2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB brake pads wear
      10-09-2014, 07:02 PM   #1
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
brake pads wear
can you post what's your current mileage and what your front and rear brake pads miles left on idrive says ?
      10-09-2014, 08:09 PM   #2
Fletch F. Fletch
Drives: Black M235i MT
How do you see the numbers on the iDrive?
I'll do it for ya, in the AM.
      10-09-2014, 09:07 PM   #3
pikcachu
pikcachu's Avatar
1399
It's in settings - vehicle status - select the service and you should have intervals for oil, pads and other fluids
      10-10-2014, 06:36 AM   #4
Fletch F. Fletch
8700 miles
Front- 23,000 miles left
Rear - 21,000 miles left
I find the rears having less left a bit odd.
Also, is there a way to see % left?
Just wondering.
      10-10-2014, 07:02 AM   #5
overcoil
Drives: M235i 6spd
Does your traction control or stability control get activated often? I'm thinking a lot of rear brake being kicked in to reduce wheel spin or slippage.
But it could just be a tiny brake puck on a powerful caliper.
      10-10-2014, 07:04 AM   #6
Fletch F. Fletch
Yes.
Great point!
I do a fair amount of spirited driving.
That'll do it.
      10-10-2014, 07:46 AM   #7
2+3=5
2+3=5's Avatar
Drives: M2
4300km
front 46000km
rear 43000km
      10-10-2014, 07:56 AM   #8
plien69
Drives: 2014 M235i
6300 miles
Front: 30000 mi
Rear: 32000 mi
      10-10-2014, 11:05 AM   #9
pikcachu
pikcachu's Avatar
1399
damn...
i have 8000
Front: 14000mi
Rear: 15000mi
I could swear i had 26k and 27k before the track day
      10-10-2014, 11:33 AM   #10
tccox
tccox's Avatar
Drives: 2014 228i Msport
Front 37000 left
Rear. 41000 left
Current milage 4500 miles
2014 228 Msport, manual trans
As much brake dust as this sucker produces I have a hard time believing there's that much brake pad life left
A peasant and proud of it
Save The Manuals!!!
      10-10-2014, 06:20 PM   #11
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Fronts 36,000 miles
Rears 33,000 miles
Current mileage 6283 miles
      10-10-2014, 06:35 PM   #12
Fletch F. Fletch
This is a good informative thread.
      12-07-2014, 09:56 PM   #13
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
The first set of brake pads lasted nearly 8,000 miles and the second set is nearly done at 15,000 miles. Oh, I did do about 10 track days this summer. And yes, I'm on my second set of MPSS tires. I love this car!
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
      12-14-2014, 11:11 AM   #14
jbenington86
Drives: 2015 M235i, 2017 Tundra
2015 M235i  [0.00]
2008 128i  [0.00]
During the experience I had with my 128i the computer never read higher than 40k miles of pad wear remaining even when brand new. However my first front pad change was at 80k-83k miles can't remember exactly. The rear pads are still original from the factory with over 95k miles on the odometer. Even as I know my rear pads need changed very soon (2mm-3mm of pad before senor trips) the computer is still reading 23k miles.
      12-15-2014, 12:18 PM   #15
Lucky13
Lucky13
Drives: 2014 M235 manual, 2020 X3 30X
Took my son's E93 335 in to independent when the brake pad light came on at 35,000. They checked all 4 pads and there was at least 10,000 miles worth of pads still on them. 6 months later the damn sensors have gone off again, not sure how good the sensors are so don't go by the sensor reading.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
      12-15-2014, 01:27 PM   #16
BlueM235
Drives: M4 2017 comp pkg
1,800 kms
rear 49,000 kms
front 50,000 kms.
TC, DSC and Cruise control (Downhill) will wear off rear pads much faster especially inner rear. Noticed on my 2011 335i.
      12-16-2014, 05:32 AM   #17
2+3=5
2+3=5's Avatar
Drives: M2
4.5 months 8300km
front 37000km
rear 32000km
      12-16-2014, 01:43 PM   #18
MG 228i
Drives: Z4 m40i, 340i 6MT, i3S
5,200 miles:
37,000 front
42,000 rear
Maybe I should drive harder?
      02-08-2015, 08:34 PM   #19
rich8566
rich8566's Avatar
Drives: M2 + Z-4
      02-08-2015, 08:57 PM   #20
pikcachu
pikcachu's Avatar
1399
Originally Posted by rich8566 View Post
I went thrift my first set of front and rear pads at 6700 miles (and about 6 track days. I went through the next set of front pads at 11,000 miles (after another 5 or so track days).
did you buy the pads or did they cover it with the maintenance?
      02-08-2015, 09:14 PM   #21
rich8566
rich8566's Avatar
Drives: M2 + Z-4
All of the brake work was covered under the BMW new car standard maintenance coverage. My only costs are tires, gas and oil changes between their covered 10k changes.
      02-08-2015, 09:36 PM   #22
Pparana
Drives: 2015 m235i
Fronts toast at 2200 miles, rear might have another day or two left at the track.
Search this Thread:
