2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 135i wheels on the m235i
      01-18-2015, 07:41 PM   #1
g18galvin
g18galvin's Avatar
34
Drives: Z4MR
I have a set of style 264 laying in the garage that I got for cheap, before I send them to get refinished, has anyone installed 1 series on the 2er?
I have 15mm spacers rear and 10mm front
Fitment?
x7.5 ET49
x8.5 ET52
      01-18-2015, 07:50 PM   #2
i8ur911
Drives: F22 228i MSport
Do the 10mm spacers up front cause a vibration? That seems to be very common....
      01-18-2015, 08:17 PM   #3
g18galvin
g18galvin's Avatar
34
Drives: Z4MR
Haven't had that issue with my stock wheels
      01-20-2015, 02:17 PM   #4
VMRWheels
General
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
You should have no issues running that setup
Even if you were to run the 15mm front or 10mm rear, you should still have plenty of fender clearance
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
      01-20-2015, 05:35 PM   #5
g18galvin
g18galvin's Avatar
34
Drives: Z4MR
Thanks!
      01-20-2015, 07:19 PM   #6
MikeG12
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
I have snow tires mounted on 264's on my 228 MSport. Work fine. Don't have MSport brakes but there looks like plenty of clearance for them.
      01-21-2015, 08:29 PM   #7
g18galvin
g18galvin's Avatar
34
Drives: Z4MR
Do you prefer the look the 264's? Do you happen to have a pic?
      01-22-2015, 08:24 PM   #8
MikeG12
I actually do like the 264's better than the stock wheels. I just got them for mounting snow tires. No pictures and the car is so dirty, I don't want to take them. Easier to clean too.
      01-01-2018, 03:59 PM   #9
DaveCN
Drives: '14 M235i, '98 M3
Bumping an old thread - I know.
I picked up a set of these for winter tires for my M235i and after test fitting, I bought 12mm spacers for all 4 corners to try and address the brake clearance issues. They should be here tomorrow - I'll post up if that addresses the problem.
      01-03-2018, 07:05 PM   #10
DaveCN
Used 12mm spacers all around, put the rear dust caps on the spacers. 225-40-18 Blizzaks on all 4 corners. Fits just fine.
