03-29-2019, 12:30 PM | #1 |
Rep 162
Rear Brakes on M235i
Hi all,
I had the front brakes (rotors & pads) replaced as part of warranty just a week before the warranty expired. My rears are due to be replaced soon - any suggestions on higher quality (braking efforts, low dust, better heat dissipation etc) rotors and pads that I should change to or should I stick with OEM since the fronts are OEM? If I change to a non-OEM rear brake setup, will it cause problems with brake balance? Thank you to all in advance! |
03-29-2019, 01:07 PM | #2 |
Rep 3,496
How do you use the car?
03-31-2019, 09:56 PM | #3 |
Rep 158
Unless you are tracking the car, I would not advise mixing pad compounds, let alone adding a more capable pad on the rear. I would just stick with stock pads and either get new stock rear pads when you need them or swap everything to a new set once the rears are done.
04-03-2019, 09:26 PM | #5 |
Rep 716
Drives: F90 M5
I had Ferodo DS2500's on all 4 corners back when i had the stock hardware. loved them on street and on track i would highly recommend them
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
04-04-2019, 07:10 AM | #6 |
Rep 2,873
Don't mix pads between axles. Stock pads (and fluid) really won't do for any real track time, so you may want to swap to a street/track pad for the summer with a fluid change, then swap back to factory pads and another fluid swap (back to factory low-visc) for winter. This is what I did last summer, and doing the same this year but with better pads and brakes.
04-10-2019, 11:35 AM | #7 | |
Supreme Allied Commander
3842
Rep 54,352
Drives: F80 M3
If you track the car but don't want to swap pads at each event, the Ferodo DS2500 is your best choice. This is a very popular pad for the M2/3/4 owners. You should replace all four corners if going this route. |
04-24-2019, 05:22 PM | #8 |
Rep 190,750
We offer, HAWK, Stoptech, Centric and EBC brake parts
