2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes m4 tension struts to go with lcas
      02-05-2019, 10:21 AM   #221
Polo08816
Drives: 2014 335i M Sport
Originally Posted by krisa9977 View Post
Just put Lemforder LCA and Powerflex adjustable bushings. With Powerflex front wheel goes 20 mm backwards where it supposed to be and you getting extra -0.5 degrees of negative camber on top of LCA. Lemforder LCA is the same as m3/m4 LCA, but cost much less and also have metal uniball bearings instead of original rubber bushings.
part numbers:
Now the car has about -2.0 degrees of front negative camber.
Powerflex PFF5-1901GBL
Lemforder 38258 01
Lemforder 38259 01
Anyone know a good Lemforder parts source in the US?
      02-05-2019, 12:08 PM   #222
FaRKle!
Drives: 328d Wagon, M2 Comp, i4 eD35
K-Mac camber adjustable bushings (PN 193616-8H) will get you a decent amount of camber now too. I was able to get -1.8deg with my xDrive car.
NOT2DAY117.00
      03-09-2019, 03:48 PM   #223
MacklinUSOB
Drives: f30 328i 6MT Sport
I just ordered a set of Lemforder TS and replacement fasteners from https://www.onlinecarparts.co.uk/. Appears to be one of a few sites affiliated with 3rd party German OE manufacturers.
Haven't used them before but will report back when I get them. Total price with shipping to US was $298 USD.
I couldn't find the Lemforder arms available anywhere in US after hours of searching. Cheapest I found was ECS @ 179.99 each for genuine BMW, $406 shipped with hardware.
Originally Posted by rwalker View Post
I'm about to install these... Pparana, any last words?
spacers from Summit Racing:
http://www.summitracing.com/parts/KYS-100-377-3
http://www.summitracing.com/parts/KYS-100-377-1
I ordered these exact spacers to pair with them.
I did a hard braking test on the highway today and my stock TS bushings are done. Not surprising after 75k, but I'm keen to see brake feel and wheel placement improvements. Will report back after install.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      03-14-2019, 02:34 PM   #224
knoteasy25
Drives: m235 white manual
Lemforder LCAs and Tension Struts
Any updates on getting the Lemforder parts from https://www.onlinecarparts.co.uk/
Shipped to the States.
Will not allow to search from manufacturer's part numbers.
Any duty and if so how much?
What about the Lemforder parts themselves?
      03-14-2019, 06:50 PM   #225
MacklinUSOB
They're in transit from Germany as we speak via DHL. Still to be seen if I'll have any duty assessed. From what I gather from CBP's website, if the items are for personal use and are valued under $800 they usually won't have a duty. We'll see how it goes.
I don't think they sell BMW stamped parts so you'll need the Lemforder numbers which can be found in their online catalog. 38257 01 and 38256 01 are the right and left arms.
Lemforder is an OE manufacturer for BMW, quality is either as good or better than the genuine stamped parts.
      03-15-2019, 10:36 AM   #226
FaRKle!
Yup, <$800 is duty free. I just had a set of dampers delivered to me yesterday from Germany that was ~$700. No duty required.
      03-15-2019, 12:51 PM   #227
knoteasy25
you got those from onlineparts.co.uk?
      03-15-2019, 01:28 PM   #228
knoteasy25
I pulled the trigger and bought the m4 LCAs and tension rods from online uk parts co awhileago.
What else should I get washers? and headlight leveling bar?
      03-26-2019, 07:21 PM   #229
MacklinUSOB
My TS' made it in from Germany today, no duty assessed. As I suspected, they came with a box labeled AutoDoc which is the main distributor for a ton of these European online parts websites. For anyone curious about onlinecarparts.co.uk, they check out. Parts are still sealed from the Lemforder factory. I'll be throwing these on this weekend most likely and I'll be back with my last update then.
      04-22-2019, 10:36 AM   #230
MacklinUSOB
So my install got postponed until after I returned from the Caymans. Install was a breeze, I used the following tools: Impact gun with 17mm (wheel bolts), 21mm (ball joint nut), and 18mm (subframe bolt), 8mm (fender liner screws), 18mm ratcheting spanner, rubber mallet, torque wrench, jack and stands.
