2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Dr. Strangelove, or How I Learned to Stop Worrying & Live w the Harmon Kardon System
      04-09-2019, 06:21 AM   #793
selmeralto
selmeralto's Avatar
227
Drives: 2021 M2 Competition
A last resort, if you can't get the color coding: you should be able to test this by ear.
Put on a track or two with tight bass lines. Face the rear speakers, sitting in the center of the car. Move your head back and forth slowly. Listen for tight bass and clear location of instruments. Reverse the speaker connections on one speaker only. One of the connection setups should have tighter bass with a firmer sense of the location of instruments. Those two speakers should then be in phase. You might find this test easier by setting the fader control to shut off the front speakers.
Then, setting the fader control back to normal, listen to the whole system for the same parameters, paying attention to spatial location and tightness throughout the system. Then reverse *both* connections in the back, keeping them in phase with each other, and listen for consistent phasing throughout the system. The goal is to have a clean, firm, consistent and spatially defined sound throughout the car, at least as far as that's possible in a small moving vehicle.
      04-09-2019, 10:35 AM   #794
nastypoker
Drives: BMW M235i
Mr Selmeralto, I have just upgraded my HK system with the B100W speakers and tweeters in the front of my car. I also disabled the centre speaker and am waiting on some JBL's to arrive for the rears.
It sounds A LOT better so thank you for your guide on what to do but I still have a problem. Sometimes I get some crackly noises but it is very intermittent and I can't just make it do it by turning the volume up. It seems to happen when listening for a while and then a loud section of music comes on and I will get this very high pitched rustling/crackling noise like someone is crinkling foil but higher pitched. This happened with my HK speakers and I was hoping they were damaged and the new speakers would fix this as well as the generally terrible sound quality but it hasn't.
Any idea on what I can do or check to help solve this issue?
      04-10-2019, 07:34 AM   #795
nastypoker
Drives: BMW M235i
Fitted the JL rear speakers today and it has made another improvement which is great.
I did a test using the aux cable instead of bluetooth and there are no crackles!
It seems crackling over bluetooth is a common issue with no fix.
      04-10-2019, 10:24 AM   #796
BEM-S4
BEM-S4's Avatar
Garbage in = garbage out. Streaming compressed music bad. Bluetooth bad.
Try lossless source files next.
      04-10-2019, 11:14 AM   #797
nastypoker
Drives: BMW M235i
Yeah it's just a shame because using my phone on bluetooth is so convenient. If it wasn't for the crackles, I would be happy with bluetooth audio quality on these new speakers I have now.
So I want to be able to answer calls using the car system, have no crackles from bluetooth audio when listening to music and use the steering wheel controls. It seems my only option is to have music on a USB stick or pre-load onto the cars HD and then have my phone on bluetooth just for calls.
Bit annoying as I update my music library on my phone regularly so I need to do that with the USB stick as well now.
      04-10-2019, 11:30 AM   #798
BEM-S4
BEM-S4's Avatar
Usb with lossless is path of least resistance. I did the USB option for my father's car simply for ease of use. It's incredibly seamless.
      05-19-2019, 09:21 PM   #799
Hekler
Drives: 2019 M240i Black on Black
Originally Posted by selmeralto View Post
(With apologies to Stanley Kubrick.)
What follows is a relatively low-cost way to make the Harmon Kardon audio system sound good.
The original post is in black. My updates are in red. There have been many comments and updates to this thread. I edit this initial post (#1) to keep it current but subscribers to this thread don't get notifications of edits so if you're interested in the audio upgrade solution recommended here I suggest you read all the posts that follow and return to #1 from time to time to keep current.
WORRYING.
I was angry and disappointed with the Harmon Kardon system for 7 reasons:
1. The HK system sounds awful: it is harsh, especially toward the upper end, fatiguing, and uneven across the audio spectrum. The bass has no solidity.
2. The HK system has a poor soundstage: instruments and voices lack clear spatial definition.
3. The HK system has very little capacity to customize the sound: just treble and bass tone controls that, sadly, boost their respective spectrums unevenly. No mid-range adjustment. No EQ.
4. The HK system is integrated so tightly with the car’s electronics that replacing components is a challenge.
5. The HK system is noisy: from the factory there’s an annoying upper frequency hiss that apparently comes from the Active Sound Design (ASD) module linked to the HK amp.
The HK sound is also muddied by the fake engine noise that ASD puts through the speakers.
6. The HK system is expensive, especially for what you get.
Depressing reality checks: The Sony system on the Ford hybrid C-Max SUV (MSRP $24,170) costs $275 less than the HK and has a mid-range adjustment. The Sony sounds better than the HK. I rented a run-of-the-mill Nissan Altima. It had a 3-band equalizer. The $5.99 Neutron music player app on my Galaxy phone has a 4-band equalizer.
