08-02-2019, 07:42 PM | #1 |
Supreme Allied Commander
3815
Rep 54,319
Drives: F80 M3
BMW Akrapovic M240I (F22, F23) 2019 Evolution Line (SS)
BMW M240I (F22, F23) 2019
Evolution Line (SS) MTP-BM/SS/4H EC CARB RP power +4.8 kW at 5500 rpm torque +12.6 Nm at 3000 rpm weight -0.7 kg The Evolution Line exhaust system will propel the BMW M240i to the next step of performance tuning due to an increase in torque and power. Impeccably designed to fit perfectly within the lines of the car, this austenitic stainless steel system is finished with hand-crafted carbon-fibre tailpipes to increase the visual impact. It has a layout incorporating two central link pipes to replace the stock single version, designed for optimum flow of the exhaust gases. A dual-mode ECU-controlled valve manages the sound levels, which ultimately delivers a deep and fulfilling sporty note as the revs rise. EC-compliant and easy to install, the Evolution Line system is a perfect accompaniment to an already spectacular car. $3215.06 Order here: https://www.hpashop.com/Akrapovic-BM...Akra-M240i.htm |
