04-26-2017, 03:31 PM | #1 |
Rep 441
Track Days with Hankook RS3
How many days have you gotten out of these tires? I have a 17" square set up. I'm rotating after each event. I have 6 Days on them so far. About 2 hours each day. Running at 38-39 PSI Hot. I feel there is over half tread remaining. What should I expect on average as far as useable days with these tires in total. Car is otherwsie stock, nothing to help camber, etc.
2018 F80 M3 - 6MT - Alpine - Sakhir
2015 F22 M235i - 6MT - Estoril - Oyster - SOLD 2007 E90 335i - 6MT - Crimson - Terra - SOLD |
04-27-2017, 10:29 AM | #2 |
Rep 1,541
Wow that's good wear! Do you daily drive on them too? It's hard to say what you will get out of them. Depends on a lot of factors. When I ran them on my other cars I would not be able to get 6 full track days out of them, but I also daily drove them. I would imagine if they were my dedicated track tires I would have gotten maybe 6 days MAX.
I'll be switching to the new RS4 soon. I'm running the RE71 now.
04-27-2017, 04:14 PM | #4 | |
Rep 5,262
04-27-2017, 05:42 PM | #5 | |
Rep 1,541
I have 1 1/2 track days on my current set (~3 hours). All on the same track with a tire rotation at the two hour mark. Two tires are on their last leg, but again I daily them. Shallower tread and softer compound than the RS3.
04-27-2017, 05:44 PM | #6 |
Rep 1,541
Yes, I will have to double check my measurements before ordering the RS4. It's a wide 255 compared to the RE71.
04-27-2017, 06:09 PM | #7 | |
Rep 5,262
Might end up ordering through Discount Tire shop and have them test fit it and get the RE-71R if it doesn't ... |
04-27-2017, 07:04 PM | #8 | |
Rep 441
04-27-2017, 07:17 PM | #9 |
Rep 5,262
I have 8 track days on the RE-71R but 2 of them where a bit wet... and have about 50% left to the wear bars... but I rotate and run them backwards too so I can rotate side to side
04-28-2017, 09:58 AM | #10 | |
Rep 1,541
Even though it's rated treadwear is the same as the Rs3 the compound is much more aggressive. Manufactures have a lot of leeway in how they rate tires... This is comparable to an R comp tire. Not quite as sticky, but close. Probably a ~1 second difference between a R comp > Re71 > RS3 at Big Willow here in SoCal. RE71 is probably on par with the NT01 which is old tire tech. Also RE71 is LOUD on the street compared to RS3. Keep that in mind if you want to daily it. I don't mind it cause race car. Also keep in mind tire life has ssoooo much to do with driving style and laptimes.
04-28-2017, 10:01 AM | #11 | |
Rep 1,541
My wear is on the inside shoulder which is probably from street driving. Need to pull more camber out. My RE71 after 1 1/2 track days:
04-28-2017, 10:31 AM | #12 | ||
Rep 5,262
04-28-2017, 10:36 AM | #13 |
Rep 1,541
04-28-2017, 12:35 PM | #15 | |
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
04-28-2017, 01:22 PM | #16 |
Rep 1,541
I try to aim for 36* on all 4 for my square setup.
04-28-2017, 03:40 PM | #17 |
Rep 5,262
Don't remember exactly how much hot but these are my cold temps adjusted after a few sessions with a pyrometer
05-04-2017, 10:01 AM | #19 | |
Rep 1,541
The pic of my tire above is actually rotating the wrong way. I rotated my wheels in a X pattern is why. I've flipped the tires on the wheels with my previous setups though too.
05-04-2017, 09:05 PM | #20 |
Rep 5,262
05-06-2017, 10:21 AM | #21 |
Rep 441
05-06-2017, 10:35 PM | #22 |
Rep 5,262