I was particularly annoyed that my immediate impression after listening to the system for the first time was that, after springing for the “premium” system, I was facing the proposition of spending even more money to upgrade the “upgraded” system. I expect more of a $50K car. The poor quality of this "premium" option diminishes the luster of the BMW brand.
7. I add a quirk reported by some members that the HK subwoofers may unexpectedly go offline, usually coming back after a car restart. This may be caused by the amp overheating under load, especially prolonged heavy bass draws. This is an annoyance but it happens infrequently and isn't a big deal.
NOT WORRYING. LIVING.
I have however arrived at a compromise that doesn’t involve too much more money and that makes the system sound good. I’ve concentrated on reducing noise and making modest equipment improvements, primarily to the speakers, to improve the audio. This solution avoids having to interfere with the complicated computerized electronics of the car. None of the modifications requires any specialized skill or equipment. For the record, I’m a lifelong audiophile with preferences toward natural, clean and dynamic sound. I am not so much interested in high-thud sound but I do appreciate clear, solid, well defined bass. I listen to all kinds of music.
Here’s what I've done, with money and time outlays listed. Thanks to all the people on the forum who made various suggestions about these changes.
1. Disconnected the center channel speakers.
Results: better soundstage and a little cleaner sound. You’ll need a small Torx ratchet set.
Time: Under an hour.
Cost: $0.
This procedure has no effect on the navigation voice, which comes through loud and clear through the rest of the speaker system.
2. Installed the Technic Active Sound removal harness.
Results: (1) eliminates the fake motor/exhaust sound fed through the speakers and (2) reduces if not eliminates the hiss that interferes with the music from the audio system and was giving me headaches. Not only is the sound system improved but the car is noticeably quieter. Zooks527 has a terrific installation tutorial on the forum: http://www.2addicts.com/forums/showthread.php?t=1202389 .
Time: about 2 hours.
Cost: $65.
[CAUTION: I had a problem with the BMW SOS emergency button after my audio mods. It seemed at first that the harness might be incompatible with the BMW SOS emergency button, rendering the SOS service inoperable. It turned out, however, after investigation that the harness is safe. The SOS problem was due to a defect in the BMW telematics control unit, which operates independently of the ASD and the harness. No need to worry.]
Installation of the original version of the harness results in a reduction in bass response and some other audible issues. Forum member Silver6spd discovered that an incorrect wiring setup in the harness was causing the problem which was itself the result of a mistake in BMW's original OEM schematic regarding the polarity of the left front speaker.
The fix is easy:
1. Among the looping wires in the harness you'll find a white wire and a white/black wire.
2. Cut each of these two wires at the center.
3. Connect the wires crosswise so that each wire consists of a white-connected-to-a-white/black wire.
4. Put a wire connector or a wire nut or electrical tape on each. Make sure you don't over-tighten the wire nut and break one of the connections - or you'll lose sound to a speaker. Test for sound and you're all done.
Thanks to Silver6spd for recognizing the problem and tracking down a solution. Future versions of the Technic harness will have the correct wiring. Thanks also to Technic for working to correct the issue. Pictures of the simple fix at are posts #252 and 253, below.
A cleaner solution involving a little more time and effort changing the pins rather than splicing the wires has been suggested by mdputnam: http://www.2addicts.com/forums/showt...9#post20512019.
Use the approach with which you're more comfortable: there's no difference electronically or sonically. The fix is well worth making since the harness results in a noticeable improvement of the sound of the system.
3. I'll be installing the BMW weather-stripping on the front doors.
Results: reduces- engine and road noise for an even quieter cabin.
Time: 20 minutes.
Cost: $30.
I've now installed the weather-stripping. Quieter as advertised.
For information on ordering the weather-stripping, see posts #171-3, below.
Note that the correct part numbers are 51487300693 and 51487300694.
A thread on installing the weather-stripping is at http://www.2addicts.com/forums/showt...atherstripping .
4. Replaced the HK stock speakers in the front doors with Eton B100W component speakers (mid-range + tweeter for each door).
Results: tighter and cleaner sound with a smooth, more natural sound across the spectrum and a punchier mid-low. The harshness of the mid-upper and upper end of the HK system is gone. Eton speakers are highly regarded in Germany and on the Continent but are not very well known in North America. These are very fine and reasonably-priced speakers. They can be ordered from Germany via Amazon or the Extreme Audio website. Mine arrived in a week, delivered to the door by FedEx. Many forum members in the U.S. have ordered the speakers from Germany with no problems.
The speakers are an easy installation, assuming you’re not squeamish about taking the door panels off. The speakers are an exact fit with no additional adapters or connectors needed. Though you do need to be careful: one member accidentally drilled through a wire connected to the airbag system. Just work slowly and you'll be alright.
