09-03-2014, 07:00 PM | #23 | |
Rep 586
09-03-2014, 09:20 PM | #24 | |
Rep 104
09-05-2014, 12:08 AM | #25 |
Rep 34
For winter tires you want to go with a narrower tire and more sidewall on a smaller wheel. That being said, if you want a high-performance (Y speed rating) winter tire to keep on 18s I can vouch for Yokohama W.Drive. I had it on my last car and will likely be getting them for this car.
09-05-2014, 07:15 AM | #26 | |
Rep 142
09-05-2014, 07:28 AM | #27 |
Rep 75
Anyone have any thoughts on 17" Anzio Turn wheels ?
Other thing, living where I do there is too much day to day temperature swing in spring and fall to use a summer tire and a winter tire. I would need a flippin pit crew to track weather reports & follow me around, & the drive south for vacation thing would not be ideal, guess you'd throw on the winters to be safe and then watch the car get shorter each day when you hit 80 + degree weather. Am going to go for a three season tire & wheel set 6 months out of the year & else run the OEM wheels with the summer only PSS. Second question, would like a good all season that is as good as I can get for winter conditions (I understand that I'm just not a gonna get winter tire performance with an all season, but I can't afford the pit crew and only have to deal with snow and ice a few days per year) , anyone have experience with continental DWS tires or something similar? |
09-05-2014, 05:29 PM | #28 | |
Rep 34
You have to get a tire based on your driving conditions. If I was living in a rural area I would get a 17 inch wheel with a tire that has deep treads & studs. In a metro area, with high mileage, a high performance winter tire similar size to stock will out-perform the 17s by a long shot in acceleration, cornering, and overall tread-life. The 17s with deep tread will squirm & squeel on dry pavement and studs will provide less traction in the dry. TLDR: Pick the tire that most suits your conditions and drive it within its limitations. |
09-07-2014, 11:42 AM | #29 |
Rep 878
09-08-2014, 03:35 PM | #31 |
Rep 5,577
09-08-2014, 03:41 PM | #32 |
Rep 878
1100 euro's +29 for shipping. Staggered. I want the car to look the same in winter The rear winter tires are hard to find for the 245 size. The fronts are easy and much less expensive.
09-08-2014, 07:27 PM | #33 |
Rep 75
09-08-2014, 08:02 PM | #34 |
Rep 5,577
09-10-2014, 02:16 PM | #35 |
Rep 878
09-10-2014, 04:13 PM | #36 |
Rep 5,577
09-11-2014, 09:00 AM | #37 |
Rep 878
Confirmed the car does not need new sensors. I have the price for the 1 sensor for the system. I will again engage on this tomorrow at the dealer again. Im changing the oil and doing a full 4 wheel alignment.
09-11-2014, 09:18 AM | #38 | |
Rep 75
http://www.oewheelsllc.com/TPMS-Sens...r#.VBGubEt1Q-Y |
09-12-2014, 12:51 AM | #39 |
Rep 10
Sorry if this seems like a silly question, not living in a cold climate that needs Winter tyres.
Are the winter tyres Run Flats ? If not, what do you do in the event a flat |
09-12-2014, 02:10 PM | #40 |
Rep 878
Scott it was incorrect. The car needs 4 sensors(of course I had a feeling he was wrong ) So the sensors are 58 euros each and have been installed in the new wheels and now fitted with the Pirelli winter tires.
09-17-2014, 05:23 PM | #41 |
Rep 347
Has anyone driven on the Nokian WRG3 (or G2)?
My plan is to get Blizzak WS80, but these Nokians just came up on the radar. The WRG3 is an all-weather (not all-season) winter-rated performance tire that gets a top rating from Consumer Reports against dedicated winter tires. http://www.consumerreports.org/cro/n...ance/index.htm I'm in a warmer location (by Canadian standards) with typically fewer snow/ice days. If these perform to spec, they would be an ideal balance of performance, fuel economy, wear and traction.
F22 * (N55 + 6MT) ÷ PSS = FUN
09-18-2014, 05:12 PM | #42 |
Rep 326
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
Ordered and got mounted a set of Blizzak LM32's 225/40-18 non-RFT. Mounted them on used 135i style 264 wheels. These fit my 228 fine and should fit 235's with bigger brakes. the 264 wheels have about the same clearance as the stock 18's on my 228 Msport. These wheels are readily available on the 1 addicts forum and I found mine on Craigslist. Typically a good set will go for $400.
09-20-2014, 06:57 PM | #43 |
Rep 765
Okay, so I SUCK at knowing spacing, sizing, etc on wheels. I know the math, but I don't care to do it all the time. SO .. my question ..
As I shop for a winter set of wheels, what are the minimum spacing requirements for a set of 17" wheels? Offset, wheel size, etc? I just need to know what specs I need as a minimum when shopping used wheels. I plan on having 10 and 12mm spacers on the stock M235i wheels, so I can at least accommodate some wheels without the requisite offset.
09-22-2014, 02:04 PM | #44 |
Rep 25
Any thoughts about these from www.replika.ca? According to their website, these 17x8.0" will fit the M235i.
