02-04-2016, 06:01 PM | #23 |
Rep 444
Yes, the fronts have a small lip you can roll.
Quickest Stock Turbo F8x In The World
02-05-2016, 02:02 AM | #24 |
Rep 1,503
post pics when they're on the car
FBO M235i r
F80 M3 |
02-05-2016, 09:59 AM | #25 |
Rep 12
Dinan's S3 prototype uses the following setup. They claim there is no rubbing. It also has the standard Dinan drop. They also say that they will be switching to the BBS CI-R as soon as the 19" are ready, which should be soon.
Wheels: Front: 19 x 8 ET 40 – BBS CH-R (custom modification) Rear: 19 x 9 ET 44 – BBS CH-R (custom modification) Tires: Front: 245/35-19 – Michelin Pilot Super Sport Rear: 265/30-19 – Michelin Pilot Super Sport Article with pics is here: http://www.autoblog.com/2015/09/18/2...i-first-drive/ |
02-05-2016, 02:40 PM | #26 | |
BMW Lover
122
Rep 251
Thing is what are the (custom modification) |
02-05-2016, 03:15 PM | #27 |
Rep 1,503
Possibly modified offset?
FBO M235i r
F80 M3 |
02-06-2016, 11:19 AM | #28 |
Rep 12
This is what Nathan at Dinan said. Can probably get more info from him:
"The custom modification we did was something to the center mounts to make it fit properly if memory serves. These wheels natural application is for the old E8x 135i but they didn’t work naturally on the M235i for reasons I don’t recall. The engineering guys are off on Fridays so I don’t have anyone to lean on for specifics on that. Ultimately we will be offering a CIR instead of a CHR on the 2 series as the CHR was never meant for the 2 series." |
02-06-2016, 03:32 PM | #29 | |
BMW Lover
122
Rep 251
02-06-2016, 11:11 PM | #30 |
Rep 444
Well for a 19x9.5 +40, 265/30/19 will fit. I put my rim on the car and there is over an inch of clearance from the rim to the suspension. A 265/30/19 MPSS will be about 0.3 inches closer to the suspension. You could get another half inch of clearance towards suspension if you cut the shock cover, which someone on these forums already has. The only downside is that you will have some poke, about a half inch out.
02-06-2016, 11:38 PM | #31 | |
Rep 1,091
previous: 2003 E46 330i SMG
02-07-2016, 12:20 AM | #32 | ||
Rep 1,503
The best advice I ever got going into this (my first time doing aftermarket wheels) is that you need to be willing to do modifications to make an aggressive fitment work; whether it be alignment, body work, etc. What fits on someones 2 series may not actually fit on yours, cars could come with slight factory variance in alignment specs. Quote:
FBO M235i r
F80 M3 |
BM235iW97.00 |
02-08-2016, 08:24 AM | #33 |
Rep 219
19x8.5 et40 F and 19x9.5 et45 R
235/35R19 and 265/30R19 Hankook Evo2 V12 Test drove them, no rubbing on the rear.. but it did rub up front.. Gonna have my fenders rolled. I'm on H&R Springs |
02-08-2016, 08:48 AM | #35 | |
Rep 893
2019 SG M5C
02-08-2016, 10:11 AM | #36 |
Rep 219
02-08-2016, 11:01 AM | #37 |
Rep 3,129
Custom modification was back-trimming the rear center section effectively changing the offsets. The standard wheel offsets are et 40 / et44 on the BBS CH-R. With the 1-off modification the offsets are et45 / et48, which is the new standard offset for the 19" CI-R's that are coming out.
02-08-2016, 05:46 PM | #38 | |
Rep 444
02-08-2016, 06:36 PM | #39 |
Rep 1,503
It's hard to say how much the 30 profile will help you, your rolling radius is probably close stock. Get the wheels and tires on the car, then you might see what I mean. I'm just surprised that you would get such an aggressive offset when they make proper 1/2 series fitments. You also need to consider the shocks under load. If it gives you the look you're going for, more power to you
FBO M235i r
F80 M3 |
02-08-2016, 06:45 PM | #40 | |
BMW Lover
122
Rep 251
02-08-2016, 06:46 PM | #41 |
BMW Lover
122
Rep 251
Bro, so you Reckon that 225 up front won't Rub on this setup, plus Hankook has a smaller footprint than PSS am i right ?.... Car Looks sick by the way !
02-08-2016, 07:04 PM | #42 |
Rep 3,129
02-08-2016, 07:17 PM | #43 | |
Rep 444
The 19s will only fill the wheel wells by an extra 0.2 inches. I've tested the spring compression with 700 pounds in the rear and they don't even compress an inch. Also the AG M510s in 35/40 are 500 cheaper then going custom offsets. and if they don't look right on the M235i, I can always put them on my Z4M. lol.
02-08-2016, 08:04 PM | #44 | |
Rep 1,422