Bonus: opportunity to add sound deadening material – I used Dynamat Extreme – to the door frame around the mid-range and to the door panel. Eton makes different versions of the speaker. It’s important that you order the “B100W” version. Grave has posted an excellent installation tutorial on the forum. He has good pictures accompanied by instructions in French. See his post at http://bmw-one.com/phpbb3/viewtopic.php?f=21&t=34196 . I've written up a (very poor) English translation of his instructions that I can PM. For further help on the installation see also Solarphil's excellent guide at http://www.2addicts.com/forums/showthread.php?t=1258290 .
Time: about 4 hours but I really took my time, trying not to put a screwdriver through a cone. That includes Dynamatting the doors and panels. A less cautious amateur could probably do the job in a couple of hours, a pro in an hour. If you have a pro do it, you shouldn't have to pay much since no special fittings are required: it's plug and play after the panels come off.
It's well worth it to make this investment since most of the sound comes from the front speakers.
Cost: about $250, including shipping.
The total cost to make the HK system sound good (Technics harness, Eton speakers for the front doors, weatherstripping, some Dynamat) was just under $350, which is about as much money as I care to spend on the audio system right now, having already parted with $875 for the HK.
JL Audio speakers for the rear deck add another $75-100. See below.
Is the system all I wanted?
No. But it’s a damned sight better than the factory HK setup. The sound is tighter, cleaner, more natural sounding, and much easier to listen to at volume. The hiss seems to be gone. The cabin is much quieter. The HK woofers are OK.
If I’m overcome with a burning urge to relieve myself of more money on the audio system and I have time on my hands I’d probably, in order,
(5) Replace the rear speakers JL Audio C2-400x coaxes, as per Viffermike’s suggestion.
I broke down, bought, and installed these.
Result: Much more natural sound, huge difference in lower and mid-bass. The treble is also improved. Sure glad I did this.
Time: under an hour.
Cost: $75-$100.
The installation is extremely simple. Two of the three JL screw holes align exactly over two of the holes in the car. You can easily secure the third mounting tab by using a wide washer or similar item and the original BMW screw. Adding speakers to the rear of a convertible takes more work than in the hardtop and might require the help of a pro. See posts #222 & 224 in this thread and the "M235i Vert" thread.
Installation note: the original connectors are locking connectors. Use a very small screwdriver or an awl to release the lock. Don't just pull.
The increased and tighter bass may cause a bit of a rattle from the rear, even if you install the dynamat as recommended in this thread. The rattle comes from the child lock latches. An easy solution suggested by clemsonkev: pack the lock with a few packing foam peanuts and close the latch. Problem solved.
(-) Replace the HK underseat woofers. Time: a few hours. Cost: depends on choice but plan on around $500 for the pair.
Not necessary with the addition of the Eton and JL Audio speakers. Even doing one set of speakers improves the bass, especially the JL's in the back. One or two members have replaced the under-seat woofers with Bavtech and other speakers, leaving the original HK head unit. What change there was was unremarkable.
(-) Install a Bimmertech amp. Time: a few hours. Cost: $849.
Not necessary.
Another speaker option to consider is Bavsound. Their front door package (mid + tweeter) is about $100 more than the Etons. The Bavsound rear shelf speaker set is about $200 more than the JL Audio. They also offer a center channel speaker for $100 and a center channel tweeter for $100. Bavsound has announced that the package will rise by $100-200 on June 1st. There are other speaker options that are more expensive.
6. I will install more Dynamat as I work on the car.
I added Dynamat Extreme to most of the bare metal in the trunk. You can see a few photos of the Dynamatting in posts #126 & 148, below. My goal was to make the listening environment sepulchral. The car is now like a tomb and the sound is considerably improved, especially with respect to solidity and delineation of musical sources in the soundstage. I should add that road noise is considerably reduced, so adding Dynamat is not just an audio issue.
My choices reflect my prior conviction that it makes sense to improve the speakers before the electronics and my resistance to dumping tons of money on a system that, in the end, is still limited by the capabilities and limitations of the HK headunit/amp. I would much rather have had control of the audio from beginning to end, in which case I might have ordered the base sound unit and put the money in on a good, complete aftermarket system. I realize that there’s room to disagree on these points. But an important question is whether the HK head unit/amp is superior to the base HiFi unit. It probably is, in which case it probably makes sense to spring for the HK system, knowing that further expenditures are in your future.
I'm now done fooling around with the audio. The system is pretty good.
I hope this post is helpful to other HK owners similarly afflicted and to other 2-series potential buyers thinking of what options to include and exclude.
Reflections on Eton/JLAudio v. Bavsound/Bimmertech
The current price for Bavsound Stage One package upgrade (front and rear, including center channel, but excluding the subwoofers) is $797, with a possible price increase of $100-200 in summer 2016. Adding the Bimmertech amp ($849) puts the Bavsound/Bimmertech combo at between $1746-$1846. The Eton/JLAudio speaker combination is $350.
Is the nearly $1400-$1500 difference between Bavsound/Bimmertech and Eton/JLAudio worth it?
