11-08-2018, 09:33 AM | #507 | |
Rep 555
11-08-2018, 12:57 PM | #508 | |
Rep 115
Based on the pictures from Tail of the Dragon, my tires tuck inside the outer lips of the fender (with very marginal room, but they should tuck).
2014 M235i
11-08-2018, 01:10 PM | #509 |
Rep 555
You dont have rolled fenders right? Im hoping with very slight rolling this might be remedied, i know rear is already rolled. But i imagine just the act of it pulls them out a couple mm.
11-08-2018, 01:47 PM | #510 | |
Rep 115
Rolling the fenders won't help if it's hitting the fender liners. If it's hitting the lip of the fender, rolling will help. Usually you gain a few MM of clearance. I haven't looked inside our fenders to see how much it will help, usually you get some clearance by rolling the lip higher, and then pushing the outer part the fender out. It's all fun and games until your paint cracks.
2014 M235i
11-14-2018, 01:19 PM | #512 |
Rep 555
Well I gave up the idea of doing 235 fronts for now, just went with 225/35/19 for the time being, but good thing too, turns out the Michelin PS4S is a bit wider than the PSS.
11-19-2018, 05:07 PM | #513 |
Rep 5
18" vs 19"
I bought a used 228i from the dealer that came with VMR V710 19" wheels. The dealer had mounted new 245/35 tires, but they are rubbing. The dealer is offering to swap to 225/35 at no cost, but those tires have tiny sidewalls, and I'm worried about flatting or damaging the rim if I hit a pothole.
I'm considering swapping to 18" rims + stock 225/40/18 instead, as they seem better for daily driving. How have your experiences been with the 225/35/19 tires? Are they livable for daily driving or would you swap to 18"? |
11-20-2018, 01:20 PM | #515 |
General
2051
Rep 25,989
Agreed! The 18's will ride much better than the 19's will--especially going into winter!
VMR|Wheels | 714.442.7916 |
11-26-2018, 12:53 PM | #516 |
Rep 14
why is it recommended that the front tire be 8.5 rather than 9.5 like the rear?
11-26-2018, 05:30 PM | #517 |
General
2051
Rep 25,989
We recommend the 8.5" front because a 9.5" front will be an aggressive fitment that may require modifications and/or stretched tires. It's been done, but it's not something that we recommended as a bolt on fitment. Our recommended fitments are guaranteed to bolt on with no modification.
12-05-2018, 02:56 AM | #518 |
Rep 26
I can finally make a post here, all thanks to Brandon W.
mb67152.00 Champagnenewty1.50 |
12-06-2018, 04:12 PM | #520 |
Rep 45
Another fitment question
I'm picking up some lightly used wheels and tires this weekend.
VMR 810s F - 18x8.5 et 35 - 235/40/18 Conti ExtremeSport R- 18x9.5 et 45 - 255/35/18 Conti ExtremeSport I will be removing the tires for now and am planning on installing the Michelin A/S 3+ in F 225/40/18, R 255/35/18. I already tried to have the Michelins installed in 225/35/19 and 255/30/19 but that did not work on my stock 19's due to how wide the Michelins are compared to the Pirellis. I bought my car used and just "assumed" the 255 were stock size, learned my lesson. Back on track now. Current owner has a m240i and I have a m235i. From what I can tell, there is no reason if the above setup worked on his car that they should not work on mine. Am I correct? Sorry for the newb question, just really don't want to order tires again and they not fit. |
12-09-2018, 02:37 PM | #523 |
In search of the perfect cup of coffee
152
Rep 213
12-10-2018, 12:15 AM | #525 |
Rep 144
12-10-2018, 11:29 AM | #526 | |
General
2051
Rep 25,989
Don't forget to post pics after they're installed! Looking good! Was this picture taken before the fire?
Black Sunshine39.00 |
12-17-2018, 04:47 PM | #527 |
Rep 32
Just got mine in the other day. Titanium black shadow on a mineral white 240 with stock suspension. I went for 18s with 35/45 offsets wrapped in 225/255 Michelin PA4s for the winter. Going to swap to PS4s in the spring. Hard to tell if there is any actual poke, but the more aggressive offset compared to stock really helps fill out the wheel wells. Not sure if it's also the offset, or just the design, but the wheels themselves look way bigger than stock. Not quite like 19s, but close. Either way, very happy!
M240X /// DINAN /// VMR
12-18-2018, 02:30 AM | #528 |
152
Rep 213
Another teaser photo of my VMR V710's in Gunmetal on my 228i Conv:
Front: 18x8.5 ET35 5x120 72.6 Tires: Michelin Pilot Sport 4S 225/40/18 (We don't have rough winters here :P ) Rear: 18x9.5 ET45 5x120 72.6 Tires: Michelin Pilot Sport 4S 255/35/18 |
Tags |
9.5, fitment, v703, vmr, wheels |
