06-14-2017, 05:27 PM | #23 |
always learning
57
Rep 130
I like the look of the SM-10 a lot.. I run 18x8.5 ET40 (final) up front and 18x9.5 ET45 rear and just DINAN springs. Sad to report that the rears rub on the fender liners with the DINAN supplied camber settings. That 18x9 ET42 option out back looks compelling, but I'd be worried the 18x8.5 ET35 up front would poke or rub without much front camber. I'm sure it's possible to make the 18x9 ET42 work in a square setup, but I'd need to run a LOT of front camber and this is strictly a street car (HPDE car in training, when it's old enough and I can afford to ball it up).
-Colby
2020 M2C (his) 2022 Audi A6 Allroad (hers) 1997 Land Rover Defender 300TDi (ours) |
ApexWheels1427.50 |
06-22-2017, 03:58 PM | #24 |
Rep 119
Looks like its time to sell my vmrs....
ApexWheels1427.50 |
06-23-2017, 12:40 AM | #25 | |
Rep 2,650
- Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
06-30-2017, 11:00 AM | #27 |
Rep 6,752
Here are some on-car pictures of the SM-10 wheels on a F80 M3
06-30-2017, 09:04 PM | #28 |
Rep 157
Hoping to see a pic of some FL-5s on an M235i/M240i. I'm strongly considering a 245/40-18 square setup on the 18x8.5s (suggested by Apex--thanks!), with camber plates and fender rolling (if necessary). Have to burn up the stock rubber before the changeover, though.
07-04-2017, 08:59 PM | #29 | |
always learning
57
Rep 130
Also, do you think it would be possible to mill down 5mm off the 8.5" ET35 to make it ET40 or would that compromise the wheel's structural rigidity?
-Colby
07-05-2017, 04:16 AM | #30 | |
Rep 4,516
With both M4 LCA + TS front wheels stay in the stock position within the fender
Current '22 X3M LCI.. |
07-05-2017, 04:23 AM | #31 | |
Rep 4,516
Taken from this thread At the rear, I think same size tyres on more aggressive wheels [8.5" et35mm] will need big camber and major arch pull...
07-05-2017, 11:34 AM | #32 |
Rep 1,541
I might be changing up my square fitment. Any update on the below in both styles??
18x9.0” ET42 - 19.3 lbs. - TBD
07-06-2017, 12:35 AM | #34 | ||
Rep 2,650
The only requirement is to install adjustable camber plates, as the front fitment will require negative camber to clear the front fenders. Not only does negative camber allow you to stuff more wheel and tire under the front fenders, it more importantly plays a pivotal role in providing more grip throughout the corners as well as more consistent tire wear. Whether you are taking the car into the canyons or using it as a weekend warrior at HPDE's, camber plates pay for themselves in the form of tire longevity. Pick a palatable double duty alignment and the car can absolutely be daily driven, just be ready for go-kart like fun during your daily commute. As you track the car more often in the future, simply increase your camber specifications. Side note - We never suggest altering the back pad of a wheel, as our crush testing and certification process does not account for these alterations. Quote:
- Ryan
07-06-2017, 02:36 PM | #35 |
Rep 6,752
Check out this E46 M3 with the new APEX 18×9.5” ET22 FL-5 wheels in Race Silver. These are wrapped with 265/35-18 Pirelli P-Zero Trofeo R Tires. This setup requires 3.8° camber on the front and about 2° on the rear.
Anthony235715.00 |
07-12-2017, 06:19 AM | #36 | |
Rep 4,516
Moving on - any photos of SM-10 or FL-5 on an F2x yet ???
07-17-2017, 06:14 PM | #37 | |
Rep 6,752
-Matt
07-17-2017, 06:21 PM | #38 |
Rep 6,752
Kamel's 335i Coupe with SM-10 Wheels.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 07-31-2017 at 05:32 PM.. |
07-31-2017, 05:34 PM | #40 | |
Rep 6,752
-Matt
08-07-2017, 09:54 AM | #41 |
Rep 1,541
Bump for the same request
09-22-2017, 10:55 AM | #42 |
Rep 24
10-24-2017, 02:34 PM | #44 |
Rep 6,752
Here are some quick renders to hold you over!
CanadianGatorBacon231.50 |
