07-22-2019, 08:21 AM | #23 |
Rep 197
Well BM3 is a standard 600$... Jordan charges 500$... I just raced an M2C 3 times, won each time (80mph+ pulls).... Still not even done with revisions and the car is pulling! Last race was the biggest difference, meth injection >>>>. Another cool factor is my 164mph speed limiter is gone. Went like 175mph or something easy. Also he got the tune nearly complete in 5-6 revisions. From personal experience, Twisted Tuning takes 20+ revisions and goes ghost on you and doesnt even extract full potential. There is a reason Jordan is 500$ and Twisted is 300$. The support, quickness, and knowledge Jordan brings is worth the premium. He is actually one of the co developers of BM3 and has been in the industry far too long lol. to Jordan!
Dylan861330.00 |
07-24-2019, 03:54 PM | #24 | |
Rep 2,214
jondagger90.00 |
07-26-2019, 08:06 AM | #25 | |
Rep 1,184
I don't have bm3 yet. So I essentially buy bm3 for approx $600, and then a map from Cary for approximately $500 or whatever he ends up charging? Or are you saying you can buy bm3 through him with his tuning service included? I figured it was both individually, so somewhere in the ballpark of $1100 total? Definitely going to be looking into this soon. I've still got some parts sitting in the closet that I'd like to get installed first though. |
07-26-2019, 08:41 AM | #26 | |
Rep 197
08-14-2019, 08:36 AM | #27 | |
Rep 1,184
I have pure inlet, dv+, and vrsf tic in the closet. Just haven't had time to install. I know none of those should make to much of a difference unless my dv is failing.... But prob best to have them all in place before starting to tune. |
08-14-2019, 12:44 PM | #28 | |
Rep 197
08-14-2019, 07:43 PM | #29 |
Rep 151
Cary Jordan and I will be making a record breaking N55 in my F23 (yes, convertible) M235i in the next few months. Upgraded turbo. Upgraded LPFP and HPFP. Caged! Stay tuned... ☺️
Black Sunshine39.00 jondagger90.00 |
08-23-2019, 06:18 AM | #30 |
Rep 197
Took a upgraded turbo n55 m2 on meth port injection in 50 digs, tuned by Twisted tuning.. also gapped my buddies stage 2 m235i by 2-3 cars... repeatedly.. Cary is the man !! Twisted Tune with 3psi and more meth than my tune couldn't keep up! Don't cheap out fellas ! Cary = gaps
11-26-2019, 11:34 AM | #31 | |
Rep 190,633
jondagger90.00 |
11-30-2019, 12:15 AM | #32 |
Rep 98
I'm looking at getting Cary to tune my M2 and came across this post.
Is it possible to do a remote dyno session and he does all the tuning in that one session and avoiding the need to do logging over multiple days? As I don't want to log on the road due to the requirement of doing a 5th gear log (means speeds ~240km/h) I would have to book 4-6 dyno sessions to get the revisions. Thanks. |
01-06-2020, 10:50 AM | #33 | |
Rep 237
I'll be going through him in the spring early summer and I'll have the same question. If I were tuning a less powerful car the logging on the road would be feasible. I'll chime back in here with what he says or how I ended up doing it |
01-06-2020, 02:35 PM | #34 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
From my experience with other remote tuners, they have you do 3 logs in 3rd gear which will push you to ~80mph (~130kph). Still dangerous on normal streets. Little easier on the Interstate/Autobahn.
Dynos typically run in 5th gear only because it's the closest (or is the gear) to a 1:1 ratio to give the most accurate readings without reaching the maximum speed of the dyno. Logging can be done in any gear, but 3rd gives accurate readings within a relatively short window. |
01-22-2020, 02:45 PM | #36 |
Rep 1,303
I believe you always go through the revisions. That’s why you pay the extra $600 or whatever it is to get a custom calibration.
01-24-2020, 12:01 PM | #37 |
Rep 410
04-16-2020, 09:39 AM | #38 |
Driver - Autocross
74
Rep 178
Sorry to revive this thread, but I use MHD, how does cary work with you when you use MHD? Also does he send me a base map to go out and log with? Do a few pulls and then come back. And send him the logs? Go from there sort of deal until we hit max?
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
04-22-2020, 10:54 AM | #39 | |
Rep 190,633
He'll send him a base map, you'll send him datalogs, he'll respond with a map revision. Repeat this process until you are happy with the result It took 2 tries on my car, very smooth process
04-22-2020, 10:58 AM | #40 | ||
Driver - Autocross
74
Rep 178
04-22-2020, 11:00 AM | #41 | |
Rep 190,633
I'm not sure I understand the question about boost. Are you asking if he factors in what boost to target? Yes he does, that's part of the tuning process I'm not allowed to post links on here, you can find it on my website by searching for MHD
04-22-2020, 11:06 AM | #42 | ||
Driver - Autocross
74
Rep 178
04-22-2020, 12:43 PM | #43 |
Rep 190,633
Correct
The_otherM235i73.50 |
