2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning M240i Max gains on 93oct/98ron and stock turbo
      06-19-2022, 03:48 PM   #1
Jakops1337
Drives: BMW M240i
Hello, what your maximum gains on stock turbo with 93oct/98ron fuel?
I want to get a custom tune to my daily m240i but i dont want to change turbo,
Its worth to change the intake and install b58tu hpfp?
I was thinking to get a downpipe+hpfp b58tu+mst intake and custom tune.
Can i reach 500hp?
M240i b58.
      06-20-2022, 09:12 AM   #2
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
I think a couple guys have gotten around 500 WHP on the stock turbo but using an E85 blend. Maybe 450-ish WHP on non ethanol gas? I would recommend a new HPFP, downpipe, and in my opinion I would leave the stock airbox in with a new drop in filter. I had the MST intake for a few hundred miles and all it did was make more noise and I experienced higher intake air temps.
2024 M2
2019 M240i- Sold
      06-20-2022, 04:04 PM   #3
AleksanderSuave
Drives: 2017 M240iX Coupe
Can i reach 500hp?
M240i b58.
500 HP Wheel vs Crank is different, regardless, you should try using the search function.
There are tons of dynos shared from cars with multiple stages.
intake is mostly useless and a custom tune if you're not replacing the turbo wont be a good use of your money either. Put it towards a set of Michelin PS4's if you dont already have some. Or save it for future fuel injectors.
      06-21-2022, 04:17 PM   #4
MrFiasco
MrFiasco's Avatar
United Kingdom
Drives: M240i LCI PRE PPF
Bm3 Stage 2+
Hi mate,
I am currently running Bm3 stage 2+ 93 with 100cell DP and drop in panel filter, spark plugs gapped, de res, xhp stage 3, TU Pump, Stock turbo. On my M240i. (UK)
I chuck in 4lt of E per full tank of esso99 on stock turbo and im making 470hp crank, 480ft lb (650nm), calculated from rpm and torque in bm3 logs. The 4lt of Ethanol really cleaned up my logs.
I have yet to try their stage 2+ E30 maybe hit the 500/510 crank but im unsure weather or not i want to push it that much. im not sure if Boost target is the same and just more timing advance or a bit of both.
      06-26-2022, 03:55 AM   #5
Jakops1337
Drives: BMW M240i
Thanks for the answers
      06-26-2022, 12:05 PM   #6
Shadysu
Shadysu's Avatar
23
Drives: 2017 M240i
Catless DP HPFP 94 doing around 460-470WHP I believe
On e40 or more its 500+ give or take few hps.
2015 F30 335XI PS2 FBO SOLD
2017 F22 M240i xDrive
      08-25-2022, 09:37 PM   #7
cooolone2
cooolone2's Avatar
625
On what tune, what parameters...?
Asking for a friend, lol
      08-26-2022, 05:41 AM   #8
Shadysu
Shadysu's Avatar
23
Drives: 2017 M240i
correction* I believe 430-450whp on 94 Stg 2 + and 470-500WHP+ on E40+
11.4 on pump with passenger 3.4 0-100. Didn't get a draggy on E. MHD Maps. XHP Stage 3.
I was very tired lol.
      07-19-2023, 09:04 PM   #9
swflm240
Drives: 2018 m240i rwd
what intake you have or had?
      07-20-2023, 08:39 AM   #10
kamilbaran
kamilbaran's Avatar
138
Drives: '18 Yas Marina M3, '17 M240i
In the same boat similarity with my ‘17 6mt 240, I am already fully stage 2+ with proper mods/maintenance. Is there generally much more power to be gained off the custom tune improvements of the car? Or is it better off to stay with the ots stage 2+ as it wouldn’t be a major improvement (power wise) but the price of the custom tune wouldn’t be worth it. Would prefer to stay on pump, but I run flex fuel on my f80 and wouldn’t be opposed to it on my f22 especially seeing the limits on pump.
      07-20-2023, 09:21 AM   #11
n55david
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
It depends.. who's 2+ tune are you using?
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      07-20-2023, 09:22 AM   #12
kamilbaran
kamilbaran's Avatar
138
BM3
      07-20-2023, 09:51 AM   #13
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
BM3
It's probably the most aggressive of the bunch so there isn't a ton to be gained without maxing out the turbo but there is a some. Obviously there is a bigeer gain with mhd since it makes less power in ots form etc.
      07-20-2023, 09:53 AM   #14
kamilbaran
kamilbaran's Avatar
138
do you see any value in trying to get more out of stock turbos with a custom tune? I really have no issues w stage 2+ ots but you can’t blame someone for wanting more power always.
      07-20-2023, 09:57 AM   #15
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
I'm in the same boat.. there is room there for sure. The value is in how kuch is it gonna cost for a custom tune. The only tuners I use charge over $1000 so I'm not sure there is much value in it for me.
      07-20-2023, 01:15 PM   #16
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
Do you have an opinion on getting a custom tune to help out with smoothing out the torque curve? My experience with my MHD OTS maps is that I feel like there is too much torque on the low end to mid end, and creates an imbalanced driving experience. I know that is part of having a turbo car vs na but just wondering if some custom tuners can make the power delivery a little more civilized.
2024 M2
2019 M240i- Sold
      07-20-2023, 01:20 PM   #17
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Any tuner can detune the low end etc by playing with the load demand curve etc.. but are you talking for wot or just regular driving?
      07-20-2023, 01:33 PM   #18
B58togo
Drives: M240i
415-420 WHP on 93.
      07-20-2023, 01:43 PM   #19
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
Spirited driving and WOT. Seems silly to pay someone to take away power but there are times where the torque gets in the way of fun.
2024 M2
2019 M240i- Sold
      07-20-2023, 02:02 PM   #20
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Rwd?
      07-20-2023, 02:09 PM   #21
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
Rwd?
Yes but fitted with the M Perf LSD which is way better than stock diff
2024 M2
2019 M240i- Sold
      07-20-2023, 02:16 PM   #22
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
What trans?
