2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Lighter Socket Issue
      05-25-2019, 08:00 PM   #1
KjPerry
KjPerry's Avatar
Drives: 2016 BMW M235i xDrive
Hi,
Bought a USB adapter to use to charge my phone through the lighter socket in the front. I go to plug it in and no charge.
I confirmed that it is the indeed the cigarette lighter socket itself and not the phone or parts i am using.
Any idea what this issue could be or where i can start?
Would appreciate the help.
Thanks in advance.
      05-25-2019, 11:44 PM   #2
bmtespar
bmtespar's Avatar
Drives: 19 X3 30i, 18 230iX Vert
Originally Posted by KjPerry View Post
Hi,
Thanks in advance.
Next suggestion would be to check the fuse in the fuse panel.
Current: 20 M340i
Sold: 19 x3 30i X drive, 18 230i X drive Convertible
18 x3, 30i X drive 16 428i Convertible, 16 X1 X drive, 14 i3 Rex, 14 328i, 14 x1 28i X drive, 08 328i, 03 M5, 99 323i Convertible, 00 z3 M Roadster, 99 328i, 00 323i
nazali1313.50
      05-26-2019, 02:16 AM   #3
overcoil
Drives: M235i 6spd
There is second power outlet in the trunk - chk to see it that second outlet charges your phone.
At least u have the usb in the center console to use.
      05-27-2019, 11:30 AM   #4
knyghtryda
Drives: 2018 M240i M Performance Ed.
The front socket geometry is slightly weird and I've found that it won't work with every USB charger. Try the backseat socket or the trunk socket and see if your charger works. I have a 4 port USB charger that works fine from the backseat but refuses to work in the front socket. Hope this helps!
      05-27-2019, 12:17 PM   #5
aerobod
aerobod's Avatar
3626
The problem is the BMW 12V socket is manufactured to the ISO 4165 20mm specification, but the plug is likely to be to the SAE J563 specification (which is more common in North America), they are similar but not the same and with manufacturing tolerances sometimes don't make good contact.
ggggbmw432.50
nazali1313.50
MLJR235116.50
      05-27-2019, 01:47 PM   #6
Aspen235
Drives: 2014 X3 35i, 2018 M240i 6mt
Stick a dime in the bottom of the socket. I tried several chargers before figuring out that the socket is deeper than most chargers can reach. The dime raises the contact point enough and doesn't short it out. Fixed for $0.10.
MLJR235116.50
      12-21-2022, 03:07 PM   #7
MLJR235
MLJR235's Avatar
117
Drives: M235I
I know this is a bit old but just want to say it worked 100% as noted..
Can't get over it how simple the "fix" was. It's been such a nuisance not being able to use the charger in this location i gave up all hope. Thanks Aspen for the awesome hack!
'15 235i - Moddedededed
      12-22-2022, 07:25 AM   #8
nazali
nazali's Avatar
Drives: 230 2020 vert F23
^^^ this OR the fuse, use a meter or try another device
      01-30-2023, 10:09 PM   #9
AxiomF22N55
AxiomF22N55's Avatar
13
2016 BMW M235i  [0.00]
Don't do this. I caught my dad's car on fire doing this when I was a kid. LOL
