2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Turbo dying
      01-26-2019, 09:15 PM   #1
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
Turbo dying
I think my turbo is dead, or about to be...
Power seems like its lost substancial power although the meters do creep up to about 340hp it usually only shows 245 when im WOT... On a stage 2 tune i think it should show much higher.. but its an ots map so maybe thats what it is.
Im also getting this whining noise, its more of an electrical sound than a police siren, but i can hear it. Also it seems like i cant push more boost than 11 psi through most the power band.. power feels flat.
I think they are toast, and 45k of high abuse is a decent life expectancy.
Anyone had turbos go bad, or can comment on what to look for on n55?
Also anyone have a shop that has swapped n55 turbos in the tri state that you would recommend, lmk.
www.nybmwcca.org
Current Cars:
      01-26-2019, 11:21 PM   #2
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Damn...
      01-27-2019, 05:37 AM   #3
BEM-S4
BEM-S4's Avatar
Call Laura at Thompson in Doylestown - a bit of a ride for you but at least start with a phone convo. I think Matt left there but Laura is very good.
      01-27-2019, 12:49 PM   #4
Taskmaster
Japan
2465
https://www.2addicts.com/forums/show....php?t=1576174
      01-27-2019, 10:36 PM   #5
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
are you still having issues with that harness from your other post as well?
      01-28-2019, 08:10 AM   #6
bbnks2
Drives: 135i N55
Post a log.
      01-28-2019, 12:10 PM   #7
bryan_G01
bryan_G01's Avatar
1165
same harness, i have to replace the main harness, no one wants to do it. Not even bmw...
www.nybmwcca.org
Current Cars:
      01-28-2019, 12:10 PM   #8
jmwilson125
Drives: 2016 M235i
Failing diverter valve not holding boost maybe?
      01-28-2019, 01:39 PM   #9
EVEda235i
Mr. Clutch
EVEda235i's Avatar
Drives: 2015 M235i
2011 BMW 335i  [9.50]
Agreed. Did u upgrade to a GFB DV+?
Quiet M235i
      01-28-2019, 08:25 PM   #10
bryan_G01
bryan_G01's Avatar
1165
i have one. need to put it in.
im pretty sure acuators are stuck too, and from heat, wheels messed up rubbing making whistle sound.
saw some other videos online n54, n55, same sounds. pretty sure turbo is cooked or about to be.
Plan is new turbo & DV+ install. just need to find a good shop.
www.nybmwcca.org
Current Cars:
      01-29-2019, 09:40 AM   #11
jmwilson125
Drives: 2016 M235i
Are you going to upgrade the turbo? Or throw another stock in? Did you get your hands on that dinan one?
      01-29-2019, 10:02 AM   #12
bryan_G01
bryan_G01's Avatar
1165
the dinan one was sold, i woulda threw that one in.
ill probably throw a pure stage 2 in. If stock is going to be 2k, pure really isnt that much more for alot more power.
www.nybmwcca.org
Current Cars:
      01-29-2019, 10:43 AM   #13
bryan_G01
bryan_G01's Avatar
1165
who has ps2 cheapest right now?
www.nybmwcca.org
Current Cars:
      01-29-2019, 10:47 AM   #14
cxp213
cxp213's Avatar
313
+1 on upgrading turbo if replacing, but sounds like you're just guessing. Why not log to verify your suspicion first?
      01-29-2019, 10:57 AM   #15
arhoads335i
Drives: 2015 435i grand coupe xdrive
2008 BMW 128I  [0.00]
Id probably go with a smaller speedtech unit. Afterall the Pure stage two is still a hybrid. With how hard you work the car on the track the EGTs will get high with the stock manifold.
Also I would argue that the turbos speedtech uses are more reliable. Though it will cost more.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current)
2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD)
08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD)
      01-29-2019, 11:02 AM   #16
bryan_G01
bryan_G01's Avatar
1165
honestly, not going for world speed records..
Im not even looking to add meth or PI, just need to replace my broken turbo. If i get some more power, all good.
Ill pull some logs so you can see next time i go out.
Just found this on another msg board and loled...
Well you would loose boost infact no boost at all.
every time you tryed to boost you would get a stupid weuuuuuuuuuuuuuuuuuu sound
you would eventually start to smoke badly out the back..
I blew my turbo a few months back and thats what happened to me.
yes you still have vaccum and it would be its norman 25 driving and 20 when idle.
with no dv your car would run like shit.. you need that dv to release the pressure.
with a broken dv you would get a hisss at higher boost and your car would just be flat out weak.
hope that can help.
that weeuuuu sound is exactly what im getting..
xtreme power house has the best price in ps2 right now it seems. mike if you online, pm me.
www.nybmwcca.org
Current Cars:
      01-29-2019, 11:24 AM   #17
bryan_G01
bryan_G01's Avatar
1165
so to answer my question, How to tell if your turbo is dying?
  • Weuuuuuu sound without power
  • Oil levels low, get the add oil msg in I-drive
  • Smell - a burning smell of oil, something not right
    • loss of power- hard to determine, but if you feel its not the same, have it checked out
    • White or blueish smoke
www.nybmwcca.org
Current Cars:
      01-29-2019, 11:38 AM   #18
bryan_G01
bryan_G01's Avatar
1165
ftw
www.nybmwcca.org
Current Cars:
      01-29-2019, 11:42 AM   #19
Taskmaster
Japan
2465
https://f30.bimmerpost.com/forums/sh...ighlight=Turbo
Check
      01-29-2019, 11:43 AM   #20
Taskmaster
Japan
2465
Car-part.com
      01-29-2019, 11:47 AM   #21
bryan_G01
bryan_G01's Avatar
1165
looks like pure stage 2 fellas...
should have some good data soon.
btw x-ph was almost $500 cheaper and free shipping vs ordering from pure directly.
www.nybmwcca.org
Current Cars:
      01-29-2019, 09:08 PM   #22
amw896
amw896's Avatar
congrats dude. Looking forward to a review!
