2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB AC Blower Motor removal?
      07-06-2018, 12:11 PM   #1
ATLMPoster
ATLMPoster's Avatar
Drives: 2015 GSM M235i
So it sounds like there is some debris in the ac fan. I did a similar job on my old Subaru and I can't find anything online about the removal process on F22s.
I looked under the passenger dash on only saw the airbag and no obvious screws/clips. Any one have any info?
      07-06-2018, 12:30 PM   #2
overcoil
Drives: M235i 6spd
Had you checked under the top firewall cowling in the engine department - as you would to access the rear most spark plug in a six cylinder
      07-21-2018, 08:35 AM   #3
overcoil
Drives: M235i 6spd
Did you ever clean out your hvac blower motor?
https://www.2addicts.com/forums/show...er+replacement
      08-14-2018, 11:47 AM   #4
ATLMPoster
ATLMPoster's Avatar
I did! Sorry about the long reply. I just removed the panel under the glovebox and taking the blower out was easy, just 3 screws. It was a parking receipt that I assume fell in the dash and got sucked in. It had been lurking under there for 2 years according to the date on it, and it was from LA. Only finicky thing was getting the plastic panel clipped back in place.
      08-14-2018, 12:09 PM   #5
overcoil
Drives: M235i 6spd
Thanks for update.
      09-18-2018, 02:42 AM   #6
Texan2er
Drives: 2015 M235i
Would this panel you removed also be the one containing the cabin air filter? Having some AC issues on my new-to-me baby not blowing despite hearing the fan running at max and hoping it's just a blocked filter...
      09-18-2018, 06:42 AM   #7
overcoil
Drives: M235i 6spd
Yes
