2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions MyCarly BMW Android/IOS Coding...
      04-19-2017, 09:20 PM   #89
MattUK
Captain Unsensible
MattUK's Avatar
United Kingdom
100
Drives: 2016 M240i Coupe - Estoril
2016 BMW M240i  [0.00]
Originally Posted by Sleslie View Post
Originally Posted by MattUK View Post
I've switched across to Bimmercode as that has far more options for coding out of the box and allows expert mode coding.
I've also now setup eSys with the cable, so have all options.
The cost of Carly compared to the others and what it offers are not that good.
Where you able to use the Carly OBD adapter with BimmerCode?
No, needed to get the one listed
      04-22-2017, 12:52 PM   #90
SwolePatrol
Drives: 2015 M235i Melbourne Red
Anyone have any additional personal experience with BimmerCode and Carly? My car is a 2015 M235i (June 2014 build).
I read that some of these options "don't stick" once I shut the card off. What features is this references?
Is there a "how-to" guide?
      04-23-2017, 09:59 AM   #91
SDKevin
Cone Killer
85
Drives: 2024 M240i, Ducati 1299S
The only feature that doesn't 'stick' is the manual opening / closing of the exhaust valve and they are very clear that it's only a temporary change.
I've been using the Carly for a couple of months and, although pricey, it's decent. Limited as to what it can code, but it's very user friendly compared to having to lug my laptop out to the car. I like the sound of BimmerCode expert mode and hopefully Carly will add that feature.
      04-23-2017, 12:19 PM   #92
SwolePatrol
Thanks for the info!
      04-23-2017, 05:10 PM   #93
BMWZ4
BMWZ4's Avatar
1910
Question: can someone connect their Carly and take a look at the ASD option? Take a read of the ASD ECU and tell me what the ASD options are...please!
Should be OFF, M3/M4, M5/M6...and 1 other one. I only see the 3 I've noted and I THINK there was a 4th option (but in my case it's gone...assuming I'm not mistaken)
Thanks
      04-24-2017, 09:16 PM   #94
SDKevin
Cone Killer
85
Thanks
Mine only has the same three options you listed. I'm pretty sure it never had another. I've turned mine off but I've always wondered how I would set it back to M235i (without restoring from the backup file).
BMWZ41909.50
      04-25-2017, 08:56 AM   #95
BMWZ4
BMWZ4's Avatar
1910
Thanks
Thanks for checking much appreciated. I was thinking the same thing...guess you'd have to restore the backup.
      04-25-2017, 08:57 AM   #96
BMWZ4
BMWZ4's Avatar
1910
Originally Posted by Almaretto
Originally Posted by mcwinterr View Post
I installed the iOS app update (available on 11/22/2016), and I still only have access to only 2 coding modules -- - KOMBI and REM (see attached).
There still is no option to choose the 2017 F22 2-Series model (I have a 2017 M240i).
So it appears the FEM, CIC and CSM modules still need to be added by MyCarly.
Do you have to be connected to vehicle to show which ECU modules Carly can code?
Yes
      05-12-2017, 12:07 PM   #97
marcthedark
Drives: M240i xdrive Convertible
Hi,
I looked and looked and could not find the options to:
- unlock doors when engine is turned off
- turn off HU when I open the door
Think the above was possible but somehow could not find the area to do so in the Carly app
      05-13-2017, 08:48 AM   #98
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Originally Posted by marcthedark View Post
Hi,
Pretty sure it's in FEM_BODY module...that's where my "cheat sheet" shows it to be. I did my coding with E-Sys, as Carly wasn't fully functional with the F2x series at the time (March of 2016).
      07-14-2017, 06:46 PM   #99
boostm3
boostm3's Avatar
683
Drives: '18 LBB M2 6MT Exec
For android, can you use the basic Elm327 bluetooth OBDII adapter with Carly, or, does it have to be the white plastic one on their website that says Generation II?
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17
      07-15-2017, 09:38 AM   #100
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
You have to use Carly's Gen II adapter with Carly for BMW on Android to code. It won't work otherwise, and they clearly state that on their website.
      07-15-2017, 10:01 AM   #101
boostm3
boostm3's Avatar
683
Ok, thanks.. Just wasnt sure if it was required to work, or just a highly marked up regular OBDII adapter. Ill get one..
Boostm3
      12-18-2017, 01:58 PM   #102
Danny_Shadow
Danny_Shadow's Avatar
17
Drives: 2024 U11 X1 sDrive20i MSport
New Carly update for iOS - added Video playback via USB port (amongst other things) - I’ve been waiting for this one and can confirm mkv playback all working - nice early Christmas present.
Gone: 1999 E36 316i, 2001 E46 318Ci, 2007 E60 525d, 2014 F32 420d, 1990 E30 320i, 2016 F22 M235, 2018 F20 M140i,2021 G20 320i
Current: 2024 U11 X1 sDrive20i MSport
      02-18-2018, 03:35 PM   #103
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Latest Carly for BMW (Android) now shows ASD as a separate module, and offers the following for my 2016 228i convertible:
Off
Current Value
M3/M4
M5/M6
Rolls-Royce V12
      02-18-2018, 07:10 PM   #104
boostm3
boostm3's Avatar
683
Off
Current Value
M3/M4
M5/M6
Rolls-Royce V12
Does it happen to give you an enable option as well as disable?
Boostm3
      02-19-2018, 03:44 PM   #105
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
The display shows 5 checkboxes...I would assume that if you un-check the box for "off", it will then enable it to the previous setting or let you choose one of the alternates.