The Bimmertech amp is tunable (though not through a simple EQ array on the car's display) whereas the Eton/JLAudio fix relies on the HK tone controls. The ability to fine-tune the Bimmertech amp allows for more customization than the HK tone controls. Tuning the Bimmertech involves downloading and installing a tuning file with a laptop and a USB cable. You can then fine-tune the tuning manually with a laptop and cable. Installing and adjusting the tuning on the Bimmertech will be fun for some, a pain for others, since there no such thing as single standard or optimal tune that will satisfy all listeners. See http://www.2addicts.com/forums/showthread.php?t=1232178 for what's involved. In any event, installing a tune is not something that can be done on the fly if you want to alter the sound while driving or in a hurry, as you can do with conventional tone controls.
As for a judgment on the sound itself - which is, after all, the prize - it would be good to have the two systems side by side for an A/B comparison but the likelihood of that happening is very low.
But watch this space: an A/B comparison is coming soon.
After living with the upgrades listed here for quite some time, I personally don't feel the need for extra power or superior electronics in the car: the system sounds good and has all the power I need even at high revs and speed, especially since so much noise has been eliminated from the environment.
To this I would also note some difficulties forum members have had with Bavsound and Bimmertech.
First, several forums members have reported issues with Bavsound distribution, production line delays, missing parts, and speaker quality control.
Second, as reported by Zooks527, there is a potential problem that the Bimmertech 3rd party amp may cause routine dealer ECU flashes to abort and immobilize the car(!). The flash may be looking for a response from the audio that it doesn't get because of the 3rd party amp. Not seeing the response, the flash fails and the car turns into a brick.
When this happens the 3rd party amp has to be uninstalled and the stock amp reinstalled while the car is in the shop. The car can then be reflashed by the dealer. The 3rd party amp can be reinstalled after the flash in the shop or at home. If your car is immobilized in the shop you will have to tell the dealer the probable cause since the dealer may not be aware of the incompatibility of the amp with the flash procedure.
Note: The bricking problem appears to be caused by the 3rd party amp, not the Technics ASD bypass harness.
I am not aware of any dealer who has charged an owner for time and labor on reflashing the car and getting it to start, on the grounds that the owner's installation caused the problem. Nor have I heard of a dealer who has tried to void the warranty because of an amp installation. But these are possibilities. At best the problem is an unpleasant inconvenience - it's not exactly a barrel of fun to rip out the trunk liner and reinstall it, reseating it under the rubber trunk seal. And at worst the uninstallation and reinstallation could result in damage to the components, liner, and/or rubber seal, extra time at the dealer's, and perhaps even repair charges. There are other amps (for example, the JL 600/6) that cost less than the Bimmertech and amps that cost more but until we hear from owners of such amps who have actually had ECU flashes we have to assume the same risk applies. Now it should be pointed out that ECU flashes are only infrequently installed by dealers. That said, in order to be safe, owners with 3rd party amps need either to be sure to uninstall the amp before every visit to the dealership - which may not be possible in the case of unplanned or sudden visits - or ask the dealer not to flash the car - which is not a good policy. Ignoring this issue could leave you with an immobilized BMW on the shop floor. I should point out, though, that some members have reported having an ECU flash on cars with aftermarket amps installed, with no adverse results. So the jury is out on this one.
Forum member djarchow has reported that the Bimmertech amp may cut out when stepping on the brake and turning the headlights on. The culprit may be low level electrical noise in the car that causes the amp to shift to switch to AUX inputs, muting the main inputs.
All this gets back to the problem of the system's close integration with the car's computer systems. For a discussion of the risks of installing after-market electronics in this car, see this thread: http://www.2addicts.com/forums/showt...4#post20053574
I won't pursue the possibility, made in another thread, of installing a MusicarNW Stage 3 system at upwards of $5,000. This is way beyond what I could personally justify spending on an automotive sound system, especially considering how good the system can sound with the modest changes suggested above. For the record, I understand the irony of someone who has spent $50K on an automobile complaining about the extravagance of spending $5K on a sound upgrade.
Forum member fancyfl1ght has reported static white noise problems with the JL Audio xd800/8v2 amplifier.
There is some ongoing discussion about other possible polarity issues with the HK system but at the moment it's not clear that there actually are such problems. Moreover, as djarchow has argued in another thread, what might seem to be a simple issue with the polarity of a speaker can actually involve many other variables in the system. If we get confirmation that there actually is a specific problem with polarity (apart from the driver's side rear speaker), I'll provide an update to this thread. Until then best not to rush into changes.
Finally, a gentle reminder. When making electrical connections be sure that the connections stay secure. If you use wire nuts don't over tighten them or the wire may come out of the metal connector inside. Same for electrical tape: be sure as you wrap the tape that you don't undo the connection inside. I know this is Basic Working With Electricity 101 but at least two members (not naming names ) have inadvertently disconnected wires and have lost sound.
