2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions What's needed to DIY coding for the F22?
      07-14-2014, 12:17 PM   #1
7Defcon
Drives: BMW 228i M Sport
      07-14-2014, 12:31 PM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
Enet Cable search on ebay http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
E-sys software (ask here http://www.bimmerfest.com/forums/sho...38188&page=121)
token for e-sys (you can buy from one of the links in the e-sys installation instructions)
my cheat sheet :-D https://drive.google.com/file/d/0Bwv...it?usp=sharing
NCD CAFD tool http://www.bimmerfest.com/forums/sho...&postcount=108
Whatever you do never ever ever press "Code Default Values" ... you have been warned :-)
good video
File Type: pdf FA (VO) Step-By-Step (MWPos) 8-24-2013.pdf (1.05 MB, 1378 views)
      07-14-2014, 01:15 PM   #3
7Defcon
lol thanks for the heads up and the help! I wonder if I can get it coded so that I can do every feature while driving, such as play a DVD video or other features. Just so my passengers can watch on my next road trip.
      07-14-2014, 01:32 PM   #4
pikcachu
pikcachu's Avatar
1403
ya you can code DVD in motion... look at the cheat sheet and also play video from USB stick instead of DVD and DivX and other video formats
      08-09-2014, 07:05 PM   #5
mikeyymonster
mikeyymonster's Avatar
Drives: 2021 M2C
Just ordered my cable! How exciting! What happens if you press code default values? I'm assuming just back to stock?
      08-09-2014, 07:11 PM   #6
Xmas
Drives: 228i
no matter what you do, DO NOT PRESS CODE DEFAULT VALUES.
Make a backup copy before you do anything coding.
      08-09-2014, 09:48 PM   #7
pikcachu
pikcachu's Avatar
1403
Do not press "Code default values"... to go to factory settings you use "Code" (also know as VO code) instead of "Code FDL"
If you use "Code default values" you might have to have your car towed to the dealer as it might not start back up....
Really good video here
      08-13-2014, 07:41 PM   #8
7Defcon
I'm stuck at the part where I need a token. Not sure exactly where to get it. I've gone through most of the instruction PDFs.
      08-13-2014, 07:53 PM   #9
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Look at the "How To" instructions for obtaining your token. This will need to be purchased to activate the changes to your car. It is always good to take a backup of the FA and VO everytime you have a coding session. This will give you a good point in time should you need to undo a previous change. Copy the backup to another device like a thumb drive and store it away from your computer.
      08-14-2014, 02:09 AM   #10
mikeyymonster
Drives: 2021 M2C
In the event something goes wrong, how does one restore the data from a working backup of the ncd files? I'm assuming you copy over all the files (ovewrite) from your backup to the CAF folder, and then what action will need to be done on Esys?
      08-14-2014, 10:57 AM   #11
pikcachu
pikcachu's Avatar
1403
No need to overwrite....
Open esys and then either load a backed up SVT or you need to do "Read SVT" then for the ECU's CAFD you want to update just do right click - New - FDL and pick the backed up ncd file... make sure you pick the right one else it won't load values meaning you can't load the FEM_BODY ncd into the HU_NBT... then right click the CAFD again and do "Code FDL
and do the same for each FDL you want....
Also if you just want to go back to the factory setting you code VO code the whole car and will reset any custom coding...just select the top "SVT" root and click "Code"
BY NO REASON EVER CLICK "CODE DEFAULT VALUES"
      08-14-2014, 11:00 AM   #12
Cybertronic
Drives: G30 M550i, E30 M3
Even though the software is readily available on the net...
You need to be extremely careful when working with E-SYS! You can brick your car.
You'll then either have to play dumb, or beg the service people at the dealer to fix it.
Make backups, move slowly, and understand what you are going to to, BEFORE you do it.
Anyone in the CA Bay Area, I'm happy to help you set up and give you some tips on your coding setup, or do coding for you (for free!)
      08-14-2014, 12:09 PM   #13
TaiChiSteve
TaiChiSteve's Avatar
Drives: 2015 M235i EB/Terra
Cybertronic,
Im not in the Bay area but am interested in coding myself when my car arrives shortly. Can you elaborate on where to get the software.
thanks..
      08-14-2014, 12:10 PM   #14
pikcachu
pikcachu's Avatar
1403
it's in the 2 post http://www.bimmerfest.com/forums/sho...38188&page=121
      08-14-2014, 12:27 PM   #15
TaiChiSteve
Thank you pikcachu
      08-18-2014, 09:47 PM   #16
BRM6
BRM6's Avatar
Brazil
11
Drives: 328/335/M235i/M4 - Current M6
Great info. I have had my cable for the F30 335, but never tried. I'll try it and then do it for my M235i Thanks
      08-25-2014, 06:30 PM   #17
barukdaddy
system requirements
GREAT info in here, thanks pikcachu. For somebody who's not a programming genius, do you know what minimum system requirements I would need on my laptop to run E-SYS?
      08-25-2014, 06:44 PM   #18
pikcachu
pikcachu's Avatar
1403
you will need about 8GB of hard drive space for software and pdzsdata, and esys uses about 1GB of memory to run smoothly
      08-29-2014, 09:04 AM   #19
jgunnz
jgunnz's Avatar
31
Great info, as always pikachu. Thanks!
One more question: How much does the software token cost?
      08-29-2014, 10:07 AM   #20
pikcachu
pikcachu's Avatar
1403
i think it's about $60-80
      09-23-2014, 10:38 AM   #21
HondaGoneRogue
They like my Swag...
HondaGoneRogue's Avatar
433
Drives: 15 GSM 435i GC
Awesome stuff.
2015 435i Gran Coupe - Current
2008 AW 135i - Sold
      10-02-2014, 03:35 PM   #22
lazyrhino
lazyrhino's Avatar
United Kingdom
58
Drives: BMW M4 Competition Package
Any advice on coding the Enhanced Bluetooth (6NS)? My M235i is coming with Pro-Nav (ZNP), but not Enhanced Bluetooth. Would love to get this sorted.
I've got an ENET cable on its way to me, and ready to go with all the E-Sys tools (got version 3.25.3, with token and pin, and PSdZData 52.1).
