12-03-2017, 10:13 PM | #45 | ||
Rep 145
01-19-2018, 03:45 PM | #46 |
Rep 117
01-19-2018, 04:55 PM | #48 |
Rep 525
18x8.5 +45 on 235/40
18x9.5 +45 on 265/35 Below pics are with 5mm spacer in the front, resulting in +40 offset. I took the bottom 2 pics on a speed bump to show suspension compression and clearance. |
01-19-2018, 07:41 PM | #49 |
Rep 986
265's are fly in the back
18x8.5 ET45 - 3mm spacers ET42 235/40/18 18x9.5 ET52 - 265/35/18 I've run Bridgestone PP S04, Hankook RS3v2, and RS4's.. The Hankook's are really great tires on the track, they just seem to stick everywhere. But i'm sure the AWD/xdrive helps I also run GCv2 camber plates in the front with about -2.5 deg front, and -2.25 rear. This has been working out well this past track season. |
02-01-2018, 02:38 AM | #51 | |
Rep 2
Is the front wheel still hubcentric with the 5mm spacer? |
02-07-2018, 12:55 PM | #53 | |
Rep 1,541
Lugs keep the wheel on, but the hub is what supports the car. If you loose the hub "lip" between the wheel/hub your lugs will be the only thing supporting the car....sheared lugs and a flying wheel would probably be the result.
02-07-2018, 01:41 PM | #54 | |
Rep 525
Anyway, while one should always opt for hub centric spacers spacers, thin spacers under 10mm don't have the built-in lip to act as the hub as it relies on the original hub to make contact with the wheel center bore. |
02-07-2018, 04:04 PM | #55 | |
Rep 1,541
Rotational forces (like when launching) aren't that much of an issue I would think. It's the vertical up and down forces (hitting a bump or rumble strip on a track) that would be my concern.
03-11-2018, 10:15 AM | #56 |
Rep 178
Nice setup! Which wheels and tires are you running? I am looking for a similar setup, can't go 19" with all the pot holes around with stock suspension I shouldn't have any issues running 18" 235/265?
03-14-2018, 11:51 PM | #58 |
Rep 445
03-14-2018, 11:56 PM | #59 | |
Rep 1,503
Very tight tolerances on this car. I ran the et62 with a 12mm spacer and it was perfecto
FBO M235i r
F80 M3 |
03-15-2018, 12:23 AM | #60 |
Rep 445
So 18x8.5 ET 45-40 w/ 235/40-18 F; 18x9.5 ET 50-47 w/ 265/35-18 R? Both MPSS or MPS4 (as opposed to a tire like Nitto that runs narrower for its nominal size?)
03-15-2018, 05:20 PM | #61 |
Rep 555
So I have seen people with 18x9.5et45 stuff 265s, I am curious if anyone has tried this on a car that's lowered with 19x9.5et45 (a lot of people running VMR wheels in this offset).
I have a set of VMR V804s currently running 19x8.5et35 with 225/35/19 front and 19x9.5et45 255/30/19 rear. I am debating trying to stuff a 265 rear, and 235 front. Now, I realize there is no fender rolling possible in the rear, but usually as part of roll, some minor pulling occurs. I have read of guys with F30s still performing a roll on the rears (even though there is no lip) and it does a very slight pull. Just wondering if anyone has done anything like this or manage to stuff these sizes with VMR wheels. In the next couple of months I will be replacing all my tires with new P4S tires, and probably around that time getting dinan springs. I feel like a tiny bit more meat might be beneficial but not if its too much trouble to get to work.
03-16-2018, 02:56 PM | #63 |
Rep 555
Would rolling the front fenders help a bit with this?
03-16-2018, 03:15 PM | #64 |
Rep 525
Depends on how wide or narrow your 235 tire is. I have super wide 235s on my 8.5" ET45 and had no rubbing but there was about 2mm clearance on the inside. When I added a 5mm spacer (effectively ET40), it rubbed the fender but only under compression while cornering. Currently, I'm running a 3mm spacer, but once I roll the front fenders, I plan on trying a 7-10mm spacer to bring out the wheel more.
03-16-2018, 04:31 PM | #65 | |
Rep 555
06-05-2018, 01:11 AM | #66 |
Rep 322
This thread was super useful when I was looking at track wheel and tire specs.
I ended up doing Forgestar F14s with RE71r tires (they run wide). 18x8.5(+40?) 235/40/R18 18x9(+50?) 265/35/R18 (not sure what the exact offsets are, been trying to ask Forgestar) I'm also running a bit lower than stock on coilovers, with -2.2 camber on all four corners. No fender rolling. So far, just one track day on them, no signs of rubbing anywhere. It was on Thunderhill, which tends to be pretty hard on the suspension with all the elevation changes... I might get braver for the next set and try 245s front with more camber / fender work... (also, shoutout to Kevin at **********s.com for answering my incessant questions about these) Last edited by msendit; 06-05-2018 at 01:17 AM.. |