Conclusion: All in all, the simple speaker swap with sound deadening and noise reduction seems to me the way to go from the standpoints of sound, convenience, price, and risk. People can choose which of the improvements to make on an incremental basis. If you have the inclination, though, I really do recommend carrying out the full installation.
I'd welcome others' views.
These reflections do not take into account the possibility of replacing the underseat woofers which, for reasons noted (posts #27 & #159, below), I'm not inclined to do at this point. The space limitations for the enclosures make it pretty unlikely that just replacing the speakers will make a significant difference at the lower end. As I said earlier I was trying to keep costs down to what I considered to be reasonable after spending for the "premium" HK upgrade. Philosophical reflections on how much money to spend on the underseat woofers are sprinkled through the discussion but see especially post #537 and following.
I just got my car and liked your approach to make the sound better for reasonable costs. Thanks Much!!
      05-19-2019, 09:53 PM   #800
EE60
Drives: 2015 M235i vert
Convertible
[COLOR="Red"]What follows is a relatively low-cost way to make the Harmon Kardon audio system sound good.
The original post is in black. My updates are in red. There have been many comments and updates to this thread. I edit this initial post (#1) to keep it current but subscribers to this thread don't get notifications of edits so if you're interested in the audio upgrade solution recommended here I suggest you read all the posts that follow and return to #1 from time to time to keep current.[/COLOR]
WORRYING.
1. The HK system [COLOR="Blue"]sounds awful[/COLOR]: it is harsh, especially toward the upper end, fatiguing, and uneven across the audio spectrum. The bass has no solidity.
2. The HK system has a [COLOR="Blue"]poor soundstage[/COLOR]: instruments and voices lack clear spatial definition.
3. The HK system has very [COLOR="Blue"]little capacity to customize the sound[/COLOR]: just treble and bass tone controls that, sadly, boost their respective spectrums unevenly. No mid-range adjustment. No EQ.
4. The HK system is [COLOR="Blue"]integrated so tightly [/COLOR]with the carÂ’s electronics that replacing components is a challenge.
5. The HK system is [COLOR="Blue"]noisy[/COLOR]: from the factory thereÂ’s an annoying upper frequency hiss that apparently comes from the Active Sound Design (ASD) module linked to the HK amp.
6. The HK system is [COLOR="Blue"]expensive[/COLOR], especially for what you get.
[COLOR="Red"]Depressing reality checks: The Sony system on the Ford hybrid C-Max SUV (MSRP $24,170) costs $275 less than the HK and has a mid-range adjustment. The Sony sounds better than the HK. I rented a run-of-the-mill Nissan Altima. It had a 3-band equalizer. The $5.99 Neutron music player app on my Galaxy phone has a 4-band equalizer.[/COLOR]
[COLOR="Red"]7. I add a quirk reported by some members that the HK subwoofers may unexpectedly go offline, usually coming back after a car restart. This may be caused by the amp overheating under load, especially prolonged heavy bass draws. This is an annoyance but it happens infrequently and isn't a big deal.[/COLOR]
I have however arrived at a compromise that doesnÂ’t involve too much more money and that makes the system sound good. IÂ’ve concentrated on reducing noise and making modest equipment improvements, primarily to the speakers, to improve the audio. This solution avoids having to interfere with the complicated computerized electronics of the car. None of the modifications requires any specialized skill or equipment. For the record, IÂ’m a lifelong audiophile with preferences toward natural, clean and dynamic sound. I am not so much interested in high-thud sound but I do appreciate clear, solid, well defined bass. I listen to all kinds of music.
HereÂ’s what I've done, with money and time outlays listed. Thanks to all the people on the forum who made various suggestions about these changes.
Results: better soundstage and a little cleaner sound. YouÂ’ll need a small Torx ratchet set.
Cost: $0.
[COLOR="Red"]This procedure has no effect on the navigation voice, which comes through loud and clear through the rest of the speaker system.[/COLOR]
Results: (1) eliminates the fake motor/exhaust sound fed through the speakers and (2) reduces if not eliminates the hiss that interferes with the music from the audio system and was giving me headaches. Not only is the sound system improved but the car is noticeably quieter. [COLOR="Red"]Zooks527 has a terrific installation tutorial on the forum: http://www.2addicts.com/forums/showthread.php?t=1202389 .[/COLOR]
Cost: $65.
[COLOR="Red"][CAUTION: I had a problem with the BMW SOS emergency button after my audio mods. It seemed at first that the harness might be incompatible with the BMW SOS emergency button, rendering the SOS service inoperable. It turned out, however, after investigation that the harness is safe. The SOS problem was due to a defect in the BMW telematics control unit, which operates independently of the ASD and the harness. No need to worry.][/COLOR]
[COLOR="Red"]Installation of the original version of the harness results in a reduction in bass response and some other audible issues. Forum member Silver6spd discovered that an incorrect wiring setup in the harness was causing the problem which was itself the result of a mistake in BMW's original OEM schematic regarding the polarity of the left front speaker.
