08-01-2020, 06:18 PM | #1 |
Rep 486
I bought an "Ethernet LAN Network Adapter" (link below) like suggested by xHP website but I'm not able to connect it to my car. Members of an xHP FB group also said they were all having the same issue so this is a known issue obviously.
Their website also suggested another connector called "Thor Wifi Adapter" (link below) and I wonder if I should try it given the fact that bimmergeeks' return policy isn't nearly as generous as amazon. Questions: 1) How many of you have tried the THOR with an iPhone specifically? 2) Has anyone had the same not-able-to-connect issue with Thor/iPhone? 3) How was your overall user experience using an iPhone? My overall impression reading their user manual is that it's not iPhone friendly and that the technology doesn't seem to be very mature (compared to bm3) because the setup needs to be very meticulous or I should say the process can easily be messed up if I miss something tiny. https://www.amazon.com/gp/product/B0...UTF8&psc=1 https://www.bimmergeeks.net/product-...p-wifi-adapter |
08-05-2020, 04:18 AM | #2 |
Rep 9,709
I agree the support for iPhone is pretty sketchy.
I bought something very similar to the RJ45 to Lightning you list. Nothing special price wise. Lightenting to RJ45 Ethernet,... https://www.amazon.co.uk/dp/B085T16D...p_mob_ap_share At first no luck, but the app did react differently when it was plugged in. A clue perhaps that it is doing something. I can't remember the exact wording, but without the connection it would say no supporting adapter found. With the connection it would say something like can't connect. I forced iPhone to use the ip code that they recommend for android. Just in case. Then it was a series of switch on ignition / start app / plug in lightning including force closing app, reinstalling app, hard power cycle phone, or variants of this order. Just as I was about to give up, I tried one last time and it worked. By this point I'd tried so many different configurations I don't know which one was successful. All I can say is keep at it |
08-05-2020, 07:50 AM | #3 | |
Rep 486
