2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 17" Kosei Square Track Wheels Fitted
      02-08-2015, 06:58 PM   #45
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
M235i
Originally Posted by rich8566
I did about 10 track days last year with my M235i. I love the car in the track and although I love the grip of the PSS's, they do wear the fronts more than the rear. That's why I'm going with a square setup with the Kosei's this coming season.
The Glen and CCANY
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
      02-08-2015, 07:12 PM   #46
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
damn... you got corded
what psi where you running ?
      02-08-2015, 08:18 PM   #47
rich8566
rich8566's Avatar
Drives: M2 + Z-4
42-44 hot.
      02-08-2015, 08:47 PM   #48
pikcachu
pikcachu's Avatar
1403
42-44 hot.
i see ... all around?
looks like you lost a wheel cap too
      02-08-2015, 08:51 PM   #49
rich8566
rich8566's Avatar
Drives: M2 + Z-4
42 front 44 rear with the staggered setup. And yes, I lost two front caps.
      02-08-2015, 09:04 PM   #50
Supernaut
Little Deuce Coupe
Supernaut's Avatar
Drives: SO M2C
42-44 hot.
Damn, you have to crank those up, don't you?
So, aside from BMW's underlying issues with camber, don't other high performance tires have less roll over than the PSS at the same pressures?
Also, since a square setup will reduce the understeer, at some point, burning through the front tires so fast has got to make it worth springing for matched wheels.
I'm debating myself on how best to manage this along with a camber fix like camber plates or the longer lower control arms, so I appreciate all the input here.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD
2020 Sunset Orange M2C|6MT|Black 788s
      02-08-2015, 09:14 PM   #51
pikcachu
pikcachu's Avatar
1403
i think a dedicates set should be worth it, specially with a square non-directional tire... so you can rotate left-right and front-rear
it won't prevent it from wearing the outside but at least you can manage to wear the set more evenly...
also i would imagine that with bigger tire in the front you should get more grip and maybe should put less wear on the shoulders?
      02-08-2015, 09:17 PM   #52
rich8566
rich8566's Avatar
Drives: M2 + Z-4
I'm hoping I'll be happy with the square setup because dang those PSS tires really do grip and they inspire a lot of confidence with their great feel.
      02-08-2015, 09:54 PM   #53
Ramos
Ramos's Avatar
Drives: G20 2020 M340
I've decided to buy the wheels. I'm going with the Team dynamics rather than the Kosei's . I'm conservative when it comes to wheel fitment at the expense of being limited to 245's
To answer your comment, the PSS's are great street tires / all around, but you can definitely get more grip with extreme summers such as the RS3's or even Michelin's own PS cup tires.
      02-08-2015, 10:05 PM   #54
pikcachu
pikcachu's Avatar
1403
Do you have a link for the wheels?
      02-08-2015, 10:27 PM   #55
Ramos
Ramos's Avatar
I haven't bought them yet, still shopping for the best deal.
So far I found them at outmotoring.com for $221 each
Team dynamics pro race 1.2
8.0 x 17
ET 40
5x120
73 mm bore
They have different colors too.
I think this site is mostly for mini parts.
Let me know if you find a better deal. I'll do the same
      02-08-2015, 10:31 PM   #56
pikcachu
pikcachu's Avatar
1403
8.0 x 17
ET 40
5x120
73 mm bore
ok...wonder what the weight is on those... the Kosei are 15.5lbs but looks like they are out of stock on tirerack now
      02-08-2015, 10:47 PM   #57
pikcachu
pikcachu's Avatar
1403
also any of you getting TPMS for the track set ?
      02-08-2015, 10:59 PM   #58
Chris in Japan
Drives: BMW M135i on order
8.0 x 17
ET 40
5x120
73 mm bore
I bought these exact wheels from www.demontweeks.com in the UK. I think they were around 450gbp for the set. Shipping was pricey though...
      02-08-2015, 11:19 PM   #59
Ramos
Ramos's Avatar
Yes Chris, I only found out about these wheels from your post.
Thank you
Can you answer how much they weight and whether you like them so far?
      02-09-2015, 01:52 AM   #60
Ramos
Ramos's Avatar
Ok update
Found them at bimmer world for $210 each and they weight 20.5 lbs according to them.
While that's 5 lbs per wheel more than the Kosei's, and pretty heavy for a 17 inch wheel, I'm convinced they will be a lot tougher and stronger.
Also TPMS would be nice since we have the ability to actually see the PSI of each tire in the M235 which is super useful on track.
Are the TPMS universal to any wheel?
      02-09-2015, 12:12 PM   #61
pikcachu
pikcachu's Avatar
1403
you can see temperature too... if you have it coded...
but not sure if it is worth it $300 of TPMS to see it on a dedicated set
      02-11-2015, 10:06 PM   #62
Chris in Japan
Thank you
I believe the weight is 9kg, Although I didn't actually weight them myself. Love the wheels, and very sturdy.
      02-15-2015, 04:55 PM   #63
Gepeto
Originally Posted by ska///235i View Post
Thanks a bunch
This is very informative for those seeking winter setups
(Sorry i know this was for track setup)
On a side note
Tirerack states that the BBS RS works for the m235i
17x7.5
Et 35
With 225/45/17
I can confirm, I run that size and offset of BBS SR for Winter. Fitment is perfect.
      02-22-2015, 08:29 PM   #64
CC ///M GUY
CC ///M GUY's Avatar
Drives: 2016 BMW 340i
I'm running these for winter! Like em a lot!
      02-23-2015, 08:53 PM   #65
rich8566
rich8566's Avatar
Drives: M2 + Z-4
I got the Kosei's with the TPMS since I'm also using these wheels for my snows. It drove me crazy watching the yellow light without the monitors in my prior E90 winter setup.
      02-23-2015, 09:49 PM   #66
pikcachu
pikcachu's Avatar
1403
I got the Kosei's with the TPMS since I'm also using these wheels for my snows. It drive me crazy watching the yellow light without the monitors in my prior E90 winter setup.
I see...
On a side note, you bastards made Tirerack to go out of stock for the Kosei's