The fix is easy:
[/COLOR]
Time: 20 minutes.
Cost: $30.
[COLOR="Red"]I've now installed the weather-stripping. Quieter as advertised.
A thread on installing the weather-stripping is at http://www.2addicts.com/forums/showt...atherstripping .[/COLOR]
Results: tighter and cleaner sound with a smooth, more natural sound across the spectrum and a punchier mid-low. The harshness of the mid-upper and upper end of the HK system is gone. Eton speakers are highly regarded in Germany and on the Continent but are not very well known in North America. These are very fine and reasonably-priced speakers. They can be ordered from Germany via Amazon or the [COLOR="Red"][COLOR="Red"]Extreme Audio website[/COLOR][/COLOR]. Mine arrived in a week, delivered to the door by FedEx. [COLOR="Red"]Many forum members in the U.S. have ordered the speakers from Germany with no problems.[/COLOR]
The speakers are an easy installation, assuming youÂ’re not squeamish about taking the door panels off. The speakers are an exact fit with no additional adapters or connectors needed. [COLOR="Red"]Though you do need to be careful: one member accidentally drilled through a wire connected to the airbag system. Just work slowly and you'll be alright. [/COLOR]
Bonus: opportunity to add sound deadening material – I used Dynamat Extreme – to the door frame around the mid-range and to the door panel. Eton makes different versions of the speaker. It’s important that you order the “B100W” version. Grave has posted an excellent installation tutorial on the forum. [COLOR="Red"]He has good pictures accompanied by instructions in French. See his post at http://bmw-one.com/phpbb3/viewtopic.php?f=21&t=34196 . I've written up a (very poor) English translation of his instructions that I can PM. For further help on the installation see also Solarphil's excellent guide at http://www.2addicts.com/forums/showthread.php?t=1258290 .[/COLOR]
[COLOR="Red"]JL Audio speakers for the rear deck add another $75-100. See below.[/COLOR]
No. But itÂ’s a damned sight better than the factory HK setup. The sound is tighter, cleaner, more natural sounding, and much easier to listen to at volume. The hiss seems to be gone. The cabin is much quieter. The HK woofers are OK.
If IÂ’m overcome with a burning urge to relieve myself of more money on the audio system and I have time on my hands IÂ’d probably, in order,
(5) Replace the rear speakers JL Audio C2-400x coaxes, as per ViffermikeÂ’s suggestion.
[COLOR="Red"]I broke down, bought, and installed these.
Cost: $75-$100.
The increased and tighter bass may cause a bit of a rattle from the rear, even if you install the dynamat as recommended in this thread. The rattle comes from the child lock latches. An easy solution suggested by clemsonkev: pack the lock with a few packing foam peanuts and close the latch. Problem solved.[/COLOR]
[COLOR="Red"]Not necessary with the addition of the Eton and JL Audio speakers. Even doing one set of speakers improves the bass, especially the JL's in the back. One or two members have replaced the under-seat woofers with Bavtech and other speakers, leaving the original HK head unit. What change there was was unremarkable.[/COLOR]
[COLOR="Red"]Not necessary.[/COLOR]
Another speaker option to consider is Bavsound. Their front door package (mid + tweeter) is about $100 more than the Etons. The Bavsound rear shelf speaker set is about $200 more than the JL Audio. They also offer a center channel speaker for $100 and a center channel tweeter for $100. [COLOR="Red"]Bavsound has announced that the package will rise by $100-200 on June 1st.[/COLOR] There are other speaker options that are more expensive.
[COLOR="Red"]I added Dynamat Extreme to most of the bare metal in the trunk. You can see a few photos of the Dynamatting in posts #126 & 148, below. My goal was to make the listening environment sepulchral. The car is now like a tomb and the sound is considerably improved, especially with respect to solidity and delineation of musical sources in the soundstage. I should add that road noise is considerably reduced, so adding Dynamat is not just an audio issue.[/COLOR]
My choices reflect my prior conviction that it makes sense to improve the speakers before the electronics and my resistance to dumping tons of money on a system that, in the end, is still limited by the capabilities and limitations of the HK headunit/amp. I would much rather have had control of the audio from beginning to end, in which case I might have ordered the base sound unit and put the money in on a good, complete aftermarket system. I realize that thereÂ’s room to disagree on these points. But an important question is whether the HK head unit/amp is superior to the base HiFi unit. It probably is, in which case it probably makes sense to spring for the HK system, knowing that further expenditures are in your future.
[COLOR="Red"]I'm now done fooling around with the audio. The system is pretty good.[/COLOR]
[COLOR="Red"]
[COLOR="SeaGreen"]But watch this space: an A/B comparison is coming soon.[/COLOR]
[COLOR="Red"]Conclusion: [/COLOR]All in all, the simple speaker swap with sound deadening and noise reduction seems to me the way to go from the standpoints of sound, convenience, price, and risk. People can choose which of the improvements to make on an incremental basis. If you have the inclination, though, I really do recommend carrying out the full installation.