The passenger side had a battery lead snaked right around the subframe bolt as well as the auxiliary radiator which prevented me from using the impact but the 18mm spanner with a 19mm on the end as a cheater got it out easily. Impact gun made quick work of the sometimes stubborn 21mm hub nut and the set on the other side. F80 Arms and spacers had a nice snug fit, I used the 18mm spanner and mallet to align the second larger spacer into place. Torqued down hub bolts and then loaded the suspension with the jack to torque the subframe bolts. Pretty easy install.
First driving impressions are great, front end feels much tighter on response and over bumps. Wheel is pulled away from the fender liner and ride height increased about 1/4-1/2 inch. I installed new pads while I had it up so braking feel improvement is to be seen until they are bedded.
For anyone curious about Lemforder parts, they are cast from the same molds as the BMW stamped parts. You can see where they scrubbed off the M\\\ logo on mine.
cxp213313.00
DVC558.00
      04-23-2019, 05:32 PM   #231
knoteasy25
great review
thanks for the review still waiting on my set,
can someone explain what the headlight rods are and what part number is from bmw?
do I need to order the m4 ones?
Also what spacers did you use, aluminum or steel?
      07-14-2019, 01:35 PM   #232
YR430D
YR430D's Avatar
46
Drives: BMW 430D
Originally Posted by Pparana View Post
Looks good, its snug, i used another bolt to help align one of tje spacers while fitting the front spacer and lca, will make sense when your in there.
Thanks for the great work and thread very helpful.
I’m running M4 255/35/19 tyres and Wheels. At the moment I’ve got no issues and tyre top is more or less flush with the arch.
Anyone tried this full setup with M3/4 wheels?
      07-14-2019, 01:47 PM   #233
YR430D
YR430D's Avatar
46
Drives: BMW 430D
Originally Posted by Bee Pee View Post
yup - I had mine made bespoke to my specs via an ebay seller here in th UK. Painless enough.
Contact details for the seller?
      08-23-2019, 05:56 PM   #234
grocerylist
Drives: BMW M235i
2016 BMW M235i  [0.00]
Nice, that's a $100+ savings and has gotta be a good 0.25g weight savings per corner!
Not sure if anyone was aware but there's also another option from Turner with their Turner Motorsport Thrust Arm Monoball Upgrade - Pre-installed Arms - F8x M2/M3/M4. Definitely more costly currently @ $643.10 but they've got upgraded sealed ball joint monoballs.
They also sell the monoball bearing set if your TS bushings blew out.
Too rich for me but something I came across when researching LCAs & TS and thought I'd share.
goodNIGHT106.50
      09-03-2019, 08:07 PM   #235
R32DBP
Drives: 2014 335i M Sport, 2004 .:R32T
just placed my order for lemforder TS and LCA from onlinecarparts.co.uk. They have a sale going on right now so I ended up getting all 4 arms for my F30 for $400 shipped. A lot better than the $1000 shipped I was about to spend on OEM M3 LCA and Turner Monoball pre installed TS from ECS.
The PNs I ordered are below.
Lemforder 38256 01
Lemforder 38257 01
Lemforder 38258 01
Lemforder 38259 01
Now I just need to order the spacers or probably have them made at my job.
Correct me if I am wrong but its the spacers below for the TS.
http://www.summitracing.com/parts/KYS-100-377-3 2x
http://www.summitracing.com/parts/KYS-100-377-1 2x
People have mentioned using 2mm spacers on each side as well for the LCAs? So 4x 2mm spacers?
Also, does anyone have the PN for the necessary headlight leveling rod that is needed to use the F8x TS/LCAs?
      09-20-2019, 06:22 PM   #236
knoteasy25
what spacers for LCA
what spacers are required for M4 LCA ?
I see some places m12 13mm ID 38 OD width2mm, some 1mm and some none.
Also any idea where I can purchase this online?
Its the only thing holding up my install.
