2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions DIY: Removing Sunvisor Decals
      07-11-2016, 10:32 AM   #23
mdputnam
mdputnam's Avatar
289
For convertible owners the screw covers are recessed into a hard plastic surround and you can not get a plastic tool in there to pop off the covers. However, there is a slot in the side of the covers. If you insert a small screw driver into the slot and rotate the screw driver, the covers will pop open:
Insert the small screw driver into the side slot
View of the slot with the visor removed and the covers pushed back down.
      07-11-2016, 11:51 AM   #24
tinyTIM
tinyTIM's Avatar
Drives: 2016 m235 xdrive
2016 BMW M235xi  [0.00]
I finally got around to doing this over the weekend. So nice without those annoying stickers. Thanks to the OP for a great write up.
      07-11-2016, 03:50 PM   #25
NEUE02
NEUE02's Avatar
267
Ha ha! My goal is to make the world sticker-less!
The Stable
aerobod3625.50
      07-24-2016, 01:31 PM   #26
Glamdring
Drives: M235i Vert
For those of you that got the sticker off in one piece...Bravo! Mine took a LOT of elbow grease. I bought the 91% solution and left it on, but still had a lot of work to do to scrub it off.
Good news is that I have a convertible, and I saw no need to remove the visors. Open the roof, flip them over, and go to work.
      07-24-2016, 03:52 PM   #27
BentZero
BentZero's Avatar
I let the alcohol sit for 15 mins and got all but the borders up in one piece. I then soaked the remaining borders for another 5 or so mins and then rubbed a bit with a microfiber towel. It definitely took some elbow grease, but nothing major.
Build thread
      08-24-2016, 07:24 PM   #28
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Will try this tomorrow on the other one. The first one took forever today :P
      09-27-2016, 04:03 PM   #29
BEM-S4
BEM-S4's Avatar
Tried this on the new vert, didn't work so switched to goof off which worked like a charm.
New tip for others who may experience the same issue, when I was done I had some wrinkling on the visor almost like the material had stretched. Annoying but not horrible.
Anyway I saturated with VLR then hit it with a hair dryer. Vinyl heated up then shrunk back to original shape, maybe even a little tighter than before. It's got a good memory since it's plastic so with some heat it will go right back to normal.
      09-28-2016, 10:47 AM   #30
mdputnam
mdputnam's Avatar
289
Just a note, we use a lot of 91% alcohol at work. This stuff absorbs moisture out of the air like a sponge. If the relative humidity is above about 40% leaving the lid off the bottle for an hour will turn your 91% alcohol into 70% alcohol and in the process become useless for removing the decal. At work we just put a pin hole into the foil seal and keep the cap on when we're not using it to retard the dilution of the alcohol.
Maynard3848.00
snaketh99.50
Rick4345471.50
      09-29-2016, 07:00 PM   #31
Sleslie
Sleslie's Avatar
Drives: 2017 230i xDrive
I've got a feeling I'm going to slap my forehead over this but what is VLR?
      09-30-2016, 09:16 AM   #32
BEM-S4
BEM-S4's Avatar
I'm sure you could use anything similar or just heat but I had this on hand, figured some moisture may help the process.
https://www.amazon.com/gp/aw/d/B004N...dRL&ref=plSrch
      10-24-2016, 07:39 PM   #33
DuPage
Drives: 228i
air bag decal removal
Can't the decal be removed without removing the sun visor?
      10-24-2016, 07:45 PM   #34
NEUE02
NEUE02's Avatar
267
Yes, but it takes much longer and is more difficult. Much better to remove the visor. It's quite simple and faster in the end.
      10-25-2016, 07:26 AM   #35
BentZero
BentZero's Avatar
Technically, yes, but it'll be a lot messier and harder to do than it would be to just pop them off real quick. I had to let mine soak for close to 20 mins. That would be a pain to try to do in the car.
Build thread
      11-11-2016, 03:05 PM   #36
DanATL
Drives: '89 635CSi, '16 M235i, '23 X5
As I removed the stickers I could not help but think about how cheap and cheesy these visors are. These belong on a Yaris not a $50K car.
Maynard3848.00
      11-11-2016, 06:35 PM   #37
harma24
HA! I had the same thought when I removed the stickers from mine!
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      11-11-2016, 10:53 PM   #38
BentZero
BentZero's Avatar
Lol, totally agree. My first car had better and that was a 1979 Honda Accord hatchback.
      11-17-2016, 10:40 AM   #39
Maynard
Drives: 228iX & M2C
Ditto with the surprising cheapness on these visors - and I'm picturing a station on the automated assembly line where a special robot sharpens the edges with a grinding tool. I think the management made them do this intentional cheapness, so that they could keep a few 4-series buyers.
      11-17-2016, 12:05 PM   #40
krhodes1
Drives: 2011 328i Wagon
2011 128i  [10.00]
2011 BMW 328i Touring  [10.00]
On the bright side, if you want to get rid of those nasty ugly labels the right way, the sunvisors actually are stupid cheap. I think I paid $120 for the pair of them in Budapest while on my Euro Delivery - that includes 20%+ tax. No stickers of any kind on the Euro spec version. Euro Spec visors for my 3-series were more than 2X as much.
The visors are cheap because ultimately this is a cheap car. The hatchback version competes with Golfs in the old country after all. Just because we buy the sexy version with the big motor and all the toys doesn't mean they don't have to save some Euros here and there.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option
'11 128i Convertible - Space Gray on Savannah Beige, 6spd manual,
also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire
      11-24-2016, 11:13 PM   #41
42395_skyline
42395_skyline's Avatar
Drives: 2017 M240i
Just did mine and wanted to just let everyone know who's lazy or impatient, take your time and make sure you use the highest % alcohol and make sure to leave it soaking with a paper towel all over the label for at least 15 min. It comes off with almost no adhesive left over and repeat the process to remove the left over adhesive. I did the second one with this method with great success. I wasted 40 minutes on the first one by being impatient and waiting 5 minutes and then spending 35 min failing at removing the left over adhesive. Tried the above method I mentioned on the adhesive and it just came right off.
      11-29-2016, 08:41 PM   #42
Fugly M3
Fugly M3's Avatar
5076
Drives: 2023 M3CX
Originally Posted by ehagerty View Post
Did mine today ...took me way more than 5 min but I think I purchased some falsely advertised alcohol
Is that cheese cloth? there's a new use for that!
      11-30-2016, 10:32 AM   #43
mdputnam
mdputnam's Avatar
289
I upgraded mine to BMW's carbon fiber M Performance Sun Visors. They were only $880.00 per visor, but I feel it was well worth the improvement in looks and saved 0.3 oz in weight. I'll be doing some acceleration runs to document the improved performance.
BM235iW97.00
DanATL42.50
      11-30-2016, 12:15 PM   #44
BentZero
BentZero's Avatar
Check those cornering g's too since you've lowered your center of gravity.
DanATL42.50
