05-03-2020, 02:01 AM | #1 |
Rep 238
Coding Aftermarket Headlights
Hello!
I just recently installed a custom set of BavGruppe component headlights in my F87 (N55) M2. Everything functions as it should, and I honestly have no issues with the headlights. I do however have a few codes which are lingering and resulting in a check engine light on my dash. The codes can be seen below and were pulled using BimmerLink from the FEM. I suspect these codes are present because of the fact that the new aftermarket angel eyes and LED eyebrow are no longer tied into the OEM harness, but instead are controlled off a secondary harness which gets its power / signal from the rear tail lights. So essentially there is an open circuit on where the OEM Angel Eyes / Eyebrow was. I've made sure every warm and cold check is disabled via Bimmercode, and I've done extensive searching but unfortunately cannot find a solution. I imagine the answer lies within disabling the OEM angel eye / eyebrow entirely? I'm not 100% sure, just taking a shot in the dark. Anyone know how to code these errors off? Is this possible using Bimmercode / expert mode? Thanks in advance!
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes |
05-03-2020, 08:30 AM | #2 |
Rep 238
I was able to get the DRL and Design light error coded off and that got rid of my check engine light.
For anyone who has this problem in the future: 3062 Expert Coding... MAPPING_STANDL_V_L_OUTPUT changed to OFF from TMS MAPPING_STANDL_V_R_OUTPUT changed to OFF from TMS MAPPING_PARKL_V_L_OUTPUT changed to OFF from TMS MAPPING_PARKL_V_R_OUTPUT changed to OFF from TMS MAPPING_TAGFAHRL_V_L_OUTPUT changed to OFF from TMS MAPPING_TAGFAHRL_V_R_OUTPUT changed to OFF from TMS 3063 Expert Coding... MAPPING_DESIGNL_V_L_OUTPUT changed to OFF from TMS MAPPING_DESIGNL_V_R_OUTPUT changed to OFF from TMS
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes Last edited by Endeav; 05-03-2020 at 08:55 AM.. |