      10-07-2019, 12:41 PM   #237
jondagger
Drives: 2016 M235i
So to clarify this post for any newcomers, here is what i got from the 11 pages here.
-------- LEMFORDER Arms -------- ~321£ = 396.57$
L LCA - 38258 01 (BMW OEM 31122284529)
R LCA - 38259 01 (BMW OEM 31122284530)
L TS - 38256 01 (BMW OEM 31122284531)
R TS - 38257 01 (BMW OEM 31122284532)
-------- Hardware -------- ~50$
https://www.fcpeuro.com
(2) BMW Tension Strut Nut - Genuine BMW 31106767496 (supposedly this one is welded to frame so not needed, will confirm)
(4) BMW Combination Nut - Genuine BMW 33306787062 (some claim these come with the LCA+TS but mine didn't)
(2) BMW Control Arm Bolt - Genuine BMW 31106795930
(2) BMW Hex Screw With Collar - Genuine BMW 31106797237
(2) BMW Control Arm Locking Nut - Genuine BMW 33326760668
-------- TS Spacers -------- ~20$
https://www.summitracing.com
(2) Front/Outside: Keyser Manufacturing 100 377-1 (0.5 IN / 1.5 OD / 0.25" length)
(2) Rear/Inside: Keyser Manufacturing 100 377-3 (0.5 IN / 1.5 OD / 0.50" length)
OR
ask victorescott@hotmail.co.uk
(2) Front/Outside: Stainless Steel 12mm bore x 30mm dia x 6.3mm long
(2) Rear/Inside: Stainless Steel 12mm bore x 30mm dia x 12.2mm long
Note: the second custom one is more accurate 18.9mm total instead of the 0.75in/19.05mm total from summit.
-------- Optional LCA Spacers -------- ~20$
38mm OD, 13mm ID, 1mm thick each side (some used 2 on each LCA)
https://www.homedepot.com/p/Everbilt...9302/203436045
OR
-------- Headlight Adjustment Rod -------- ~25$
https://www.turnermotorsport.com/p-5...m-upgrade-kit/
BMW Headlight Adjustment Rod - Genuine 37142283867
note: Need 1 of these. You will have to cut off one side of this and cut off the OEM end. Glue them together. Video named "M235i DINAN SPRINGS AND M3 LOWER CONTROL ARMS INSTALL" by "Low Boost Films" on youtube explains. Explanation starts @ 6:19.
TOTAL: ~511$
note: torque specs of subframe 74ftlbs +90* and 122ftlbs to knuckle for both lca and ts (please check me on that) and to only torque them at natural position , ie on tires or jack the hub up
someone please comment if anything needs revision, I would love for this to be the most accurate possible.
Appreciate 7
      10-13-2019, 08:59 PM   #238
nixeighty6
Drives: 2021 M2c
Ordered this list Friday, couple parts here already. Thanks for posting and will keep the community updated to what i find.
      10-29-2019, 10:24 AM   #239
goodNIGHT
goodNIGHT's Avatar
107
Drives: 2015 M235i
So if you get the F8x tension struts, it's still a good idea to get the power flex bushings and spacers???
That or just get the turner Motorsport tension strut? I'm assuming those won't need the bushings or spacers??
Can you mix the F8x LCA and Turner TS together?
Thanks
      10-29-2019, 04:57 PM   #240
jondagger
Drives: 2016 M235i
Thanks
Absolutely you can miss match where you're getting it. The 1mm spacers for the TS is recommended but not needed. The LCA is required. Also the power flex option would be a good bang on top, but personally I didn't do it as I don't track often. Also, not 100% sure that it's much better than ball bearings, some people say it is.
      10-30-2019, 12:14 PM   #241
goodNIGHT
goodNIGHT's Avatar
107
Drives: 2015 M235i
If i were to buy the Turner F8x kit I would still need the spacers, right?
If so Ill just go the lemforder/powerflex route
      10-30-2019, 12:47 PM   #242
jondagger
Drives: 2016 M235i
correct spacers required no matter which route you go.
goodNIGHT106.50
