06-27-2016, 06:39 PM | #1 |
Rep 568
aFe Magnum FORCE Stage-2 Pro 5R Quick Snapshot
I felt it really important to type the title the same way aFe does on their website.
I swore to Obi Wan I was NOT going to fall for marketing nonsense & buy a cold air intake. But the guys at Excelerate Performance pulled some kind of speed-shop mind trick on me & next thing I knew - there I was, paying for an aFe CAI. I got it for a really nice price, too. Under 400 smackers. Shabammalamma ding dong. Here's what I can tell you about it: - It's a wicked-nice piece of equipment. It's really, REALLY well made. I just loved holding it & love looking at it. I keep opening the hood. And closing it. Then opening it. Then closing it. Then opening it... This thing is so nice, it made me want to replace everything in my engine bay with something made by aFe. - It is worth the price of admission alone just for the improvement to the way the engine bay looks after install. - The filter element itself should get some sort of quality award. - The installation took all of 10 minutes. - The heat shield it comes with basically lines up with the inlet port where the factory box ports mates to collect fresh air. The aFe intake winds up using the entire cavity where the OEM box was as the "air box". There is a little bit of a gap where aFe shield meets the OEM port. I am going to try & find some sort of seal to help close that gap to block the hotter engine-bay air. There are some other places that seem to need some sealing. I'll post pics of wherever I wind up adding seals. - The unit comes with a seal that goes along the top of the heat shield that rests against the hood to create a seal. - Windows down, stereo off, you can definitely hear the turbo & blow off valve. Sounds awesome, but I don't think it's all that intrusive. Some folks have said they absolutely hate the sound & that over time, it really got on their nerves. Fair warning - if you find yourself annoyed by repetitive sounds, this may not be the upgrade for you. However, windows down, stereo on & moderately loud, I can't hear the noises. Windows up, stereo on, no noises. Didn't try it windows up, stereo off because well.. my stereo sounds awesome & the music I like is awesome so unlikely I am turning it off. But I doubt I would be able to hear it if I did. (I have the weather seals that go in those spots by the door jamb/fender gap.) - Can my butt-dyno feel any difference? Nope. But based on dyno graphs I've see other members post here & there where this is the only mod, I believe there is some difference. Even if it's 5HP, I like saying "it's got 356HP" vs "...351 HP". If you're on the fence about a CAI, all I can tell you is - think about why you want one. Then, ask yourself if that list of wants is worth the price - because this is one pricey mod for very small gains. Once I saw it, though, it's just such nice quality, that in & of itself made it worth every penny. It dresses up the engine bay nicely. Paint that engine cover, you got something nice look at. Knowing I am getting some gains & there some nice sounds, well.. I'll take that too. What you are looking at in the pics: Shot of the intake tube. 2 full-on shots of the intake installed. Shot of the element. Shot of the gap near the OEM inlet port - screwdriver pointing to it. Shot of the gap at the bottom of the heat shield that really needs to have a seal.
2017 M2 | MGM | 6SPD Std | RWD | MP Exhaust | CSF FMIC | Active Autowerke DP w/ HF CAT | FTP Charge & Boost Pipes | Fortune Auto series 500 7k/14k coilovers | CDT Audio ES Gold Fronts & HD series Rear | Richland Forged Project Nurburg RF-GT4 Wheels | AudioControl LC-6.1200 | JL Audio TWK 88 | CF Goodies
06-27-2016, 09:07 PM | #2 | |
Rep 237
06-28-2016, 08:36 AM | #3 |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
See, here is a review I can agree with.
I have the same intake installed on my car, except with the Dry filter (didn't want to deal with having to oil it, easier cleaning down the road, etc) The sound is pretty intoxicating to me personally. I went from an AWE exhaust to just a downpipe, so I lost quite a bit of sound. The intake helped backfill that for me. Windows up, stereo off seems to net the most sound in my experience so far. Definitely recommend this intake with either filter. |
06-28-2016, 10:35 AM | #4 |
Rep 5,369
No offense (I seriously mean that), but I think you got taken here. There are no real performance gains with intakes on these cars. Sure, there are dynos showing 5whp here or there along the dyno plot, but the average power across the powerband is the basically the same as stock and in some cases, worse than stock. You've also now completely removed the factory cold air feed to the airbox and have removed the OEM airbox's ability to slightly pressurize at speed, improving throttle response.