These reflections do not take into account the possibility of replacing the underseat woofers which, for reasons noted (posts #27 & #159, below), I'm not inclined to do at this point. The space limitations for the enclosures make it pretty unlikely that just replacing the speakers will make a significant difference at the lower end. As I said earlier I was trying to keep costs down to what I considered to be reasonable after spending for the "premium" HK upgrade. Philosophical reflections on how much money to spend on the underseat woofers are sprinkled through the discussion but see especially post #537 and following.[/COLOR]
I have a convertible
For a vert, would I still want to disconnect the center speakers as a first step, or would I want to replace them and, if so, with what?
Also is revised ASD harness currently available?
Thanks for a great write up
EE60
      05-19-2019, 10:36 PM   #801
EE60
Convertible
WORRYING.
Cost: $0.
Cost: $65.
The fix is easy:
[/COLOR]
Time: 20 minutes.
Cost: $30.
Cost: $75-$100.
[COLOR="Red"]
EE60
EE60
      05-24-2019, 03:14 PM   #802
AleksanderSuave
Drives: 2017 M240iX Coupe
Originally Posted by Viffermike View Post
Now: The B100 XHPs are high-pass filters; they are NOT crossovers. All they do is prevent bass frequencies (150Hz and below) from reaching the woofer and tweeter. The OEM amp is already doing this. So, IMHO, there is no need to install them in any situation except if you're running an aftermarket amp without internal high-pass filtering.
- Mike
Mike, curious about this subject, resurrecting the dead so to speak.
when you reference the OEM amp, is there a difference here between the Hifi AMP and the H/K amp? My reading in another thread was that the two were quite similar, so I assume no (minus the increased wattage to drive the larger # of speakers in HK), or does the OEM hifi amp not have built in cross-over function since the HIFI system doesnt run tweeters?
      05-29-2019, 12:49 PM   #803
Viffermike
Viffermike's Avatar
Nearly all OEM systems in modern car audio have some sort of DSP - Digital Signal Processing - as part of its setup. A key element of that processing is pass filtering, so that certain speakers receive only certain frequencies. In these cases, such filtering is digital and cannot be removed except by two methods:
Option 1: The DSP unit itself is taken out of the audio system
Option 2: The DSP is overridden by so-called 'correcting' DSP units that are installed somewhere downstream from the OEM DSP.
Where the OEM DSP chip lives, and how it functions, is a key difference between the HiFi and HK systems.
- In the HiFi system it lives inside the amplifier unit, which can be bypassed because HiFi only uses a (barely) line-level analog signal from the head unit. So Option 1 above works.
- In the HK system, it also lives in the amp housing -- but that housing is also a MOST control box, part of the function of which is to convert the digital-only signals it receives from the head unit to multiple speaker-level analog signals, which are only then subjected to DSP. But the MOST control box cannot be removed because it's intertwined with several other Infotainment systems. Only Option 2 is possible.
The problem with Option 2 in fiber-optic MOST systems is that the amplifier cannot be separated from the audio stream, so adding a 'corrective' DSP means it must take a speaker-level analog input -- which has already been converted from digital at least once -- correct the DSP, convert it to digital again, then re-convert it back to analog. We're talking at least four AD/DA conversions, which is a really, really bad idea for audio quality. The only solution is to override the MOST interface with another MOST device, which will endemically have its own user-adjustable DSP.
What does that mean regarding physical pass filtering for speakers? It makes them totally unnecessary in all cases except one: when the OEM amp is still being used but different speakers (with different frequency requirements / capabilities) are installed.
Hope this helps.
--Helmets are for closers.--
      05-30-2019, 01:49 AM   #804
AleksanderSuave
Hope this helps.
So if I'm reading your explanation correctly, in the HIFI system, option 1 is accomplished by literally changing out speakers, when using the OEM amp, because the DSP was setup to only filter frequencies for the original OEM speakers?
What the B 100 XHP does is hard filter frequencies the OEM DSP is not setup for?
Interesting because one of the german stores I ordered from was asked the above question (what do these parts do beyond the filter supplied with the B100W) and their response was "the switch separates the frequencies better if you install an amplifier or listen to music with a lot of bass. Then the speakers in the door can play louder."
Interesting that they mention use specifically when installing an amp (which makes sense as you'd bypass the oem amp) but not when maintaining the existing amp but just replacing speakers.
If not using the additional filters, are you losing out on the full system potential by not utilizing the speakers properly, or is there a danger of sending the wrong frequency to the wrong speaker and blowing it?
from the explanation I also see it as, the high pass filter would plug into the car's wiring first in the chain, then into the eton speaker, which daisy chains into the tweeter.
Based on this, I dont see myself replacing the factory amp, so I may need to order the B100XHP kit after all.
