07-02-2019, 03:48 PM | #1 |
Rep 60
B58 Low Coolant ... again!
My car has nearly 48k miles on it and I have had the coolant go below the MIN level twice. The first time it happened was close to 35k. I got the low coolant warning and went to the nearest BWM dealership where they refilled both reservoirs. There was actually even a designated line for fluid top off at this dealership in southern california.
I had the car inspected at another dealership when I got back home and they ran a pressure test that showed no issues. I was informed to keep an eye on the level and to take it back in if it happened again. Checked the coolant earlier this week and noticed it was below the MIN line on the main tank only. The turbo coolant level was still fine, and I did not get a low warning this time around. Took it in this morning and ran a pressure test again. Results came back good and they topped it off. They said that there was probably a wrong mix of coolant/water which caused evaporation. When I had it filled at the first dealership at 35k, they only added coolant without any water. I don't know if this affected anything or made a difference. I haven't seen any leaks in my garage and also asked the dealer to check the radiator for any damage like others had reported. I have quite a few miles on my car so I wanted to just write this up so that we can all keep an eye out to see if this is going to be an ongoing thing with the b58. |
07-02-2019, 08:23 PM | #2 |
Rep 1,365
Got my first warning at 19.5k and topped it off. Currently close to 38k, so I plan to check it soon.
07-03-2019, 12:26 PM | #3 |
Rep 1,227
I've had to top off my B58's main coolant tank (not the smaller intercooler coolant tank) several times. I had it checked at the dealer after the first incident for a faulty cap but they said they didn't find anything wrong with it.
07-03-2019, 12:43 PM | #4 |
Rep 5,478
Perhaps B58 owners should start checking their intake manifolds for tiny coolant leaks like some M3/M4 owners are experiencing?
https://f80.bimmerpost.com/forums/sh....php?t=1570544
07-03-2019, 02:54 PM | #5 |
Rep 400
My tank was almost empty after 7~8k miles. (no warning)
Topped off and level is not going down a lot but still losing some. The coolant level went from Max to Min in about 10k miles which is not much. Topped off again (3~4 oz). It could be the leaky cap. I am checking the coolant level every few month. |
07-03-2019, 02:55 PM | #6 | |
Rep 400
The intercooler is cooled by secondary coolant circuit. (which hasn't dropped a bit) |
07-04-2019, 08:17 AM | #7 |
Rep 1,115
Drives: 2015 BMW M235i
I must be crazy but I'm pretty sure there is nothing ok about a motor ingesting or losing coolant mysteriously. Dealers saying it's fine makes me second guess their knowledge.
07-04-2019, 08:34 AM | #8 |
Rep 28
I agree. Nothing normal about that degree of coolant loss. The dealers are just being lazy and don't want to get into a potentially expensive repair that isn't easy to diagnose.
07-04-2019, 09:32 AM | #9 | |
Rep 1,115
07-04-2019, 10:25 AM | #10 | |
Rep 60
In some ways, I'm glad that I'm not the only one experiencing this. But, I also wish that we would get some clarity on why this is happening in the first place. |
07-04-2019, 11:01 AM | #11 |
Rep 368
Drives: 218i Coupe
Garage List 2016 BMW 218i Coupe [8.00]
2006 BMW Z4 M Coupe [9.00] 1975 BMW 2002 [5.50] 1985 BMW 635 CSi [5.00] 1974 BMW Alpina A2 ... [10.00] 2000 BMW Z3 Coupe [8.83] 1990 BMW 316i [8.00] 1993 BMW 850Ci [8.33] 2020 BMW X2 [5.25] 1994 BMW 318i [0.00] 2018 BMW X3 [0.00] |
I looked at BMW’s internal system, PuMA, for you guys and this is what came up;
PuMA measure B38, B46, B48, B58, XB1H - Check Control message: Top up coolant 63482185-05 Complaint: Check Control message (ID 166): Top up coolant The coolant level in the coolant expansion tank of the high-temperature coolant circuit is below the minimum. There may also be traces of coolant in the engine compartment or where the vehicle is parked. Cause There are various possible causes: The cooling system was not sufficiently bled initially. While driving the cooling system bleeds and as a result the coolant level drops in the coolant expansion tank. The cooling system is leaking (impermissible coolant loss). Measure +++ Revision to the previous version of the PuMA measure: Note: Bleeder screw: Observe tightening torque of 2.5 Nm. +++ In the event of a customer complaint, proceed as follows: Attention: Only perform the following work on cooled-down components. 1) Check coolant circuit for watertightness: See repair Instructions 17 00 009. Check the high-temperature coolant circuit for watertightness using test for loss of pressure. Test pressure of cooling system (excess pressure): 1.5 bar test period: 10 minutes 2) Observe pressure: No pressure drop: Continue with point 4. Pressure drop present: Continue with point 3. 