01-29-2023, 05:55 AM | #1 |
Rep 24
New battery needed???????
Morning
My partners 2018 2 series coupe came up with a battery discharged warning yesterday. I checked the voltage and it was 12.02 after being sat for a few hours. Checked startup which dropped to 9.45 which i know is low. When running and charging it's around the 14.6 with all electrical turned on etc. Took it for an hours drive with everything turned off to allow for a proper charge. Checked voltage this morning and its at 11.98. Does this mean I need to get battery changed or could it be something pulling the voltage down over time? Thank you |
01-29-2023, 08:47 AM | #2 |
Rep 1,264
Sure sounds like the battery is going bad. This is what I recommend: https://www.fcpeuro.com/products/aut...vD_BwE#fitment
01-29-2023, 02:44 PM | #3 |
Rep 442
What is the voltage on the battery when car is powered off after running for a while? An AGM battery should be around 12.6 V when in a charged resting state. If it's below that, you have bad/failing cell.
If it's at ~12.6 V when the car is off, it could be failing battery, or it could be a high-drain scenario. The acid test is to put an amp meter on it, with the car turned off. Keep in mind it can take up to 20 minutes for all iDrive components to finally fall asleep and get an accurate resting draw. It can be useful to monitor voltage during this falling asleep process also to watch for dropping voltage. It shouldn't change much. After 30 minutes, you should see less than 100 milliamps of current draw. If it's more than that, something is sucking up too much power when it should be off. Also, how old is the battery? An original BMW battery will have a date code stamped on one of the posts with the month and year of production. If it's over 6 years, you are probably due to replace it. |
01-30-2023, 10:01 AM | #4 |
Rep 24
Thanks very much for the replies I'll try what you recommended, much appreciated. Also reading up on battery replacement it says you have to register the new battery with the on board computer. Never heard of this before. The hardware/software to do this is like £100. Doesn't seem right to me
01-30-2023, 10:36 PM | #5 | |
3626
Rep 3,594
Danny81bby0.00 |
01-31-2023, 06:44 AM | #6 | |
Rep 1,146
get a solar BA9 to test,
make sure the car is asleep otherwise any tests you do are pretty much worthless with a meter on my channel I have a longer version of this Quote:
Danny81bby0.00 |
