Recommendations for M235i winter wheel/tire setup. What did you do? |
08-29-2016, 03:22 PM | #89 | ||
Rep 886
There is a noticeable decrease in handling ability, which realistically translates to "you can't drive like a jackass on winter tires". There's little (if any) handling degradation at legal speeds on just about any road. Stopping is the real difference. Snow tires will stretch stopping distance in the dry perhaps 15% or so over all-season tires. Trade that off against taking back about the same advantage on snow and taking 30% to 50% off the stopping distance on ice and it becomes a more complicated decision than a simplistic "go with what you see the most" screen. References: http://www.edmunds.com/car-reviews/f...vs-summer.html http://www.tirerack.com/tires/tests/...y.jsp?ttid=116 http://www.tirerack.com/tires/tests/...y.jsp?ttid=103
08-29-2016, 04:20 PM | #90 |
Rep 5,372
If I lived further north or in an area get a lot of snow and/or snow/ice stays on the road, then I'd reconsider. I guess my point is that many have been sold on this idea from the Tire Rack and auto forums that if it snows in your town and temps in the winter are routinely below 40, then you MUST have winter and/or snow tires. I feel that you need to evaluate the typical conditions you will drive in the winter to determine if winter/snow tires are appropriate or are overkill. Preparing your car for the worst-case at all time is a poor approach because you're compromising it's abilities in the more common road conditions. Listen, I'm not saying run summer tires in winter conditions or that any all season tire will do. If you live in Buffalo, NY, and you plan on driving in the winter, you probably need snow tires. If you live in NJ, you probably need winter or snow tires. If you live in Kansas City or St. Louis, you can likely get away with a good set of all seasons or a more performance focused winter tire.
Yes, I technically roll the dice by driving in the snow with less ideal all season rubber vs running winter/snow tires. HOWEVER, the same can be said for driving in warm (60+ degree) dry weather where the ideal performing tire would be R-spec street tires. Running R-Spec rubber in the more common spring and summer conditions (dry and warm) could very well save you from getting in a wreck just like winter/snow tires in winter conditions. R-spec rubber will stop faster and grip far harder in an avoidance turn than the MPSS tires and definitely those Pirelli C7s. Why the discrepancy in rationale? They both accomplish the same thing. |
08-29-2016, 04:41 PM | #91 | |
Rep 860
When was the last time you heard a wreck could have been avoided with R-spec rubber, and the person was not driving aggressively to begin with? That would be pretty rare. That's like trying to take the position that using winters tires is analagous to the suggesting everyone should be driving a Lotus Elise instead of a minivan because the Lotus handles better and will therefore be better at avoiding collisions. |
08-29-2016, 08:50 PM | #92 | |
Rep 222
08-30-2016, 12:11 PM | #93 | |
Rep 5,372
DRitch9.50 |
08-30-2016, 12:30 PM | #94 | |
Rep 3,395
I also live on a wicked hill and am looking for a reality check from folks that really do drive a RWD 2 series in REAL snow. Am seriously considering a set of Hakka 7/8's that are studded and carrying a set of snow cables/chains I can avoid the majority of tough days by driving a 4x4 but..... |
08-30-2016, 01:22 PM | #95 | |
Rep 6,033
If 3 season driving were as filled with external risks to the degree winter is, perhaps we would need improved 3 season tires, but we don't see folks unable to stop and turn, or simply maintain control in a straight path (if not driving recklessly to begin with). But, even if you are being the most cautious driver, your ability to maintain control without winter tires for that one season is dramatically compromised if some other vehicle suddenly appears in your path. That simply does not happen anywhere close to that same degree at other times of the year. You are fortunate not to have had such a situation yet. But, under the same philosophy that has most of us maintain fire insurance, but never had a house burn down, we find it wise to be a bit more cautious in the one season which stands out for greater risk.
