09-15-2016, 02:27 AM | #45 |
Rep 197
I've ordered this box aswell. Can we get a video of when you do a parallel parking and also one where you switch to the screen mirroring?
Edit: Trying to order a camera now but can't find the one you've listed. Anything i need to think about in terms of resolution/pal/ntsc/other compatibility issues? BTW my car is from europe |
09-15-2016, 02:29 PM | #46 | |
Rep 480
HMDI Switching
The actual screen has no vertical lines. It's the video camera.
Alpine White BMW 228i (Stripper Special with Lighting Package as the ONLY option), HD-LINK IW06B-N23 Backup Camera & HDMI Input, Technic ASD Removal Harness (Wire Nut Mod), Technic Hifi Harness, Focal FDP 6.900, Hertz Energy ECX 100.5.
09-15-2016, 02:36 PM | #47 | |
Rep 480
Parallel Parking
09-15-2016, 02:39 PM | #48 | |
Rep 480
The AV Box is NTSC
10-14-2016, 12:56 PM | #49 |
Rep 2
thanks a lot for your post on this matter
I'm planning to add a camera to my 228 as you guys did but I have a couple questions on the camera and how to route the power. the cameras I've seen come with a short power cable that is meant to be connected to the rear lights, but from what I understand that setting doesn't work for BMWs. could you guys provide some more detail on how you installed the camera and run the power cable to the AV unit? if you could also provide a link to the sony camera you used, that one seems to have a better resolution that the 15$ one from amazon thanks guys |
10-18-2016, 05:07 PM | #50 | |
Rep 480
Here's the info
The SONY CCD Camera is sold by the vendor of the AV Box. You can't miss it. It's here: http://indiwork.co.kr/shop/parts/camera/k2000-cd/ Good luck!
10-19-2016, 05:53 AM | #51 |
Rep 197
i've done part of this install now, looking for info on how to disassemble the center console without ruining anything so that i can actually hook everything up. The camera install and running the cable to the front is actually VERY simple.
10-19-2016, 09:11 AM | #52 | |
Rep 1,753
10-20-2016, 11:28 AM | #53 |
Rep 480
Easy, Just. . .
Pull the air condition vent toward you and up. It snaps out. The rest is obvious.
10-22-2016, 05:34 PM | #54 |
Rep 197
I've done the complete install and it is working properly besides for 2 minor things.
When i stream the phone image to the screen in landscape, it does not fill up the entire screen. When the rear camera is enabled, it only fills up the right part of the screen, its not centered or anything. Anyone experience these issues? First i thought it was an issue with the dip switches but i'm current running 1 and 3 on which should be the correct setting for my screen. |
10-22-2016, 07:48 PM | #55 | |
Rep 480
This should not happen.
As for the rear view camera you need to set the correct DIP switch values based on the size of your screen. These DIP switch values are No.9 and No. 10.
10-23-2016, 01:12 PM | #56 | |
Rep 197
I have not set the dip switches on 9 and 10, they are both off. I've got the nav screen (8.8" i think) |
10-23-2016, 01:22 PM | #57 | |
Rep 480
Try This
Press Option button for 5 seconds and goto Rear view camera settings. From there you can change the position of the image. Worse come to worse, you can reset the device: Press the Back button for 10 seconds.
10-24-2016, 01:54 AM | #58 | |
Rep 197
Changing the dip switches seems to have changed nothing. I have been able to get full screen working using my laptop. It seems to be a resolution issue when my phone tries to negotiate with the MWDA. I will contact the support about this. |
10-24-2016, 12:23 PM | #59 | |
Rep 480
What Miracast System Are You Using?
10-26-2016, 04:06 AM | #60 |
Rep 197
I've also noticed that the guide lines to not represent the width of the car. I have mailed the support to ask if there is any way of adjusting the width of the guide lines as well as the position of the camera image.
10-26-2016, 05:20 AM | #61 |
Rep 197
I received response from the supplier now and the guide line width is not adjustable =( To get the camera full screen one needs to hold the controller to the right for 2 seconds and it should become full screen.
11-03-2016, 03:45 AM | #62 |
Rep 197
So i've tried getting fullscreen using a cable that was also not possible, seems something in the scaling negotiation just doesn't work. Infact wireless hdmi and using a hdmi cable yielded exactly the same result.
02-02-2017, 07:57 AM | #63 | |
Rep 2
I did the whole installation used the same camera but it seems the camera is set too low so I cannot have a complete view when in reverse. thinking about getting a different camera but don't know if you had the same issue with your 2 series? |
02-07-2017, 08:30 PM | #64 | |
Rep 480
Depends On What You Want
I don't personally like a fish eye style view but a more realistic view. I don't have an issue with rear view since I can see way back further than the OEM camera.
09-22-2017, 11:54 AM | #65 | |
Rep 33
Any help appreciated. |
10-03-2017, 12:00 PM | #66 | |
Rep 480
Return the item. It's defective.
