04-11-2021, 04:32 PM | #1 |
Rep 515
Leather seat damage
So I recently bought and apply chemical guy 2 in 1 leather cleaner and conditioner and apply that on the leather. Found a spot that suddenly looks like the leather is torn. I wasnt sure if it looks like that before.
Im thinking it must have been covered with some kind of substance to hide the defect and the cleaner exposed the damage. Anything I can do to make sure it doesnt get worse or to fix it? |
04-23-2021, 08:01 AM | #2 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
autoleatherdye.com has some nice kits but kinda pricey.
04-23-2021, 08:35 AM | #3 |
Rep 5,577
Thanks for the autoleatherdye link. I think I will try it on an area of my black sensatec drivers seat. I have a spot that wore to the base color of white and I think a black dye could lessen the appearance.
To the original poster. I don't know how much work I'd put into dying the leather. Sometimes the products require an initial abrasion to create a prepared surface that absorbs the dye. I don't know Id want to start sanding the leather. Also spot treatment is a lot different than pulling a leather seat out of the car and coloring the whole seat. And finally leather and patina. The op's picture shows what occurs when someone slides into a seat over a period of time and it is normal wear, a slight person may not create such markings but a larger guy will most likely be pushing against the bolster when dropping into the seat. I personally would just condition the leather, but even that is debatable with plasticizers used on modern leathers. And I'd be very careful about not saturating the stitching in any kind of liquids. |
04-23-2021, 05:49 PM | #4 |
Rep 167
Had the same thing happen on my Miata. Previous owner leather dyed it. It came off eventually and looked terrible. I had them re-dyed, it it only lasted about 6 months.
04-23-2021, 09:55 PM | #5 |
Rep 506
I would give a quick pass with a heat gun. Tightening the leather may help even out and smooth the surface.
E46 -> E90 -> F30 -> F23