3) Search for leak. Check coolant pump. The coolant pump has a reservoir. During engine operation the slide ring seal of the coolant pump needs to be lubricated. The coolant required for lubrication is collected in the reservoir. Slight traces of coolant could be visible on the lid of the reservoir. Slight traces of coolant on lid of reservoir (see attachment, figure 1): Clean the lid. Check if coolant leaks again at the lid if excess pressure of 1.5 bar is applied. - If coolant is leaking: Replace coolant pump. - No coolant leaking: Do not replace coolant pump. Search for leak and repair accordingly. Excessive traces of coolant on lid of reservoir (see attachment, figure 2 and 3): Replace coolant pump. After repairing the leak: Bleed cooling system and check for watertightness: See repair Instructions 17 00 039. Note: Bleeder screw: Observe tightening torque of 2.5 Nm. 4) Release pressure: Adjust the filling level in the coolant expansion tank of the high-temperature coolant circuit. In doing so, it is imperative to follow repair instructions 17 00 039. The filling level in the coolant expansion tank is adjusted either to the maximum mark or 200 ml above it, depending on the model. Notes on factory filling of high-temperature coolant circuit: The initial coolant circuit capacity of the high-temperature coolant circuit was already optimised in the vehicle factories. The introduction dates are: F20, F21, F22, F23, F30, F31, F32, F33, F34, F35, F36: 01 September 2017 G11, G12: 5 June 2018 G30, G31, G32: 01 February 2019 G38: as of series launch Invoicing: Processing and reimbursement must be conducted according to current warranty conditions. In case of defective cooling system bleeding, use the following defect code. Recommended defect code for GWK cases: 17 11 00 72 00 Use the following defect code for a leaking coolant pump. Recommended defect code for GWK cases: 11 51 07 48 00 For other leakages. Obtain the corresponding defect code from the "Commercial Service Data (KSD)". Validity information Model series:[F30, F21, F32, G31, F31, F20, G30, F23, G11, F34, F33, G32, F22, F36, F35, G12, G38] Engine range:[B58M, B48M, B46O, B48O, XB1H, B38M] Body style:[ALL] Fault codes:[] Production period:- |
07-04-2019, 01:32 PM | #12 | |
Rep 400
Manufacturer has all the warranty data and dealers are instructed by manufacturer. For B58 coolant 'leak' issue, I think initial big drop in coolant level was improper fill from the factory. (mine emptied the tank in 8k miles while my wife's is still fine at 4k miles) However, mine keeps 'leaking' small amount. It can be coolant tank cap leak or leaking somewhere internally. (no visible coolant drops on the garage floor) There are only so many it can leak internally. Engine block/head (unlikely with closed deck), oil cooler (oil level will go up), trans cooler, turbo....that's about it I hope it's not the turbo internal leak. |
07-04-2019, 05:44 PM | #13 | |
Rep 60
I had read another post about replacing the turbo after bmw had inspected his car. Didn't hear anymore details about it though. |
07-04-2019, 05:45 PM | #14 | |
Rep 60
Thanks for posting this. I'll have the dealer look specifically at the coolant pump the next time this happens. I know they ran the pressure twice, so this will be another thing to ask for in the future. |
07-04-2019, 07:20 PM | #15 |
Rep 3,611
Was that on the B58, or the N55?
07-04-2019, 07:52 PM | #16 |
Just Copacetic!
178
Rep 616
I have the B48 engine and have topped it up twice from just below the minimum level, car has 8K miles. Our other car has the N20 engine and it has not dropped at all in 28K miles. Don’t know why BMW went to the all black opaque expansion tank with the B-engines, unlike the N-engines which have a translucent tank which makes it much easier to see without having to remove the filler cap.
'01 X5 3.0 AlpWhite
07-04-2019, 10:12 PM | #17 |
Rep 60
An owner named bayern68 reported a new turbo under warranty with his B58 (2016 production). This actually wasn't the same user I found originally when I said someone got a new turbo, but when I searched again I found his post.
https://f30.bimmerpost.com/forums/showthread.php?t=1324221&page=5 |
dradernh4818.00 |
07-06-2019, 10:21 AM | #18 |
Rep 133
Ill be watching this thread as im about to buy a 240i.. i know the b58 has a different block design and that keeping the engine cool with the closed deck is also different. im sure theres something bmw hasnt admitted yet.. maybe the type of coolant? id check for leaks too.. coolant just burning off that fast seems strange
07-06-2019, 12:08 PM | #19 | |
Rep 60
07-06-2019, 01:30 PM | #20 | |
Rep 400
Air pocket in the cooling system will drop the coolant level after driven for a while. |
07-06-2019, 02:28 PM | #21 |
Rep 1,237
Drives: 2015 M235ix
I had a low coolant incident once with my 235 a couple of years ago. My daughter was driving and she had the sense to address the problem. Nothing since. The car now has almost 40000 miles on it.
Knock wood!! |
07-07-2019, 12:13 AM | #22 | |
Rep 60
So is there a way to see if these are really underfilled from delivery then? How does someone monitor their levels to make sure it's adequately filled? |
