2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Trunk release button (dumbest question in the forum)
      04-14-2019, 12:45 PM   #1
M2Rob
Drives: 2018 Alpine White M2
I have a really dumb question. I have kids from a former wife, formally known as satan's spawn. I have to pick my kids up at all times day or night, and they always need to put luggage in the trunk. That little button to release the trunk is not only hard to reach, it is impossible to find in the dark. Do ANY BMW models have a lit version of that button that I can retrofit?
Life is not about arriving peacefully in the casket at the end. It is about arriving side-ways with the engine at redline and the stereo blasting.
      04-14-2019, 02:24 PM   #2
xantdieselx
Kingslayer
xantdieselx's Avatar
No_Country
411
Drives: 23' M3 Base
Are you referring to the button in the lower left near the hood release?
Doors unlocked they should be able to open the trunk using the button above the license plate no? I almost never use that release button but if you can't see it try opening the driver's door should give you enough light.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      04-14-2019, 03:17 PM   #3
overcoil
Drives: M235i 6spd
Isn’t there a setting in iDrive for trunk release near license plate active or inactive in relation to door locks ?
      04-14-2019, 05:29 PM   #4
bmtespar
bmtespar's Avatar
Drives: 19 X3 30i, 18 230iX Vert
If you unlock your doors with the central switch, they will be able to open the trunk using the soft touch button above the license plate frame.
Current: 20 M340i
Sold: 19 x3 30i X drive, 18 230i X drive Convertible
18 x3, 30i X drive 16 428i Convertible, 16 X1 X drive, 14 i3 Rex, 14 328i, 14 x1 28i X drive, 08 328i, 03 M5, 99 323i Convertible, 00 z3 M Roadster, 99 328i, 00 323i
      04-14-2019, 06:51 PM   #5
Hpirx
Drives: 2022 M240 xDrive, BGM
Not the easiest button to reach/see with the door closed. But it doesn't move around too much after the first few times. Also, my keyfob has a release button. Might use that if you have one.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also"
      04-15-2019, 12:11 PM   #6
sethwas
Drives: 228i
you're right - the button placement is really odd. You could just splice into the wire behind the dash and put any button you want anywhere inside the cabin.
But it should really be next to the headlamp controls.
To me it makes as much sense as having the main Idrive wheel to control the radio by your right hand - and yet having the volume knob a far reach to the dash. Usually if you are changing sources or channels the volume will be different and of course the hand you release from the wheel to move the idrive knob is the one that would use the steering wheel volume controls....
Seth