Monitor you intake air temps (IATs) now when you're sitting at a stop light and you'll see them skyrocket into the 140+ degree range in ambient temps above 80 degrees. Sure, the hot air clears out after a few seconds of driving, but the lag in 1st gear will get annoying while driving in warmer conditions. You probably don't notice it now because you're in the honeymoon phase. We've all been there. If you wanted more noise, you could have just cut a few holes in the lower airbox and got the same effect plus you'd have the OEM snorkel to completely feed the box with cooler air. The $400 spent could have been applied to a far better noise maker, the MPE exhaust (assuming you don't have it) which can be had for around $790. MY GOD. The best mod for sound and enjoyment and no compromises on performance. |
06-28-2016, 11:54 AM | #5 | |
Rep 568
I know there aren't any serious/noticeable performance gains. Pretty sure I said that up there somewhere. I didn't do it for the sound, either - but I'll take the sound since it does add some cool noises. I did it on the recommendation of the speed shop. They told me +5 WHP tops. Like I said, I am happier saying "356 HP" instead of "351 HP". I also said, the quality of the unit & how it dressed up the engine bay alone were worth the price of admission to me. I mean, guys are spending money for wrapping the cars & their reflectors & replacing their lights with LEDs & putting on springs & CF this & that for what, like 20 WHP? LOL
06-28-2016, 11:57 AM | #6 | |
Rep 568
I had an oiled conical on my 350Z & HATED washing & drying it. I lived in FL at the time & the pollen & bugs - I had to clean that thing constantly. And wait for it to dry for hours in the humid climate. Annoying... They tell you you can't use a hair dryer on them.
06-28-2016, 11:58 AM | #7 |
Rep 568
Yes, you can hear the turbo & the BOV.
But, I think it sounds awesome. I love mechanical noises, so... call me weird. If you like that kind of stuff & it makes you giddy like a kid - go for it. You will grin ear to ear!
06-28-2016, 12:00 PM | #8 | ||
The Schwab
473
Rep 1,605
06-28-2016, 12:06 PM | #9 |
Rep 5,369
I've been modding and racing cars since the mid 1990s and I guess I'm not trusting of vendors or internet reviews without data to back up the claims. I've been suckered out of way too much money over the years and bought into the hype and claims especially when it comes to filters on sticks and suspension mods, especially. It sounds like you too had similar experiences. From the data I've read, intakes on turbo BMWs cause more harm/frustration than joy in most instances which means to be the case for most other makes of car. I guess that's why I'm posting. LOL
If it makes you happy though, that's really all that matters. As a car guy, making a car your own is a joy. |
06-28-2016, 02:36 PM | #10 | |
Rep 568
But what the guy at the speed shop told me a CAI does for a turbo motor is, the turbo spools quicker, helping to reduce lag. Personally, I don't find troublesome lag with the N55 anyway. I am really looking forward to uograding the intercooler next year, though - then I am done. I think. |
06-28-2016, 02:40 PM | #11 | |
Rep 568
That's why it threw me this CAI had nothing & nothing for sale on their site. I'll just go to a speed shop & get something. I am sure those products are all the same. |
06-28-2016, 08:18 PM | #12 |
Rep 237
Did you tune the car? Or just add the intake and go. I'm not interested in tuning for now as I just want to liven up the sound of the engine a bit. Also, I'm pondering doing the dry filter as I dont wanna risk any damage to the MAF... does that really matter? Thanks!
07-09-2016, 05:19 PM | #13 | |
Rep 568
If you like the sounds of forced air induction, you'll love this intake. I do have the wet filter and I've read the cleaning instructions. It's not too bad, but I am getting the dry filter as a second filter for when I clean the oiled one. AFE says the oiled & dry filter perform the same. The dry is just easier to use. You still have to wash it, though. I think you will really like the AFE. Keep us posted on what you get!
07-09-2016, 10:27 PM | #14 | |
Rep 721
07-10-2016, 07:02 PM | #15 |
Car Enthusiast
282
Rep 501
Where is the Fresh Air getting pulled in from?
Quote me if i am wrong but, by the looks of that airbox/filter it appears it has blocked off the fresh air duct which comes in from side behind the DS kidney grille/headlamp area... Seems like more of a Hot air intake than anything |
07-11-2016, 07:49 PM | #16 | |
Rep 568
When I get around to it, I am going to post OEM vs AFE intake air temps (I have the Awron gauge). I can tell you on the open highway, last couple of 90 degree days we had, the intake air temps with the AFE were anywhere from 11-17 degrees above outside air temp.
07-11-2016, 07:54 PM | #17 | |
Rep 568
The MPE is not going to make the M235i sound like some ball-out, strappin' V8, but it sounds pretty darn good. And when I got the car dyno'd (stock airbox in place) trust me - WOT that exhaust was loud as hell & sounded downright nasty. And all those burbles & pops are pretty nice sounding, too. MPE, to me, gives really nice sound improvement while not being annoying either inside or outside the car. And for $790 bucks, can't be beat. Just throwing that quick review out there in case folks read the thread & are looking for another perspective.
07-14-2016, 06:05 PM | #18 |
Rep 190,750
Congrats!!
07-27-2016, 05:25 PM | #19 |
Rep 386
I have this same intake..unfortunately the cone is no longer cool Blue for photoshoots haha
The only thing with this intake on Automatic M235s is the blasted Vacuum line is a pain to put on, and even then the darn thing is on there tugging on the intake tube. Still on there after 5,000 miles but still. |
07-29-2016, 09:19 AM | #20 | |
Rep 568
Sucks about that vacuum line. Makes you want to ask 'em, "Did ya test fit it & just say 'WFT - go with it'?" LOL My JB1, the plugs are juuuuuuuust long enough to reach, but tight. They need to be like, another inch longer to make me feel better about the tension in the wire.
04-26-2019, 02:08 AM | #21 | |
Rep 231
