rear (https://www.demon-tweeks.com/ferodo-...s-ferfcp4663w/)
LanceM26115.50
      04-24-2023, 11:31 PM   #364
LanceM26
LanceM26's Avatar
Should be FCP4611W Front (https://www.demon-tweeks.com/ferodo-...-ferfcp4611w/) and FCP4663W Rear (https://www.demon-tweeks.com/ferodo-...-ferfcp4663w/)
That’s great, I just like the option of lifetime replacement from fcp euro.
      05-26-2023, 03:54 PM   #365
LanceM26
LanceM26's Avatar
I've made an update to the the sheet:
https://docs.google.com/spreadsheets...JUCylV/pubhtml
      06-13-2023, 09:48 PM   #366
ggggbmw
G-Loc Initial Review
I just completed my first track weekend on G-Loc brake pads. Overall I am quite happy with them.
I am using the R12 on the front, and R10 on the rear.
Front: GP1609A R12
Back: GP1656 R10
I've previously run PFC08 and Ferodo DS1.11. I was thinking I might want the G-Loc R16 to more closely match those, but I'm glad I didn't. The R12/R10 have a lot of initial bite and torque. More than the PFC08. I think the R16 would be overkill for the narrow-ish 200TW tires I use. The R16 would probably only be appropriate for slicks or really wide DOT tires.
I run a square setup, and the G-Loc recommended R12 front / R10 rear provides a nice bit of brake bias to help keep the rear under control. I never felt the rear squirm like I occasionally did with matching PFC08 front/rear. If you run staggered tires, a matched R12/R12 might work better.
Initial street driving I was amazed by the torque, especially after some bedding in. I was also amazed by the incredible screeching of these pads. They were LOUD. I usually keep my track pads on all summer, but I was seriously considering swapping the OEM streets back on because the noise was worse than any other track pad I've used. I'm really glad that after a day at the track, and a lot of pad transfer to the discs, they've actually gotten quiet. There are still a few squeaks and chirps, but at this point they are quieter than most track pads. I'm going to be really curious how that changes as street driving scrubs the discs.
On the track they were great. Effectively no fade over 3 days, and very little wear. BIR has one killer braking zone, and several other high brake spots, and is not the easiest on pads. The braking force was very easy to control. A quick onset of torque that was linear with pedal pressure, and easy to trail brake. They had a lot more sensitive feel than the PFC08 I've used the last two years. They aren't quite as firm as the DS1.11, but are similar in their feel and control.
I cut nearly two seconds off my personal best lap time this weekend, and I think part of that was the superior trail braking feel I had with the G-Loc over the PFC08 I ran last year. Everything else on the car was the same, including the same tires from last year.
I'm going to Road America in two weeks. That is a tough course for brakes. I'll add another review after that weekend when I see how they do there.