Deutsche-Broke109.50 |
08-30-2016, 02:12 PM | #96 |
Rep 2,214
I don't think I could drive my car in the winter here, even if I wanted to
08-30-2016, 11:21 PM | #97 | |
Rep 154
Forget the studded snow tires and chains which destroy any winter driving enjoyment, and simply buy the AWD 235/240, and put a good set of high performance snows on it. |
08-30-2016, 11:22 PM | #98 |
Rep 154
08-30-2016, 11:36 PM | #99 |
Rep 154
I may now have a change in situation that I can see it potentially altering my requirements for the winter tires to a degree. And would appreciate your thoughts. I was called into my boss's office yesterday, and informed that both he, I, and our department are being outsourced by the corporation. I am only there to assist in transition until November 1st. Then I am being pushed into early retirement. All things considered, it's not a bad thing given where I am, though still a bit of a shock.
Based on that I will not be in a position where I have to navigate through snowstorms to get to and from work, I can sit home and wait them out. I certainly won't be driving near as much since there will be no five day a week work commute. When I do travel up and down the significant hill that I live on, and the ones that lead to it, it will likely always be when the roads are cleared or at least, in the case of my hill, is surfaced with a solid, packed down snow base. In a perfect world, I would like the highest performance winter tires possible to allow me to enjoy the M235i's handling and braking on the 75% or more days where the roads are dry, or no more than wet. Now I only need to balance that with selected trips out onto the roads, of my choice. I'm thinking that should ease the requirements a bit more to less hard core winter tires. I'm thinking it may open the doors to the Sottozero 3, or most likely, the Pilot Alpin. Am I right? I would appreciate any thoughts as to my best option given what I have described above. Thanks. |
08-31-2016, 07:58 PM | #100 | |
Rep 6,033
My situation changed, as I was recruited to an office job again. I decided that I wanted to spare my 2 the risks and rigors of being in the snow/ice/salt, as it has been pointed out that we may be seeing the last of the choices of manual transmission cars....so I got a winter car (Subaru Crosstrek on Bridgestone KO2 in winter - snowflake all-terrain), so I didn't even put on my winter setup on the 2 this past season. Haven't decided to sell them, as I like to have the capability available, just in case.....there's a pattern to my thinking!!! LOL!
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 08-31-2016 at 09:18 PM.. |
08-31-2016, 09:16 PM | #101 |
Rep 5,874
Here's how much I like my PA4 on VMR setup... I actually look forward to mounting my winter set. 225 front 255 rear and handles and grips like a dream in cold wet, dry, and snow. Like PSS for the winter.
And BTW they do not wander in the slightest. |
09-01-2016, 09:20 AM | #102 |
Rep 860
I assume the comment was directed at me.
I realize that it appears I'm the only one who is experiencing the wandering, but unfortunately that has not helped me resolve the issue. The one thing I did do differently than you was not to go with the staggered size tires on the staggered wheels. Could that be causing the issue? I would be surprised if that's the case, especially since we are talking about the rear tires only, but at this point I don't know what else the solution might be. Again, this is not just a minor amount of wandering...pretty much anyone driving the car would notice it. |
09-02-2016, 02:43 PM | #103 |
Rep 6,033
If anyone is still looking for a winter set-up, especially around Michigan, please go and check out the Classifieds!
raleedy160.00 |
09-03-2016, 10:52 AM | #104 | |
Rep 5,874
09-03-2016, 12:48 PM | #105 |
Rep 154
09-03-2016, 12:50 PM | #106 | |
Rep 154
JC |
09-03-2016, 12:51 PM | #107 | |
Rep 154
JC |
09-03-2016, 02:19 PM | #108 |
Rep 6,033
This is highly speculative and I doubt it. I've successfully used a square tire set-up on staggered rims with no issues. This car needs a more thorough root cause analysis. I would suggest avoiding staggered winter tires as it causes one pair to be wider than necessary, directionally incorrect for winter.
09-03-2016, 02:53 PM | #109 | |
Rep 154
JC |
