03-04-2016, 12:46 PM | #1 |
Rep 221
Let's see your meth setup...
Looking at installing meth injection and wonder what others have done on the M235i's (I've seen images of other models already). I'm curious where people are placing the pump, tank, controls, etc.
03-04-2016, 03:06 PM | #2 | |
Rep 893
2019 SG M5C
03-04-2016, 04:58 PM | #3 |
Police Magnet
82
Rep 217
I'm interested as well. I have been following other threads that have started to help me out in getting an understanding in methanol injection in my daily driven M235i, but I'm still looking to learn more so I don't make any mistakes and go with the perfect set up, right from the start.
2014 ///M235i
03-04-2016, 09:41 PM | #5 |
Rep 221
I'm thinking in the battery compartment for the pump and the storage compartment for the tank. I'll probably drill a hole out the side in the battery compartment (looking to avoid the exhaust). If you remove the storage compartment (plastic insert) there seems to be room for the tank with easy access to fill.
03-05-2016, 05:54 PM | #6 |
3441
Rep 79,212
Not sure how I feel about a fuel so close to the battery. I'd highly advise against that, especially in case of an accident. Although the install is very clean.
Most of our customers go with the BMS Meth kits for seamless integration with their tune (assuming JB4). Otherwise most other kits are universal in nature. Pump, tank lines and nozzles. Progressive controllers are not really needed on this platform but a failsafe is recommended. If you are just spraying and praying, any kit will do the job. |
03-09-2016, 07:30 PM | #7 | |
Rep 221
03-10-2016, 09:02 AM | #8 |
Rep 1,349
Drives: BMW F80 M3
Mine is just bolted against the left sidewall in the trunk. Will grab a pic later.
Mywifes3351631.00 |
03-10-2016, 02:47 PM | #9 |
Rep 957
ill post mine later, just off to the right side, pump fits in the 2 gallon kit. Tried to get as far over to right to help w weight distribution, right side is already heavy thanks to me.
I use the luggage tie downs as well as bolted it down. But since its on track and gets lots of g's the tie downs seemed like good insurance. The small tank would require lots of filling. I usually get 2-3sessions on track per 2 gallon tank. |
03-10-2016, 02:47 PM | #10 | |
Rep 957
03-11-2016, 12:48 PM | #11 | |
Rep 221
03-11-2016, 03:36 PM | #12 |
Rep 190,575
Most popular by far is the BMS meth kit, it is designed to work with the JB4
Mywifes3351631.00 |
07-23-2017, 06:09 PM | #13 |
Rep 546
07-24-2017, 06:52 AM | #14 | |
Rep 1,184
07-24-2017, 07:15 AM | #15 |
Rep 148
Here's mine:
It's not pretty, but you can't argue with the results |
07-26-2017, 03:32 PM | #18 | |
3441
Rep 79,212
To re-fill I simply unlatched the seat like I was going to fold them down and filled up from the back seat. No exactly ideal but not too hard either. |
07-27-2017, 11:00 AM | #19 |
Rep 2,214
Washer Fluid Reservoir, works great, pump is under the intake filter strapped to the fender liner. Easy out in under 1 hour if needed, everything contained up front. Low level warning comes on well before the tank runs at an "unsafe" low.
07-27-2017, 11:20 PM | #20 |
Car Enthusiast
282
Rep 501
Washer fluid tank is a good Idea - but keep an eye on that level sensor.
See fair bit of Customer complaints of Washer pumps not working or Level sensors not working because of customers using High Alcohol based washer fluid such as RainX.
2016 M235 - Melbourne Red
07-28-2017, 03:19 PM | #21 | |
Rep 2,214
Only thing you SHOULD be using from a washer fluid standpoint is the cheap Blue stuff, which is essentially 40-49% meth/ rest is water and blue colorant. Been using this stuff as my meth mix for over a decade now, with great success. IF ITS NOT BLUE, DONT USE IT. Pink, Green, Purple all have additional detergents that can muck things up. Only the blue (cheapest, usually) has no extra additives, hence the price point. |
Anthony235715.00 |
