05-20-2016, 02:32 PM | #23 | |
Rep 63
I would give the rs3's a slight advantage over the NT05 for colder weather traction and cost |
05-20-2016, 02:53 PM | #24 | |
Rep 1,422
Yea, 2 unlike metals cause accelerated corrosion. |
05-20-2016, 03:44 PM | #25 |
Rep 3,840
I'm about to order some light custom wheels so that I can get more rubber contact and less unsprung weight.
How much clearance is between the stock 7.5x18 et45 wheel and the front strut? I'm hoping for a setup like this: Front: 8.5x19 et44, 235/35 MPSS tires, that makes 11.7mm closer on strut side and 13.7mm more poke than stock on the fender side. http://www.willtheyfit.com/index.php...culate#content Or et43 in the front would give 10.7mm closer to the front strut and an additional 14.7mm poke towards the front fender. I was trying to keep the poke down to a minimum. http://www.willtheyfit.com/index.php...culate#content Rear: 9x19 et53, 265/30 MPSS tires, that makes 13.7mm closer on the strut side and 11.7mm more poke than stock on the fender side. http://www.willtheyfit.com/index.php...culate#content If this looks OK, what will happen if I install the M3 LCA? Will that give it less strut and wheel well clearance? The wheels are expensive, I don't want to screw it up. Last edited by AlpsRider; 05-20-2016 at 04:45 PM.. |
05-20-2016, 04:04 PM | #26 | |
Rep 63
My math is saying your wheel will be 12mm closer to the strut, while the tire will be 4mm closer. While the tire will be ~6mm further out towards the fender and the wheel 14mm closer to fender. I think with a very small spacer you would be just fine. But I am no expert! go measure for yourself and be sure |
05-20-2016, 04:31 PM | #27 | |
Rep 3,840
05-20-2016, 04:55 PM | #28 | ||
Rep 5,262
I was scared a bit first but then I took the wheels of and the struts were intact. I also have about 3mm clearance with the kosei 17-8 et42 with 245s all around |
05-20-2016, 05:18 PM | #29 |
Rep 214
Are you sure that wasn't feedback for the RE71R? I run RE11's and with them being really popular with the Nissan Z community (used to own a Z) I can say the wear is totally normal for the category, and wet performance is good.
Brandon
05-20-2016, 05:22 PM | #30 | |
Rep 1,422
Plus, I've been going back and forth on my big turbo build with the vendor and shop. Ugh. |
05-20-2016, 06:32 PM | #31 |
Rep 957
if the car is squirming left to right its bushings. Rear lower lca outer bushings. I went through 3 sets, just ordered some poly ones well see if they fit.
05-20-2016, 06:36 PM | #32 | |
Rep 1,422
Which bushings did you change to? How involved was the install? |
05-20-2016, 08:59 PM | #33 |
Rep 887
Drives: Enzo F23 228i
All done, she has gone from this:
To this: |
04-24-2019, 12:49 PM | #35 |
Rep 9
Hello,
I have the same interrogation for my F10, i have ~3/4mm space between wheel and suspension, U have fit spacer or not ? i dont have rubbing but i'm drive not lot of kms 🤷🏻*♂️🤗. Thanks 😊
Lukas
04-27-2019, 12:50 PM | #36 |
Rep 448
Answer?
