10-23-2016, 08:10 AM | #23 |
Rep 5,105
Yes, phone must be paired to the adapter. They say the car doesn't have to be running, but they do recommend it.
10-25-2016, 03:11 PM | #24 | |
Rep 8,364
I installed the software just to see how far I could get. It is kind of expensive, software plus adapter, just to find out if and what works or wait in hopes future updates will unlock more features. |
10-27-2016, 06:41 AM | #25 | |
Rep 37
Gone: 1999 E36 316i, 2001 E46 318Ci, 2007 E60 525d, 2014 F32 420d, 1990 E30 320i, 2016 F22 M235, 2018 F20 M140i,2021 G20 320i
Current: 2024 U11 X1 sDrive20i MSport Last edited by Danny_Shadow; 10-27-2016 at 06:48 AM.. Reason: Update |
10-27-2016, 06:20 PM | #26 | ||
Rep 5,105
I'd like to know if you were able to code all 4 ECUs?
10-28-2016, 06:19 AM | #27 | |
Rep 37
I have successfully coded the following: KOMBI: - Digital Speedo In Dash FEM: - Stop/Start Memory - Welcome Lights Extended to 90secs - Soft Binks Extended from 3 to 5 (indicators/turn signals) REM: - Door Handle Lights Come On In Reverse CSM: - Disabled Seatbelt Warning For Passenger Seat I'm going from memory on these but will check tonight and update if necessary. What is it you are trying to code? Is the engine running when you try? What error message do you get?
Current: 2024 U11 X1 sDrive20i MSport |
10-28-2016, 06:48 AM | #28 | |
Rep 5,105
My vehicle: 2016 235i, build month Sept/Oct 2015. And yes, engine running while trying to connect to any of those 4 ECU's. Uninstalled the app, re-installed, unpaired the adapter and paired again etc. So really hoping it was the adapter giving me connectivity troubles. Side note: curious if iDrive/NBT will ever be supported. I'd like to add the tire pressures to my iDrive.
10-28-2016, 10:38 AM | #29 |
Rep 30
10-28-2016, 10:49 AM | #30 | |
Rep 37
I think activating tire pressures on NBT is supported currently, i'm waiting for my 2014 M235i buddy to come over so I can test. Unfortunately I've got NBT EVO which is not supported on Carly at present, luckily however I have the tire pressure/temp readings already active. What I really want is to be able to deactivate ASD.
10-28-2016, 11:11 AM | #31 |
Rep 5,105
Danny, your build is roughly 7 months ahead of mine and you have tire pressures 'built-in' to your iDrive/NBT/Evo? Wonder why mine doesn't have that feature. Bizarre. Maybe a European thing...?
10-28-2016, 11:34 AM | #32 |
Rep 1,352
No, it's a Canadian thing. We have FTM (flat tire monitor). The US and I believe the UK have TPMS (tire pressure monitoring). TPMS gives you pressure readings in iDrive, FTM does not. There are advantages to both systems, the primary one for FTM is that you don't need to buy expensive TPMS sensors for every tire if you do seasonal swaps.
BMWZ41909.50 |
10-28-2016, 02:15 PM | #33 |
Rep 8,364
10-29-2016, 01:33 PM | #34 |
Rep 5,105
Tried my replacement adapter. Worse now.
1. Installed new adapter 2. Unpaired old adapter and paired new one 3. Deleted the app and reinstalled newest version 4. Connected to adapter 5. Selected vehicle 6. Selected Normal Speed for data transmission 7. Selected Coding 8. Get message to connect to adapterb (although I WAS connected see point 4) 9. Reconnected to adapter 10. Selected coding again 11. See point 8 And so on. Even tried it on my F25 X3. Same results. Tried with my wife's S5, same results. I'm using SG6 Edge running Marshmellow. I give up....for now. I need a break from having to send in all the logs. There's another new version available today that claims more FEM support.
10-29-2016, 01:38 PM | #35 |
Rep 5,105
Interesting you say that because I reached out to Bimmertech re their USB solution and the reply I got said not compatible with my vehicle due to NBT EVO.
10-30-2016, 09:26 AM | #36 |
Rep 6,990
I'm using an android tablet running 5.2 and not having any issues connecting or reading/writing to and from the ECUs. There have been 3 updates to the android version of Carly in the past week, all of which appear to have added some functionality. I have found that you sometimes have to fiddle with the connection speed and other parameters to get things working.
10-30-2016, 12:54 PM | #37 | |
Rep 5,105
11-17-2016, 10:47 AM | #38 |
Rep 37
Have you had any luck with this since your last post BMWZ4?
11-17-2016, 01:58 PM | #39 | |
Rep 5,105
11-18-2016, 07:32 AM | #40 |
Rep 78
Does anyone know if the Carly adapter is purely a proprietary connection or can it also be used as a general obd2 dongle for some thing like DashCommand app on my iPhone?
11-18-2016, 10:18 AM | #41 |
Rep 6,990
Hard to say - unsure as to whether or not it would work with another application. Their Gen 2 adapter is specifically designed for use with the latest version of Carly to support F-Chassis cars. It may work for some functions, but not for others. Only way to know for sure is to give it a try. Or go to the Carly website and ask their tech support staff.
11-18-2016, 10:30 AM | #42 |
Rep 8,364
Carly uses ELM boards and can be used with other programs like Torque. But, there are also bad knockoffs out there and not all programs are supported.
11-18-2016, 10:42 AM | #43 |
Rep 37
Hi Sleslie,
Are you talking about the Bluetooth (Android) one? or the Wifi (iOS) one? If it's the Wifi (iOS) one i'm happy to try any apps for you. Edit: I've just seen DashCommand is £7.99 on the iOS App Store (theres no trial/lite version). However, I can tell you that the 'Parameters' option in Carly Software is very very similar to DashCommand.
Current: 2024 U11 X1 sDrive20i MSport Last edited by Danny_Shadow; 11-18-2016 at 10:58 AM.. Reason: Additional Info |
Sleslie40.00 |
11-18-2016, 02:48 PM | #44 | |
Rep 78
