08-13-2023, 10:36 PM | #1 |
Rep 129
Snapped turbo inlet bracket.. is this worth fixing ASAP?
While reinstalling the stock airbox with more force than I would've liked, I heard a snap and found a little plastic piece on the floor. I tracked it down to the bracket for the turbo inlet. It still has a little bit of meat under the 10mm bolt, and it seems like it's just there to help position the turbo inlet. The vent hose connected to the inlet is held in by a torx screw, so leaving the bracket under the 10mm bolt broken should have no impact like allowing unfiltered air into the turbo, right?
You can see the snapped-side of the bracket in the picture. It's just a little bit out of place now. |