The worst offender is the user manual for the product itself (B100W set)
which says "The midrange loudspeaker is equipped with two terminals. The first terminal is for the factory installed speaker cable, the second one is for the crossover cable.
After connecting the crossover, you can plug in the tweeter cable. This feature allows you to build up a full active system if you wire an additional cable in the door.
The tweeter is delivered with a mixed-up-proof cable crossover which is always connected between the midrange loudspeaker and the tweeter. Except in full active operation."
So they are referring to this part as a cross-over cable..then referencing full active operation (so power the tweeter with its own channel from an amp..which the hifi system does not do) but not clearly referencing the B100XHP cross-overs at all in the user manual, or explaining the necessary application of them.
      07-10-2019, 11:47 PM   #805
Audioholics
Friends, here is my final installment of my BMW M240i Audio system upgrade. This time I visited our friends at JL Audio in Miramar, Florida to professionally tune my car. I discuss this process with their head DSP guy, Nicolas Ames.
see:
      11-10-2019, 09:44 AM   #806
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
2018 BMW X3 M40i  [0.00]
2016 BMW M240i  [0.00]
I have the Hifi option in my M240i. While it's not the best system, I've had the displeasure of living with the "base" option in my old E82 which was far worse.
After deciding that I would try improve things I wanted a solution that was 1) Plug-and-play and 2) Cost effective. I settled on a set of Eton B100W's in conjunction with the HK tweeter pods to begin with, added StP sound deadening behind the mid-range door speakers and metal immediately surrounding them.
Results were pretty solid. Nothing mind-blowing (not that I was expecting it to be), but I'm happy enough with the heightening of the sound stage from waist level and the general improvement of sound quality to declare this reasonably quick modification easily worth the effort/money.
I've now gone ahead and ordered the B100XN and B100XCN for the rears and center. Once those are in I'll re-assess whether I want to add an uprated amp to the equation in the near future.
      11-19-2019, 06:49 AM   #807
PDM5
Drives: 2017 240i 6 Speed
If the HK setup sounds like this, I can't even imagine what the "base" setup sounds like. Wow. I could have sworn some of the speakers were either blown or not working, but I moved the sound around in the settings and sure enough, all the speakers were working. I'm not an audiophile and didn't plan to spend any money on the audio setup, but this has definitely made the rethink things. It legitimately sounds like two echo dots comprise the system.
      11-19-2019, 10:20 AM   #808
BEM-S4
BEM-S4's Avatar
For those considering upgrading the amp, I've worked with Technic to come up with a connector that allows you to keep stock amp installed for CAN bus (in case dealer needs to update the car SW) while using an upgraded amp of your choice. In my case we used Bimmertech amp with harness that we tapped into to run OEM stock amp as well. Avoids the need to swap in and out in the future for service visits.
At the very least do not get rid of your OEM stock amp, may need in the future.
      11-19-2019, 02:15 PM   #809
selmeralto
selmeralto's Avatar
227
Well. 807 replies and 179,973 views later and we finally have the definitive description of the sound of the HK factory setup:
"... sounds like two Echo Dots."
Could be worse. Could be "one Echo Dot."
      11-19-2019, 03:58 PM   #810
ctemkin
Drives: 2018 M240i
I would be very interested in having the same thing done to my car. Is the connector available for sale and, if so, how do I order one? I would be grateful for any info you can provide.
      11-19-2019, 04:22 PM   #811
BEM-S4
BEM-S4's Avatar
I'll post a detailed writeup with photos when I do my F23 in a week or so. F31 I did quickly and didn't take any pics. Process is the same for both.
Reach out to TechnicPNP for the wiring solution, depending on your aftermarket amp might be a little different than what I used.
      11-24-2019, 08:39 PM   #812
Robimplicit
Drives: M2; 335d
m235 audio vs M2 audio
Hi:
I will be selling my beloved m235 and getting a 2018 LCI M2. Is there any indication that the HK speakers in this M2 are better quality than those in the 2016 m235? I ask because I upgraded the speakers front and rear as detailed in this thread and have been very happy with the clarity of the sound. At this point, I have the option to remove the Etons and Focals in order to install them in the M2. I will do this if people feel that the M2 speakers are substantially the same as what came in the top end HK system in the m235. Any chance they are better than they used to be; better than the Etons and Focals?
Thanks.
-Robert.
      11-25-2019, 01:10 PM   #813
MarcoZandrini
Drives: 2018 M240i
Originally Posted by Robimplicit View Post
Hi:
Thanks.
-Robert.
Go to www.realoem.com and enter the last 7 characters of your car's VIN. Hit enter and scroll down to audio to get the speakers' part numbers. Click on each part # to see if the 2018 M2 uses the same part #.
      11-25-2019, 06:08 PM   #814
Robimplicit
Drives: M2; 335d
Great idea. Thanks.
I checked and seems the ASD and main amplifier have different part numbers but the numbers for the speakers are the same.
