06-21-2022, 08:17 AM | #1 |
Rep 515
Differential oil change
Is the process to do differential oil change the same in m240i as in an m2?
Tried to find youtube video but most video on youtube are on m2.. Is it as simple as drain plug, suck oil out? Is there a separate fill plug or is it just one hole for fill and drain? TYIA |
06-21-2022, 09:41 AM | #2 |
Rep 3,497
There's only a fill hole, so the oil must be sucked-out via that hole. Then you can put fresh fluid in until it starts to flow out of the hole.
I watched the mechanic do this with my car the last time it was done. Believe it or not, he spent 20 minutes sucking-out the used fluid. Basically, once he'd gotten most of the fluid out, he then moved the tube he was using to get the fluid out around in a variety of ways to try and get the rest of it out. And he did get a fair amount more used fluid out of the diff using this method. He certainly had more patience than I would have had if I'd been doing it. I wonder why there's no drain plug on our diffs.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
WolfGTI716.00 |
06-21-2022, 12:05 PM | #3 |
3626
Rep 3,594
Although it isn’t for the faint of heart, you can fit a drain plug to a BMW diff, but it takes some machining. My Caterham uses the “small” BMW diff casing. I think the M235i and M240i use the “medium” one. Here is the operation to machine a flat and drill and tap a hole for a magnetic drain plug, there is just enough space to fit the drain plug and enough casing thickness for the thread:
06-23-2022, 08:14 PM | #5 |
Rep 442
I found that sucking out any oil was the hard part. That stuff is THICK. (It stinks too, but not as bad as the ZF Lifeguard AT fluid.) I had a hard time using any of the 3 fluid suction tools I have and not getting leaks in the seals to maintain suction. However, I was using a home-built J tube made from 1/4" copper tubing, with a 3/16" ID. A bigger tube would probably help.
06-24-2022, 07:59 AM | #6 | |
Rep 913
I wonder if the new M240i's have a drain hole in the new M-Diff.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
dradernh4414.50 |
06-28-2022, 03:39 PM | #8 | |
Rep 3,497
FWIW, I generally drive my car for a minimum of an hour on back roads and highways before fluid changes and run the last third or quarter of an hour in lower than normal gears. That's to ensure higher RPMs and higher fluid temperatures. I ask because I don't recall my diff fluid appearing at all thick when it was extracted by the mechanic at my shop. However, since I wasn't doing the extraction, I might well have missed that the thickness of the oil was greater than it appeared to be when flowing through the clear extraction tube and into the extractor body. The diff fluid I'm running is Red Line 75W110 GL-5 Gear Oil.
06-29-2022, 12:00 PM | #9 |
Rep 864
GL4 / GL5
Interesting that you can find users saying to only use GL5 and others GL4.
. . The OEM oil in my car was / is GL4. . Redline says GL-5 will work and protects better. My thoughts are that GL-5 is a better diff oil but could end up being corrosive if subjected to higher temps and that is why BMW went GL-4. . OEM fluid is stupid expensive. |
06-29-2022, 12:49 PM | #10 | |
3626
Rep 3,594
06-30-2022, 07:56 PM | #11 | |
Rep 442
It's still a 75W oil, so the consistency of thin real maple syrup. And WAY thicker than the typical 0W30 motor oils we use today. As I said, my improvised J tube was probably just too small to easily pull the fluid out. I was just surprised at how difficult it was compared other fluids I usually suck out of the car or small engines. |
dradernh4414.50 |
09-15-2022, 01:35 PM | #12 | |
Rep 239
Drives: '17 M240i 6MT
Sidenote: for anyone who has a Diffsonline diff with the magnetic drain plug, which drain plug is it exactly? I found out on the break-in oil change that it's a 10mm hex, not 14mm like OEM, but I'm hoping to buy a backup plug and a couple o-rings online. |
09-15-2022, 04:27 PM | #13 | |
Rep 3,497
I had the shop show me the magnetic plug at the 1,200-mile oil change, and it had a modest layer of gray mud-looking material attached to it. So it is doing its job. I didn't look at the plug at the time of the second oil change; my guess is that there was either much less or no accumulation of the kind of material the plug attracted before the first oil change. I think I'll look at it again after the next oil change.
SpencerC_6MT197.00 |
09-16-2022, 10:10 AM | #14 | |
Rep 706
Unless you're tracking the car with severe service, that is a lot more work than required... In my opinion of course. I agree, open it up, let drain, remove cover, clean, inspect, replace gasket, refill and you're done! Alternative Maintenance Schedule of 30k miles and replace with Redline 75W-90 and done! Have a great day |
nazali1313.50 |
